Question about Kitchen Ranges
Kitchen Aid oven does not get up to temp.
We have a YKERC507HAI Kitchen Aid Convection self clean stove. This just started this week. We set the bake temp at 450 and after 50 mins, the temp is only 388. Cut the power to the stove twice, with same results. Using a digital Accu-Rite digital probe on center rack. I have read that there is a way to recalibrate, but do not know how.
    Sergeant:
    Champion:
  • 338 Answers
You can only calibrate the oven + or - 35 degrees. if you are over 35 degrees off you will need to ohm your temperature probe to see if you get about 1280 ohms if you do then you need to replace the clock control. if you ohm the temperature probe and you are off by more than 10% then you will need to replace the probe. in most cases both the control and probe would need to be replaced.
Posted on Feb 02, 2009
Have a very dirty oven will it catch on fire when i use the self cleaning setting
I would scrape and clean has much as you can,from the oven,then turn your self cleaning oven on.Make sure your fan is on above the stove.the oven pretty much bakes the grime off at a high temp take your racks out before turning your oven on..much bakes the grime off
Nov 05, 2011 | Hotpoint RB757 Electric Kitchen Range
I cannot turn top oven off from bake. How do I make it work?
have the same problem with kitchen aid stove. Set the cook duration for one minute - then open and closed door. Oven turned off.
Jul 31, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Oven wont unlock after self clean cycle
Make sure you're getting 220 to the stove, maybe one breaker is off or bad.
Apr 21, 2009 | Whirlpool GR460 Electric Kitchen Range
Err codeF2EO Stuck Key onContol panel touch pad
Hi have a nice day
F2 - E0 Oven temp too high
1. Test operation of door lock on self-clean
2. Test relay contact operation
3. High resistance in oven temperature sensor
Guruood Luck !!!!!!
Feb 16, 2008 | Kitchen Ranges
Oven wont work at all.
Convection oven and Bake will not heat past 200degrees. Broiler works fine and the range works fine.This is for the Model # MGR5875QDW, Gas Precision Touch Control 800, can you help. Thanks Kasz3
Dec 24, 2006 | Maytag MGR5875QD CleanDesign Gas Kitchen...
After self cleaning, Range trips circuit breaker when using convection
self cleaning ovens use super hot seting to bake the oven clean and it sounds like it melted a wire and it is shorting out the oven on that setting. look at the wires you can see or easy to remove panels
Dec 22, 2006 | GE Profile JGS968 Gas Kitchen Range
Kitchen Ranges Logo
280 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
