Question about ASUS P5GZ-MX Motherboard
The motherboard the shut down when switched on
When i switch on the PC the motherboard comes up with no beep sound and the Processor fan spinning for seconds then the mother board automatically shuts down then.
    Scholar:
  • 50 Answers
Is it new? if yes, you probably connected the power supply wrong. most of these things are fine when they get shipped, there's just so many ways to not connect it properly that it's probably that. double check the manual of the mobo and the power supply and make sure youve got every connection right and tight. I have an engineering degree and I still forget to connect something sometimes, causing boot errors...
If it's not that, you have to think CPU connection or other peripheral connection is bad/defective/loose, and the motehrboard is just doing it's job by sutting down to prevent a fire. Doubel check your CPU connection. Did you use thermal paste? Is it snug/pproperly installed? An improperly installed CPU or other peripheral can cause spontaneous mobo shutdown, for good reason. The mobo manufacturer soesnt want you to fry your other components.
If not that, you may want to call your mobo manufacturer, you;'ll be surprised how willing they are to talk you through basic problems starting up. The lack of beeps or lights does bother me a bit in terms of pointing to a bad power connection, or a bad mobo. Usually you would rely on beeps and lights to diagnose what's wrong, as you know.
The mobo manufacturers are usually pretty good about shipping you a replacement if needed.
Posted on Feb 03, 2009
  • 4 Answers
Check heatsink/fan for CPU first. If this is Ok then try a new power supply.
Posted on Feb 02, 2009
Inspiron 2600 PC Notebook 4 beeps
4 beeps (1 long-2 short- 1 long) is a Programmable Interval Timer code (motherboard error). And 1-2-1 is a Processor Register Failure (CPU). About your only hope with a laptop is to pull the battery and (highly recommended if at all possible) pull the RTC battery and then press down on the power switch for a few seconds to totally re-set the BIOS. If no joy, you might one at a time remove the RAM, hard drive and the CD to rule out a short in those components. Next step involves removing the keyboard, etc. to get to components such as the LCD and the network card. Pull them one at a time and try booting. When you have tested all the peripherals that are plugged onto the MB, you can assume that the motherboard is toast.
Jan 12, 2012 | Dell Inspiron 2600 Notebook
No display. Processor fan Blower - active
Identify the pin point of device by swaping of RAM / Processor / and Board.
Then replace / repair accordingly.
Jun 02, 2011 | Asrock 775i65G Motherboard
No Beep no display: Cpu fan Running.
first shut down you computer remove the covers of the cpu then locate the memory and remove them wipe them clean with clean cloth and switch the computer on with out the memory and see if you hear any beeps if you hear beeps insert the memory and switch on the computer if still no beeps then remove the processor fan and clean the surface of the processor fan and the processor apply a thin layer heatsink solvent and clip the processor fan tighty to the socket
Dec 29, 2010 | ASUS P4VP-MX Motherboard
When I turn my HP Pavillion on, it makes 1 long 15 second beep then about 5-10 seconds of silence then another 15 second long beep. It does this continuously. There is nothing coming up on screen at...
If not solved yet, make sure the fan is spinning on the heat sink on the processor. If it is, then if you have a video card installed, make sure that fan is spinning. These are 2 pieces of hardware that will cause the beeping and shut down.
Dec 13, 2010 | HP PAVILION A6230N DESKTOP PC
My led and keyboard and mouse light up when I turn on power switch, nothing happens when I push start button. My e-mail address is debandeddy@yahoo.com
Sep 14, 2010 | ASUS P4VP- MX VIA P4M266A UATX P4/...
Just now i shut down my computer normally, an hour later when i tried switching it on again i cannot, the monitor dosent show any image, it even not shows the BIOS, the fan tuns just for a while and then...
It sounds like a hardware problem. Check the obvious like the power cables and plug it into a different wall socket to make sure that isn't the problem.
Does the computer beep when it starts up. The pattern of these 'POST' beeps can help you determine the problem. However if the computer doesn't beep, doesn't activate the BIOS and the hard drive doesn't spin up (with the HD light flickering) then you either have a fried motherboard or processor. Not an easy or cheap thing to fix.
Sep 03, 2010 | Computers & Internet
The pc does not boot - no beeps jsut no display - all the fans are working - tried a different harddrive and memory same thing
there are 4 condensors on the motherboard next to the northbridge/main processor heatsink that have exploded. buy a new mb. and replace the old 1 by the way you are going to need a new processor also. when the caps blew they took out the brains/processor. or buy a new pc. and specify an asus mb. either way you go...
Nov 07, 2009 | EliteGroup PM800M2 Motherboard
Boot up problems
If it won't go past the splash screen, and you have replaced the CPU, I agree that it is probably the motherboard.
One other test you can do is, remove the memory chips, and any cards that are plugged it, and see if it beeps on start up.
If it does, count the beeps. If it doesn't it is the motherboard.
If you get beeps, plug the memory back in, and try again. Listen for beeps. Let us know what you find.
And I don't know if Compaq's do this (Dells do) when you turn it on, do the fans spin up normally? Or does it sound like a small jet? Speaking of which, do you see the fans spin up at all?
Aug 05, 2008 | Compaq Presario SR1810NX Sempron 3200+ 1.8...
Biostar motherboard or processor dead?
have you also tried different video cards? or the onboard built into your motherboard?
Jun 11, 2008 | Biostar P4M80-M4 Motherboard
ASUS P5GZ-MX Motherboard Logo
103 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
