Question about NAD C320 2-Channel Amplifier
Right side speaker input don't work
I have a Marantz 60's model 2230. I was listening to it one day and the right side went out. I smelled something burning. If you turn the volume most of the way up, you can hear a little sound. This is a family heirloom, please help!! Thanks in advance, Jason
  • 2 more comments
  • Jsonp Feb 02, 2009
    The left side works just fine. Other than that I don't know how else to troubleshoot it.
  • Jsonp Feb 03, 2009
    Thanks alot Dan!!! I found the burned resistor last night and replaced it. When I turned the unit on the same resistor wanted to burn up also. I learned alot about resistors online last night. Just general knowledge. I'm sure there is more I need to learn. I do have a multimeter and I can solder. I'm sure I can do the repair but I need guidence. What can you tell me about output transistors that could help me? Where do you begin testing with the multimeter?
    Asheville, N.C.
  • Dick
    Dick May 11, 2010
    There is no way to tell what is wrong with it from that description. I can tell you it isn't something you can fix yourself unless you are skilled with a multimeter, have the schematic, and can read a schematic. But if you had those three things covered, you wouldn't be here.
    Good luck
  • 4,234 Answers
There are a number of possibilities that can cause this. Since you smelled some burning, I would suspect that the output transistors on the right side have shorted. This can sometimes cause a resistor to burn before that section is turned off. This is a relatively simple repair for anyone familiar with those units. I have rebuilt a number of these over the years and can tell you that the repair is worth the expense. You can figure on $25-$40 in parts plus the local labor rate for the total cost.
If you have a multimeter and can solder, you may be able to repair this. This is not the easiest unit to access however, so if you are not experienced, I would not start here.
Keep me posted.
Posted on Feb 03, 2009
  • ABRsvcs Feb 03, 2009
    The output transistors are the large silver parts that are roughly oval. The best way to resolve this is to A/B the 2 sides. Remove the output transistors from both sides (mark the ones from the bad side). With the outputs removed, you should be able to power up the unit without generating smoke. If so, carefully take voltage measurements on both sides to determine where things go bad. Its hard to describe the steps as I have been doing this for years and most of the checks are habit.
    Where are you located?
MARANTZ sr5200 Left Speaker larger sound right speaker
If you are saying that the left side is LOUDER than the right it could be DC offset on the recording or it could be phasing issues.
Feb 15, 2017 | Marantz Audio Players & Recorders
I have a Sony tv that I have my new firestick attached to currently. But my xfinity x-1 box is plugged into my marantz system where my speakers are connected and controlled.
You should have an optical audio output jack on your tv that you can connect to your receiver to output audio through your speaker system.
Dec 26, 2015 | Sony Audio Players & Recorders
Where do I find the service manual for a Marantz IA_2232_sb Amp?
If the left side is good then you don't need a manual. The reason being that the right side components are the same as the left side. The only items that are unique are to do with the power supply.
Any voltages on the right will be the same as the left. If you touch with an insulated screwdriver parts on the left and they buzz then touching those on the right will do the same. If it doesn't then you have located what's wrong. If a part looks different to that on the left replace it.
Jul 10, 2014 | Marantz Audio Players & Recorders
One side not working
the 2230 is a fine unit! There could be several things causing this problem, more than likely it could be dirty front controls which will require cleaning. It could be more serious problems such as pre-amp or main amp failures, dried up output coupling cap for the right channel. I would recommend having the unit serviced. These older vintage Marantz units are really special and deserve proper attention.
Jan 21, 2013 | Marantz 2230
If you get scratchy sounds while doing so, the potentiometer needs replacing. If not you could check the solder joints for it and see if its loose. You could just resolder it if that's the case.
Nov 15, 2011 | Marantz PM-68 Amplifier
Hi, I have a SR4002 AV surround receiver and I can no longer get my speakers or subwoofer to work. I have noted that the display reads analogue and I cannot get it to switch back to digital. I have done...
A setting on the receiver is the problem. Open the manual and examine every indicator for clues. Blown subs don't make settings change.
Page 39 for digital and other modes.
Run the speaker setup routines to test their function.
Aug 22, 2011 | Marantz SR4002
Durabrand Home Theater System Model HT-3917. It was playing ok a little crackle from the front side speakers for a couple days now and it just went off. I checked the fuse no,I checked the power strip and...
You (we) still don't know if the speaker or electronics are at fault. Swap the speakers left-to-right. Use test tones to test all channels. Could be a loose speaker wire, too.
Jul 24, 2011 | Durabrand HT-3915 System
Sound probem of marantz amplifier at right side.
sure it is not the speaker?
switch them and check
Mar 02, 2010 | Audio Players & Recorders
Crackling and popping sounds in surround sound speakers
Could be your head unit or the connection to the speaker may be bad. Also if the wire to the speakers in your ceiling is bare and touching any ground it would interfere. Start by checking connections by playing something and messing with wires. Listen for a difference. Next check by putting the wires that power those speakers in a known working output and listen for different quality
Apr 04, 2017 | SpeakerCraft 8" 150W In-Ceiling Speaker...
Center speaker hookup to a MARANTZ mdl 2238
Hi tliguyanadig
You can hook up the speaker "between" left and right outputs. Just connect the center speaker between left +ve and right +ve outputs respectively. It will give a spacial effect that some like and some dont:) Try it and see for yourself. Your marantz amp will handle the load OK. It is rated 38 watts into 8 ohms, but there is not alot of load presented by this sort of setup. Let me know what you think.
Apr 03, 2008 | Audio Players & Recorders
NAD C320 2-Channel Amplifier Logo
124 people viewed this question
Top NAD Audio Players & Recorders Experts
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
