Question about Refrigerators
Hello i have a side by side and now it has stop making ice in the freezer and it started to trip the gcf plug on three different occasions today
  • Refrigerators Master
  • 4,655 Answers
Jennifer, Something serious is happening here. Your details describe a very high amp. draw relating to a short circuit some where inside the Refrigerator. Prepare to remove the food to a new location until we can chat and solve this problem. let me know when you need me.
Posted on Feb 03, 2009
Freezer stopped making ice two days ago. Today fridge and freezer warm
Check the defrost timer. Rotate the dial on it to see if anything changes.
May 04, 2009 | Freezers
Problem with Maytag Chest Freezer model MQC1557aew.
First make sure than the condensing coil in the freezer is clean of dust and dirt(it is behind the grill vent in the bottom side of the freezer where the compresor is) If it is clough brush the dirt off after you unplugit.When is clean wait a few minutes ,5, and plugg it back at the GFI outlet and see if work If still tripped the outlet you may have to replace it.
Apr 04, 2009 | Maytag 14.8 cu. ft. / 419 liter Chest...
Ice maker broken
The ice maker likely needs replacing.
But ceck it to make sure its not hung up.
Does it have ice frozen in it or is it just turning arround.
Remove it and see if the heater underneath has a hold burnt in it.
Its just a plug in unit you can order one online.
Jan 13, 2009 | Freezers
Fridge tripping breaker, ice maker shorting out
Sounds like you have a short in the freezer .Double check all electrical wires with a meter .
I would also check on that bedroom outlet because sounds like that outlet is not grounded
May 26, 2017 | Frigidaire GS26HSZDW Side by Side...
Freezer not cold enough; fridge OK
Hello cokoliso,
Welcome to Fixya
You said, your Trio won't make ice. Freezer stays at about 25 degrees regardless of control setting. Fridge maintains 40 degrees at mid setting. Shouldn't the freezer be close to zero? Is there a way to check the temperature sensor in the freezer?
To check the temperature you can buy a refrigerator thermometer at the hardware store.
Ask if it can be used in the freezer too!
The fridge sounds slightly to cold and the freezer not enough.
Fist look in your freezer and check if the articles there are full to the max and covering the air vents usually found in the rear of the freezer.If so clear an opening for the freezer to breath.
Refrigerators and freezers usually share the cold air and I've seen this be the problem on many occasions.
If freezer was not I blocking the vents or even full to the max.
Then pull the plug out or if you can not reach the plug, trip the breaker off for 5 minutes and see if this resets the system.BUT do not plug the fridge back in before at least 3 minutes.
Let me know how it goes and send me any questions.
Thank You, Huuum
Please remember to leave a rating .
Oct 03, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Ice maker not working
Hello bnelson488,
Since the ice maker is erationally starting and stopping at it's own leisure.
1.We must first try to turn off the fridge.
2.unplug it or if you can not reach the plug you can turn off the breaker to the fridge also, for 5 minutes!
After this you restart the fridge and see if the system reset it self.
This is a common way to reset some units!
If nothing works then perhaps the ice maker needs to be replaced.
How old the fridge?
Let me know how it works and if you have any questions.
Please remember to give a rating before you finish..
bless you
Huuum.
Here is an interesting article I just read.
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Sep 04, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer defrosting
you have a defrosting issue for sure, you neeed to unthaw the freezer coil first and then find out if the defrost heater the defrost timer or the defrost bimetal is the issue one of these three parts is bad
Apr 22, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Leak from icemaker shorts electricity in house
It sounds like the ice in the bin is warming up enough to melt for some reason then re-freeze. Check your door gasket seal and also the ice chute door flapper seal to make sure warm room air isn't being drawn into the ice bin area. Also make sure the freezer area is VERY cold like 0 degrees F or lower, that will keep the ice hard and help stop the ice from having a liquid surface film from opening and closing the freezer door too often (then freezing again). The water down the back is from the ice cubes melting a little then re-freezing. Also, is the frige working OK? Does the compressor turn on and off normally? I ask because sometimes the compress start device is failing and the refer can warm up quite a bit while the compressor is trying to start up... eventually the compressor will start but by then the ice has melted a little then the compressor runs for a long time to bring the temps down again. Monitoring with a thermometer every hour will show if the temps are lowering in the freezer section too much.
Dec 10, 2006 | Maytag MZD2669KE Side by Side Refrigerator
Refrigerators Logo
41 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
