Question about Brother MFC 420CN All-In-One InkJet Printer
Get "BUSY: BUSY/NO RESPONSE" on T.VerificationReport when faxing
No receipt by 'sendee'. My machine dials repeatedly and repeatedly gets the busy message. When other party tries to fax me, my machine rings and says "Receiving", but nothing comes through. Yes, the green fax light is on.
  • spw777 Feb 03, 2009
    no, regular Verizon landline service
    Genius:
  • 2,120 Answers
Do you have DSL phone service or any other kind of DIGITAL phone service?
Posted on Feb 02, 2009
Fax receipt code shows a status code of 0050, What does that mean ?
It means there is no dial tone on the fax line, is the rj11 plugged in properly [ (Line) on the copier, not he one labeled as (TEL) ], is the telephone patch defective, or you have an active phone on the wall jack, (test it it with an ordinary phone), or the receiving party is busy, try later, or try a different nunber.
May 05, 2014 | Toshiba E-Studio 206L Copy Machine
How do you send a Fax?
1 Load the document face up into the Document Tray.
2 Dial the receiving party's fax number.
3 Press [Start/Copy].
The fax begins sending.
Note
If an error occurs during sending, the fax beeps intermittently for a few seconds and an error
message appears on the LCD. If this happens, correct the problem and then press [Stop], then
try sending the document again.
The fax automatically redials if the receiving party does not answer or if the line is busy.
Feb 21, 2011 | Canon FAX-JX200
I have a Brother fax machine. When I dial a number to send a fax, there is a noise on the speaker in addition to the fax dialing and it defaults into a busy signal. What should I do?
The number u are dialing is either busy or someting is wrong with the phone line thus not connecting to the other party. The fax set up may be confiqurated wronlgy.
Regards
Sep 28, 2010 | Brother Office Equipment & Supplies
Can not receive or send faxes???
If your fax machine was working before this could be a line problem. Call your fax number with your cell phone or another phone. If you get a message phone the phone company or it just rings busy its probably a line problem. Another check is to plug your hand set into the wall outlet jack, you should hear the dial tone. If there is no dial tone its also a line problem. Or just try pluging your fax machine in at another location, if it works there you know its a line problem. If its still not working its going to be one of the boards inside the fax machine. Good luck.
May 16, 2010 | Office Equipment & Supplies
Fax is always busy when sending, have the line into the phone line port and into the telephone jack, fax scans and dials and even redials but it never go through, prints out receipt that says busy/no...
Has it always done this, or did Fax once work? Sadly, Windows XP Fax has many shortcomings, not the least of which is that it won't work with many modems still in common use. Modem incompatibility is not apparent during installation or the initial setup. It only becomes apparent when you try to send or receive a fax. The Fax Service will dial or will answer an incoming fax but then fail with any of a number of unhelpful error messages such as "Line is busy," "There is no answer," or "Reception error." There will be nothing in Event Viewer to give a clue as to where the problem might lie.
These errors have been nearly impossible to track down. To do so requires enabling both PSS and debug logging of fax transmissions, both of which require fairly extensive registry changes. For the time being, the best advice is to attempt to use XP Fax only if you have a modem that is listed on the Windows XP Hardware Compatibility List and using the latest drivers.
Hope helps.
May 09, 2010 | Brother MFC-5840CN All-In-One InkJet...
No dial tone when pressing hook fax is returned
The only thing that could stop you from sending a fax or not get a dial tone, would be the connection to the phone line. Make sure the telephone wire is plugged into the line jack (not ext jack) and should go straight to the wall, without splitters or extensions. If you still cannot send a fax, try another wire or jack
Apr 06, 2010 | Brother Multi-Function Center MFC-240C...
When I fax it says phone off hook. I get a message stating no answer.
Try dialing the FAX-number with your cell-phone.
Do you hear the "ring", or does the telephone-company give you a "busy" signal ?
Some FAX machines are "busy" -- receiving many FAXES from multiple customers -- reprogram your FAX machine to "retry" a few times.
Or, when a receiving FAX runs out of paper, it sometimes refuses to accept "new" faxes.
Nov 16, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Outgoing Fax on my HP Officejet 6210 All-In-One
The fax machine needs to hear a dial tone first to send a fax. If you have no fax number, what working phone number are you using?
Jan 23, 2018 | HP OfficeJet 6210 All-In-One InkJet...
Fax machine error
I called Kodak support and had to upgrade firm software and reset all the settings to reflect whether I had an answering machine (yes) and call waiting (no). Also found it helpful sometimes to dial out using commas after the 1, to keep it from ringing busy.
Nov 03, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Brother Intellifax 4100
Press speaker can you hear dial tone?
Try ringing you mobile from fax does it ring?
After dialing correct number with (outside line prefix if required) press start
Oct 18, 2007 | Brother IntelliFAX 4100 Laser Fax
Brother MFC 420CN All-In-One InkJet Printer Logo
498 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
