Question about Sony Handycam DCR-TRV530 Digital Camcorder
Blinking error code C:21:00 how to remove from sony camcorder
How can I remove error code C:21:00. My unit sony DCR-TRV530 was exposed to high humity as indicated by flashing water drop. Unit opened as per owner's manual but error code still flashing
Thanks Ron. Yeomans
  • ronandbj Feb 04, 2009
    Thanks for trying. Reset button only surfaced the clock setting on the screen. C21:00 keeps on blinking. Probably needs to check by a service tech. regards Ron
    New Friend:
For me, the alcohol sensor cleaning didn't work. I did some research on how the sensor works and it turns out the black stuff is conductive in low humidity and resistive in high humidity. That means the circuit need to be cloed to work,, cleaning off the black substrate would only open the circuit furthur, I cant understand why removing the black substrate is working for some people. After cleaning it to no avail, I tried bypassing (shorting) it. To test it I just took an ordinary pencil and filled in some conductive carbon where the black square was. And it worked. I could have bypassed the sensor by shorting the 2 solder contacts, but to reach it I would have to take it all apart. I'll make the bypass permanent when I have a day free.
Posted on May 29, 2013
    Problem Solver:
  • 17 Answers
FINALLY FIXED and ITS FREE! Typical Sony quality. I've a PC9 and have been smacking it every since for over 2 years until I found this link (http://www.dvinfo.net/forum/sony-hvr-a1-hdr-hc-series/88013-moisture-condensation-2.html) !! This will work for most Sony DV camera more than 6 years old.
No need to abuse your Sony anymore especially in public!!
Don't throw away a perfectly good camera . Even though its old. reuse recycle ... !
Posted on Jun 29, 2010
  • 41 Answers
Try depressing the small "Reset" button with the camera power on. Use a sharp pencil/ball point pen to do that. It resets the logic in the camera and may help.
Posted on Feb 03, 2009
    New Friend:
Hi, intro in http://www.youtube.com/watch?v=KhzD7Xf5Rso
Posted on Apr 11, 2013
Error Code C 21:00 continues to flash
Hi, ok now you hold your breath and follow the instructions.. 1. remove all the batteries including the tiny backup battery (usuall seen behind the screen) 2.then hit it very hard.. now insert the batteries and check .. if you dont belive read the link http://www.camerahacker.com/Forums/DisplayComments.php?file=Video%20Camera/Sony/DCR_PC5E_Error_code_C_21.00.html all the best regards sreejith
Jul 13, 2007 | Sony Handycam DCR-TRV530 Digital Camcorder
DCR-TRV530 Digital 8 . . . Problem started with tape being caught in heads. Got a 3121 error message afterward . That stopped but in video playback mode only blue screen with play arrow at top? In...
If video head got clogged then camcorder wont read tape in playback so result comes as blue screen.
Please use video head cleaning tape and clean video head of camcorder. This will solve your problem.
Video-8 head cleaning tape is available with amazon.com
Thanks.
Dec 03, 2010 | Sony Handycam DCR-TRV530 Digital Camcorder
Error c:31:42
This code means
"FG fault during normal drum operations. Load the tape again, and perform operations from the beginning."
'C' indicates consumer-fixable problem.
'31' indicates the fix method (remove casette).
The 'FG' signal from the capstan motor is the tachometer signal that the camera uses to monitor the rotation of the capstan.
Jun 19, 2010 | Sony Handycam DCR-TRV530 Digital Camcorder
Sometimes the hot water just goes cold
Here are a couple things to look for:
1) flashing burner light - a flashing burner light indicates the unit is getting an error code
common error codes:
A. continuous flashing - ignition failure or abnormal combustion; look for visible water in the machine indicating a leak, check gas pressure, debris or buildup on flame rod/igniter plug, or clean unit with compressed air
B. 3 flashes - error 16, abnormal outlet water temperature; typically this code indicates you'll need to descale you unit
C. 4 or 5 flashes - exotic error codes; you should contact Noritz technical support to deal with these codes
2. If there is no flashing code, try increasing the hot water flow. In the summer time you typically use less hot water; this can result in intermittent operation of your tankless heater. Increase water flow by either: A. cleaning your showerhead and removing scale deposits B. widening your flow restrictor C. Remove your flow restrictor in the showerhead
3.If none of these resolves your problem, you probably have debris in your flow sensor. Contact Noritz technical support for a walkthrough on removing debris from a flow sensor.
Feb 18, 2010 | Noritz 6.3 Gallon Residential Tankless...
Sony dcr trv245e erroe code c32 20. I have had condensation issues with this camera in the past and now I cant eject the tape. can anyone help
The error code that your unit is now producing indicates that it is experiencing a tape transport problem - specifically that the takeup reel is leaving slack out of the cassette. This may have led to tape becoming caught in the mechanism and hence the cassette will not eject. This is one scenario although unfortunately it is not the only possibility.
The unit will probably need to go to a professional to have the cassette manually removed and the cause of the fault condition identified and rectified.
Jan 02, 2010 | Sony Handycam DCR-TRV250 Digital Camcorder
When transferring (or watching) video from this Sony DCR-TRV530
Sounds video head is dirty / clogged.
Use good quality video-8 head cleaning tape for head cleaning in DCR-TRV530 and then record and playback it.
Aug 23, 2009 | Sony Handycam DCR-TRV530 Digital Camcorder
My DCR-TRV530 Digital 8 camcorder got stuck, the tape is half way out but it does not pop-out and I can't take it out
If the tape is wrapped around a head or caught in a pinch roller, then you may be able to remove it with your pen. Underneath the tape is a small hole. Insert a pen or similar object into the hole. This will let you disengage the spindles in the tape. You have to hold the pen in the hole to keep them disengaged. You can then pull out the tape cartridge. This will let you see inside and whatever may be holding the tape in. Hope this helps.
Rob
Mar 07, 2009 | Sony Handycam DCR-TRV530 Digital Camcorder
Error code C:31:42 on a Sony Digital Handycam DCR-TRV530
Here is the solution to your problem:  C:31:42 = FG (film guide) fault during normal drum operations. Load the tape again, and perform operations from the beginning! Hope this helps.
Fotobean
Jan 19, 2009 | Sony Handycam DCR-TRV530 Digital Camcorder
Will not download to my computer
looking at the manual i don't believe you can download to a pc using the usb cable. you have to use analogue.
Nov 19, 2008 | Sony Handycam DCR-TRV530 Digital Camcorder
Sony Handycam DCR-TRV530 Digital Camcorder Logo
2,970 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
