Question about Sony DHC-MD333 Shelf System
Radio presets Bought this system second hand and no user manual, worked out most of the things except how to get the radio presets to work...could somebody help, well explain how to set the fm presets using the remote.. thanx
I have the almost identical MD373. Tune to the station you want, press MENU/NO, right arrow (either one will work) to "P. Memory", press ENTER/YES, use arrow keys to select the number you want to assign to, then ENTER/YES again. This system won't let you assign to a number higher than the first unused preset, so the first preset must be number 1. Options to erase one or all presets are on the same menu.
Posted on Mar 03, 2009
Bush radio ne3116 - i cannot preset channels
Choose the required station with up/down arrow buttons, press SELECT.Press and hold PRESET button until number flashes.Quickly scroll through preset channels with arrow buttons.When required preset chosen, press SELECT.
Voila: station saved!
Took me about 15 minutes to figure it out, as bought radio second-hand with no instructions, and none on internet, until now!
Sep 14, 2011 | Audio Players & Recorders
Radio Installation procedure
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} These are the working Code Entry Instructions if the Renault does NOT have the Steering wheel Remote Control
Keep pressing the Preset [1] until the correct first digit appears on the display
Keep pressing the Preset [2] for the correct second digit
Keep pressing the Preset [3] for the correct third digit
Keep pressing the Preset [4] for the correct fourth digit
If the correct code is now shown on screen, press and hold the Preset [6] for 10 seconds to save it.
Note: If Preset [6] does NOT enter the code , then try Preset [5]
Jun 06, 2010 | Car Audio & Video
I disconnected the negative battery cable, and reconnectd it to fix check engine light, now my aux 2 wont show up on my radio dial, so my sattelite radio wont work
when you disconnected the power from the radio you lost your presets radios have two power lines one is primary and is used to power everything while on the other is a remote power line and is only used to keep clock and presets so what you going to have to do is ind your user manual and reconfigure the radio to accept the satellite radio on the second aux input
hope this helped
Robb
May 13, 2010 | Pioneer Audio Players & Recorders
Instruction manual for TDK NX-03 CD Sound System needed.
I have a manual if you want to send me your email I'll will scan to PDF and send you a copy.
Dec 16, 2009 | TDK Audio Players & Recorders
Mitsubishi Lancer 2004 Radio Code Not Working
Use the first four radio station preset buttons to enter the code.
1: Push radio preset#1 until first digit of your code appears.
2: Push radio preset#2 until second digit of your code appears.
3: Push radio preset#3 until third digit of your code appears.
4: Push radio preset#4 until fourth digit of your code appears.
5: Push either tape or cd button.
What to do if your radio says OFF instead of CODE
(Courtesy of mittech)
If your radio says OFF it means you entered the wrong radio code three times. To get it to say CODE again do the following.
1:Turn the key to on or accessory.
2:Push the power button so that the radio display says OFF.
3:Let the car sit for 1 hour.
4:The radio display will go blank.
5:Turn the radio on and it will say CODE again.
Sep 04, 2009 | Infinity Reference 1211a Car Audio...
Preset Radio Statios
I just dug out the manual and have now programmed a preset.
Instructions:
1) Make sure there are a pair of working AA batteries behind the second (inside) compartment door as these power the memory (mine were Duracells with an expiry of 2001 and had worked all the way through to 2010 before finally failing!)
2) Find the frequency you want with the Up/Down button
3) Press the M button - you will get a flashing M on screen
4) While the M is flashing, press one of the numbered preset buttons.
Jun 23, 2009 | Audio Players & Recorders
I lost the user manual for my ICF-SW30 SONY radio.
tune to station you want preset; hold down Enter/Time button while you press the number you want the station to be on the keypad.
Nov 28, 2008 | Sony ICF-SW30 Radio
How to set the time????
Hold the "sel" button for 2 seconds, , "CLOCK H" comes up, then adjust with round silver knob. Use seek button if you need to change from CLOCK H to CLOCK M to change minutes.
Jan 09, 2008 | JVC Car Audio & Video
Sony DHC-MD333 Shelf System Logo
244 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
