Question about Logitech Quickcam Chat Webcam
Bad picture Works on my laptop. On my desktop I get get four very thin black and white pictures.
    Genius:
  • Logitech Master
  • 1,102 Answers
Is cam compatible with desktop have you tried device manager to update cam driver
Have you set cam up on desktop for skype
Follow instructions open skype
Go to TOOLS, then OPTIONS, and click on
Audio Settings
and set the Microphone and Speakers
to the computer Audio Card.
Then click on the Video Settings.
The camera if installed properly
will come up and show a picture.
Then on the bottom of the page click on Save.
Hope this solved let me know
Posted on Feb 16, 2009
I have a I pone four and the apple comosite cable.. when connected i have audio but video is black and white and the vertical hold will not stablize Please help lol
I would suggest you replace the composite video connector.
The bad thing about the analog video cables is that they are analog. Unlike digital, which either works or doesn't, analog can produce a snowy picture or a perfect picture.
It's probably a good idea to replace the cable.
Mar 16, 2011 | Apple iPhone (16 GB) Smartphone
I have a Samsung R700 laptop . The problem is when the laptop is plugged into power lead it works fine but when it is running off the battery the screen flickers then goes black but comes back on after you...
Your LCD screen's picture comes from a very thin ribbon cable which has either a) worked itself loose or b) worn out, either way you will need to undo the four screws at the front of the screen (usually covered with 4 rubber covers). Very carefully unclip the plastic surrounds and then check for the connecting cable. If it needs to be replaced you can ussually locate one from Ebay.
Feb 23, 2011 | Computers & Internet
I have a TV of this model. When I turn it on there is a white line that goes across the screen. There is no picture. After about a few minutes there is a distorted picture on the top half of the TV but the...
Hello
Vertical output sectionj inside the circuit board of your RCA tv is damaged. From your description I understands that there is some loose soldering occured in that section. Just open your TV, locate the vertical output section and resolder most of the soldering points in that section by applying a little more solder. The proble of your TV sholuld be rectified. To locate the vertical section, follow the four wires going from deflection yoke, ie, coil fitted on the neck of the picture tube. There will be four oof them, out of which two of them will be thin relative to the other two. Usually colur coded as blue and yellow. Colour code should always not be the same as described, and it can be changed to set by set. Any way these four wires reach to the main board and socketed there. Follow the track on the print side of the board, where the above said two thin wires are connected, and you will reach to the vertical output section.
If this does not help, replace the IC used in that section with same type and number. If you want any more assistance, please inform me by Fixya. OK.
Feb 15, 2011 | RCA F27442 27" TV
Picture is black and white
Does it sound like thin grinding noise?
The color wheel is very common problem. Color wheel for this model is about $100 to $150 plus labor.
Nour BMI
Feb 18, 2010 | Samsung HC-P4752W 47" Rear Projection...
Only get black & white, double images
bad power circuit may cause such problems.
may be power ic or bad capacitors.....
Aug 18, 2017 | Philips 50PFP5332D 50 in. Plasma...
My sanyo ds31590 31 has a black picture with a thin white line in
check the voltage at vertical ic must get 24volt dc then replace the IC that all
Jun 30, 2009 | Sanyo DS31590 31" TV
Im getting black and white picture from my s-video output
Possibly you have a 2 channel av card built on your tv have you checked all channels if so Maplins do a s-video to phono adapter that converts to colour
May 22, 2008 | Computers & Internet
Hitachi pj-tx100 black and white picture when using s-video
s-video carries luminance and chromanance. In simple terms, luma provides a a black and white picture, chroma the color data. without chroma, you get no color. Either - the cable is bad (usually in the form of bent/broken pins in the connector ends - the source device is bad - the projector input is bad
Sep 21, 2006 | Hitachi PJTX100 Multimedia Projector
Logitech Quickcam Chat Webcam Logo
73 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
