Question about Jenn-Air 30 in. CVG4280 Gas Cooktop
Can I replace the grill on Jenn Air gas cooktop CVG4280 w/burners
My Jenn Air gas cooktop CVG4280 has two burners and a grill. I would like to replace the grill with two burners, giving me a total of 4 burners and no grill. Can this be done & if so, what parts will I need?
Thank you!
Lonnie
  • sandy_lewin Mar 19, 2009
    I'd also like to replace the jenn-air grill with 2 more burners. The grill is okay, but I don't really use it, and two burners are not enough when cooking.
    Sandy
5 Suggested Answers
SOURCE: Ventilation system on Jenn Air CVG4280
My Jenn-Air had the same problem. When you install the drip pan for the burner module, there is a "finger" on the pan that is inserted into a hole in the front of the stove. If you look into that hole, you will see a lever switch. The finger on the drip pan on the burner module is supposed to push that lever switch down and turn the fan off, but over time the lever gets pushed down further and ultimately it does not get activated when the drip pan is installed.
You can either replace the lever switch, or you can try to pull it back into place and tighten the two small screws that hold it in place. Actually, I chose a third option and attached a small, flat spring to the finger on the drip pan.
Posted on Feb 16, 2008
aborcass
  • 2651 Answers
SOURCE: Jenn-Air JGD8130 Gas Cooktop
grab hold of the installed burner cartridge at he top of unit and pry up slightly, should lift up without much effort, if not try lifting front side. they jsut lift up and slide back in no screws hold them in place
Posted on Feb 23, 2008
SOURCE: Jenn-Air 30 in. JGD8130 Gas Cooktop
Yes. Buy a burner module. Sears sells them also most appliance part stores. (I am assuming you have the model with 2 knobs on the grill side) The electric version of burner modules is around $100 Gas should be similar price.
Posted on Jul 07, 2008
  • 1214 Answers
SOURCE: My jenn air espressions gas cooktop has four burners. When
Remove the round burner plates and clean thoroughly in soap and water. Clean the burner ring where the burner plates rest with soap and water.
Let me know what you find.
Posted on Dec 13, 2009
The right side back burner will not light. There is gas, I can smell it but the spark will not start. BUT, the spark will initiate and light the front right burner. What is going on? Its the same...
Can have below issue.
(1) Electric current is not reaching the ignitor. (wire is broken or have a leak)
OR
(2) Having problem with ignitor. (need to replace the ignitor)
Feb 03, 2011 | Jenn-Air 30 in. CVG4280 Gas Cooktop
How do i replace my burner on my jenn air ceramic cook top . it has the down draft feature in the centre
1) turn off power at the breaker. 2) remove hold down screws 3) pop up cooktop out of counter top 4) remove knobs and downdraft grille 5) remove ceramic top (screws around outside and also in side grille opening) 6) unplug burners replace with new burner
Sep 17, 2009 | Jenn-Air JED8430 Electric Cooktop
Igniters not working
ignitors run from a spark moudel thru switches at the kobs then to the electrode.you will need a volt meter and wiring diagram
Dec 31, 2008 | Jenn-Air 30 in. CVG4280 Gas Cooktop
Jun 08, 2008 | Jenn-Air JGD8130 Gas Cooktop
Jenn-Air 30in. Exaust problem
liquid spill and alarm won't go off.
Mar 21, 2008 | Jenn-Air 30 in. CVG4280 Gas Cooktop
Feb 21, 2008 | Jenn-Air JGD8130 Gas Cooktop
Exhaust fan not starting
Bearings are worn. You should be able to replace with a standard utility fan. You can find them at your local big box hardware store or order online here.
www.appliancepartsdepot.com
Jan 27, 2008 | Jenn-Air 30 in. CVG4280 Gas Cooktop
Exhaust fan comes on when burner turned on
The left side is set for your grill. There is apparently a switch under the left side top / front of the cooktop. The aeration tray has a prong on one end that fits into a hole in the front end of the burner basin and activates the switch which stops the fan from coming on when using the burners and allows the fan to run when using the grill. Try switching sides with the aeration trays as one might make better contact than the other.
Dec 01, 2007 | Jenn-Air 30 in. CVG4280 Gas Cooktop
Oct 17, 2007 | Jenn-Air 30 in. CVG4280 Gas Cooktop
Cooktops Logo
230 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
