Cox cable Remote will not control TV
42" Vizio HD, the codes supplied with the TV don't work can you provide me with additional codes, the Cox installer claimed he only has a 50/50 chance with Vizio in programming the remote
  • rio_tom Feb 04, 2009
    This is a simple request please help
  • MudPup P Mar 05, 2009
    Cox Cable remote codes for Vizio do not work with 37" HDTV (720p)
SOURCE: VIZIO vx37l tv remote control code for cox tv remote
0178 will work but you have to keep the set-up button pressed down for more than a few seconds after you press TV on your cox remote. (You will see the tv button light up 2 or 3 times after pressing it and holding the set-up button down)
Posted on Feb 19, 2008
robmonroe
  • 67 Answers
SOURCE: Vizio flat screen has very red tint when using HDTV component cables
Sounds like you may have connected the cables incorrectly, or the cable may me bad. The cable company likely provided you with component video cables, which are red green and blue. Ensure that these are connected to the correct plugs on both ends of the cables.
If that does not fix the issue, I would ask for a replacement cable or box.
You may also be interested in buying an HDMI cable if your box supports it.
Posted on Jun 11, 2008
SOURCE: connecting COX DVR and Phillips DVD to Vizio HD TV
we connected the cable box to the coax connector while our philips dvd went into the HDMI1 connector, and we got both working fine and dandy
Posted on Jan 12, 2009
SOURCE: Programming Cox Cable Box Remote to Vizio TV
using a cox cable remote. cant program to work cable and tv functions at the same time. please help?
Posted on Sep 07, 2009
  • 4 Answers
SOURCE: What is the tv remote code for Vizio for Cox cable
Universal remote code for Vizio sound bar is 1517.
Posted on Jul 14, 2011
How do i turn off closed caption
If you are connected to a cable box the CC is being controlled by the remote of the box.
Usually there is a hot key on the cable box remote if not you can go into settings and under language turn CC on or off.
http://www.cox.com/residential/support/tv/guidedhelp.cox?articleId=5c1b57b0-d6c6-11e1-d920-000000000000
Hope this has helped?
Mar 13, 2016 | Vizio 42 in. LCD TV
My Cox HD/DVR controller will turn off but will not turn on my new HKAVR1700 using the AUX button on the Cox supplied URC-8820-Cisco remote.
This is a documented problem with the Harmon/Kardon AVR-1700 and the Cox remote. Here's how I solved it. On the HK1700, go to System Settings and turn on HDMI Link. This will allow your TV (if it has the feature) to put the HK in standby mode when you power down the TV. Go to your setting on your TV and turn on HDMI link, or equivalent. I have a Sony TV and the setting is called "Control For HDMI." Then, use code 0110 for your Cox remote. This code will only turn on the HK, not turn it off. BUT, the HDMI Link should put the HK into standby.
Jan 06, 2013 | Harman Kardon Harman/Kardon AVR 1700
I am trying to find a remote code for the Cox 7820 remote, that will fully operate my Hannspree tv. The codes provided by Cox will operate most of the TV functions, on the correct buttons, all except for...
I have a Hannspree 42" LCD and I have the exact same problem, the code worked to control all functions except "Power On". I checked the Hannspree web site's support section, it says that their TVs will not work with a universal remote unless you have DirecTV. So why does everything work except to turn it on if they claim their TVs do not work with other remotes?
Oct 25, 2010 | Hannspree 28" Widescreen Flat-Panel LCD HD...
Jun 02, 2009 | Vizio VX37L Television
How do I get sound on my Vizio SV420XVT 42 Great picture but no sound
I had the same problem. I could get an analog audio signal but no digitial signal. My problem was with the cable box setting. I have Cox Cable. With the Cable remote I went to settings/settings/Audio out and selected HDMI. Worked like a charm
Oct 19, 2008 | Vizio L30WGU 30 in. HD-Ready LCD...
Remote Control Programming
GE Universal remote only $12.00 at Target works on my Akai LCD HDTV, this remote also has learning capability but the third code under Akai worked!!!
Jan 24, 2008 | Televison & Video
Code for Vizio tv
I contacted Vizio the other day. They tell me that they use the same generic codes as LG. I have Suddenlink Cable, formerly Charter, so I still use the Charter remote. My remote only needed 3 digits and I have noticed that many need 4 or 5. I can tell you that the LG code worked for my tv. I can power on/off, volume, and change the channel. All other functions require the manufacture's remote. The code I used is 005. There was also 004 but that did not work on my tv. Hope this helps someone!
Dec 26, 2007 | Vizio L32 32 in. LCD HDTV
Nov 22, 2007 | Televison & Video
Code for Vizio tv
Go to the VIZIO site - they post codes. Try these for Cox:
0030 or 1758 or 0178
Dan
Nov 15, 2007 | Zenith ZEN700 Remote Control
Televison & Video Logo
881 people viewed this question
Top Televison & Video Experts
Electro Med Services...
