Question about Agri-Fab Agri - Fab Snow Blower - 42"
How do I start my snow blower....it is electric.. I have it plugged in, have not used it before and the manual is missing. Thanks
My snowblower isn't starting
If it's the starter that makes a humming noise then you need to check the starter out. the gears could be stripped or even a tooth missing so it won't grab the fly wheel. Try pulling the start rope and see if that makes a difference. My Craftsman 8 horse has a recoil starter as well and I quite often use it as well. I don't always use the electric start.
Jan 10, 2016 | Craftsman Snow Blower / Snowblower Bottom...
Is a Champion RJ19LM equivalent to a R C J 8Y?
NO I DONT THE SPARK PLUG IS THE SAME PLEASE CHECK WITHA LOCAL DEALER BEFORE USING THIS PLUG
Feb 25, 2015 | Toro Power Clear 221QE Electric Start 21...
Snowblower won't throw slush
Most snow blowers will not blow slush or wet snow as it packs and plugs itself up. This is normal.
Do not unplug with the blower with it running as you could lose your hand in the process.
Jan 24, 2015 | Power Smart Red, Black Db765126 Db7651...
Procedure to start single stage electic start toro snow thrower
plug in Electric start. Push Choke to 'ON'. press Primer Bulb about 2 times. Turn Key to 'ON' Press Starter.
If you didn't run it completely dry of Gas last season I bet the Ethanol gas messed up your carburetor
Dec 15, 2014 | Toro Power Clear 621 ZE 21 163cc Single...
I have a cub cadet that has seized I have tried pulling spark plugs out and put oil in cylinder and tried pull start won't start
If it won't turn over or if it is hard to turn over, it probably has a twisted crank shaft. It will have to be rebuilt or replace the motor.
Nov 29, 2014 | Cub Cadet Snow Blowers. 30 in. Two-Stage...
Engine starts immediately when plugged in w/o pressing button
this button may be arced in the on position.. get someone to replace it..or put a pushbutton on the electric cord itself..
Jan 12, 2014 | Mtd Yard Machines 24" Two Stage Snow...
I am unable to start poulan pro snow thrower. Recoil handle will not pull and electric start wont turn over. Brand new machine, never used. Is there a safty mechenism?
have you ever had it running?
you can check the starter, pulll it off and check gear at the end
if teeth are missing the you have to get them off the magnets on the flywheel. they jam it there giving the indications of a set up engine. I ve seen it 2 times
Dec 14, 2013 | Poulan Pro 27" Snow Blower Electric Start
Trouble shooting New Toro Power Clear 418 zr - slight misses and pops while running
when you start it do u use the choke right , when starting close choke when it starts open choke you prob fouled the plug clean it put back it walah
Nov 22, 2013 | Toro Power Clear 418 ZR - Single Stage...
My cub cadet 221 cranks won't start
Clean your carb, if you have not stored it correctly you have a dirty carb now. Carb could be gummed up.
Feb 17, 2013 | Cub Cadet Snow Blowers. 21 in....
Agri-Fab Agri - Fab Snow Blower - 42" Logo
Top Agri-Fab Garden Experts
Roland W VanLue
Roland W VanLue
Paul Sikkema
Paul Sikkema
Joseph Mueller
Joseph Mueller
Are you an Agri-Fab Garden Expert? Answer questions, earn points and help others
