Question about Vivitar ViviCam 5386 Digital Camera
MSVCR70.dll error when opening a pic
When i try to open a pic, it says MSCR70.dll was not found. what do i need to do?
Windows is telling me there is a dll problem
In order to correct this error, please visit the following website:
From here you can search for the particular .DLL file relevant to your case (e.g MSVCR70.DLL). Once found, simply follow the instructions to install the missing files.
Jul 20, 2011 | Konami Live Online Game Controller:...
Installed a new hard drive with windows 7. Hallmark card studio was installed on an external hard drive. I don not have the installation disk, it is in storage in another state. when i click on...
You have to have the original software to reinstall a program. Just tranferring the files does not work. By default windows must complete the setup process through windows installer.
Mar 14, 2011 | Sierra Hallmark Card Studio Deluxe 2004...
I am suddenly getting this message on Hallmark Card Studio 2005, "This application failed to start because MSVCR70.dll was not found. Re-installing the application may fix this problem. I went to the...
1) do not down the driver from a driver site
2) do you know which program is using it
2a) if so reinstall that program onto your machine
3) check your recycle bin , if there restore it
now normally i would suggest putting a clean copy of windows on. But i want you to think, when you got the message did you just recently add a program to your machine , and when (what date) you can try to run a restore of your machine on the day before the program was put on. Now if that works, dnt go any further till you scrub that machine for malware and virus's then proceede. that is your problem malware or a virus got you and your vurus detecting soft wear may have done it .
good luck i hope this helps
Jun 14, 2010 | Sierra Hallmark Card Studio Deluxe 2005...
I have the same regsvr32 wintrust.dll error code 0x80070005 i cant log into my hotmail. i found in another forum that i should try running the following: regsvr32 softpub.dll regsvr32 wintrust.dll...
- Double click on the clock in the taskbar and make sure the system clock is set correctly.
- Disable Zone Alarm
- Register softpub.dll using the regsvr32.exe tool.Click Start, and then click Run.
- In the Open box, type regsvr32 softpub.dll and then click OK.
- Do the same for the following regsvr32 wintrust.dll, regsvr32 initpki.dll, regsvr32 MSXML3.dll.
- Restart Windows Live Messenger.
If you are still unable to fix Windows Live Messenger your computer might be infected, I recommend you Download registry cleaner to fix your errors and speed up your computer.
Aug 21, 2009 | Microsoft Windows Xp Home Edition English...
Image.dll was not found
un install the application and re install it - if it still says the same then there is something wrong with the installer - if you go to the manufacturers website you may be able to download the application setup file or at least get the relevant dll ( either from there site or by using google and virus checking the file before registering the dll file )
If you need help with the latter post back.
Apr 11, 2009 | Acer Aspire 2930-4661 Notebook
AegisE5.dll was not found.
u can go to this site...
as I registered few dll's from this site...worked in my case :)
Jan 03, 2009 | Televison & Video
Iwve got an alert that i missed m3plugin.dll i found the dll file and copy it to the correct file according the path but now he say that i missing antry upf
Try to register the DLL file. Goto run type cmd. This will open the command prompt. Type regsvr32 c:\enter location of .dll file\m3plugin.dll and press enter. This will register the .dll file if that is the problem.
Dec 03, 2008 | Intel Motherboard
The file bcmwltry.exe is the tray bar process for the Broadcom Corporation Wireless Network software.
You can try eliminating the program from start up.
Click on Start >>Run, type "msconfig" (without the quotes), then click on OK.
When the System Configuration Utility loads, click on the "Start Up" tab, then scroll down to the "bcmwlt.exe" entry and UNCHECK the box next to it.
Click on Apply, then OK, and the computer will need to be restarted. Do it. Upon restart, you'll see a System Configuration Utility warning. Simply choose the option to stop it from repeatedly opening.
This will be fixing your problem
Have a great day!
Pablo :-)
Oct 22, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Vivitar ViviCam 5386 Digital Camera Logo
48 people viewed this question
Top Vivitar Cameras Experts
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
