Question about Texas Instruments TI-84 Plus Calculator
Turning on and working
I cant turn my calculater on at all.....i tried during trig class and i had to hold the on button even then it w0ouldnt work if i pressed any thing....i got home and i tried the batteres even the watch battery and it stoped doing every thing and the bateries were fine....help i have ACT THIS weekend!!!
I had one of my more technologically advanced friends look at it and he fixed it....dont ask me how he did it but he did oh boy did that make me happy!!!!!!
Posted on Feb 04, 2009
Im getting the wrong answer for when i try to solve for a trig inverse on the ti nspire cx
When you are dealing with trigonometric functions and their inverses, the results depend on the angle unit (degree, Radian, Gradian).
To set the correct angle unit (the one required by your problem)
  1. Turn calculator ON
  2. Press Menu key.
  3. Press 5:Settings>2:Settings>1:General
  4. On the second line Angle, there is a drop-down menu you activate by pressing the Right Arrow.
  5. Select Degree, Radian or Gradian and press Enter.
  6. Using the down Arrow move focus to the bottom of the screen where you can Make Default, or OK.
  7. Press one or the other.
  8. Validate your selection if asked.
May 20, 2012 | Texas Instruments TI-Nspire CX Graphing...
My calculater has everything on the screen but its really light. I put in new batteries and it still doesnt work. Its a ti-84.
Turn the calculator on. Press and release the 2ND button. Press and hold the up-arrow button to increase the screen contrast. If you go too far, use the 2ND and down-arrow buttons to decrease the contrast.
Sep 15, 2011 | Texas Instruments TI-84 Plus Calculator
Westinghouse - 60" Class / 1080p / 120Hz / LCD
There is a method called a Power Scan this method allows you to search for all possible codes. Try this until you reach a code that carries all of the functions desired. If the TV mode button starts flashing rapidly during this process you have exhausted all possible codes.
Power Scan
1.) Hold down the clear "TV" button on the remote for four seconds, then press 500 pound ( #)
2.) Hold down the clear "TV" button on the remote for four seconds, press the big power button once.
3.) Press the channel up button once per second until the TV turns off then press pound (#).
Daniel Busa
DISH Network
Customer Service
Apr 17, 2011 | Westinghouse 16093 Remote Control
Lcd
try rsetting the iPhone:
Download the latest iTunes to your computer and reset the iPhone. Then re-sync it.
Reset
To reset iPhone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears.
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
Jul 24, 2009 | Apple iPhone Smartphone
I need to reset my mercedes 2000 s class ichange oil and need reset service B
Try this, it is the procedure for resetting the ASSIST computer on many Mercs
1...Turn Key to position No:2 in the ignition / steering lock and immediately press AND Hold the button "000.0" (the trip reset button) TWICE within the space of 1 (one) second.
2…Turn the key to position No: 0 in the ignition / steering lock. Then release the button.
3...Press AND Hold the button "000.0" (the trip reset button) and turn Key to position No:2 in the ignition / steering lock. Keep button pressed
After about 10 seconds
the service indicator will reset and an acoustic signal may briefly sound
That should do it....Good Luck…...Let me know if it works?
Jun 23, 2009 | 2000 Mercedes-Benz S-Class
Inverse Functions on Casio fx-270W PLUS don't seem to work
because cotangent, cosecant, and secant are all inverse trig functions, just type in 1 / |shift| trig function and the number if you are finding the angles. It might not be a dedicated button, but its an extra push, and it will give you the same result. *note that I put the shift press only because that is how you get the inverse tan to get an angle from a tan ratio.*
May 04, 2009 | Casio FX-270W Calculator
The key switch
check your battery on the car if under 12v boost with jump pack or next car .then try.if batery is flat and this doesnt work then try disconneting battery for 5mins then retry with boost.if battery is ok then wiil be immobiliser fault as the key is not bein recognised.
Feb 27, 2009 | 2000 Mercedes-Benz S-Class
Ti-83 plus
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
Aug 14, 2008 | Texas Instruments TI-83 Plus Calculator
Reconnecting
When you turned off the Wii, did the light turn red or amber?
If you haven't done this already, hold the power button until it shuts off, and the light is red. Power it back up and try your remote again.
Jan 25, 2008 | Nintendo Wii Console
Texas Instruments TI-84 Plus Calculator Logo
62 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
