Question about HP Vs17 17" LCD Flat Panel Monitor
Hp vs17e monitor says it's in sleep mode then goes blank
The monitor comes on with the blue lightt on then has message "monitor is going to sleep and I cn't get it to wake up!
    President:
  • 2,559 Answers
If you are running Windows Vista,do the following,
  1. Click start,Control panel,
  2. Double click Power options,
  3. On the left menu bar,Click Change when the computer sleeps,Change "turn off the display" to never,
  4. Go down to the botton and select "Change advance power settings,
  5. Scroll down to Display and click the + symbol,
  6. Click the + symbol beside "Turn off display after" change to never,
  7. Click on the next plug + symbol beside Adaptive display and change to off (You may or may not have the adaptive setting)
  8. Click apply ,click ok,
  9. Restart your computer.
If you are running windows Xp
  1. Right click on an open area on the desktop
  2. Click properties
  3. click the screen saver tab
  4. Click the power button at the bottom
  5. Change the "Turn off monitor settings"To Never
  6. Retart computer
if this doesn't fix your problem,please let me know
Please rate this a fixya
Posted on Feb 02, 2009
Why does my HP vs17 monitor screen keep going to blank black screen like it turned off but did'nt.....blue power button light is still on? Everything is running but no picture.....keeps happening everytime...
this old monitor has 2 issues.
1: it has CCFL tubes that love to burn out (backlamps)
most this old are long go, yell,dim.,blinking or DEAD.
2: push the menu button on front of mon. turn off power saver.
3: if the PC goes to sleep, or hibernete mode (parked)
then that is 100% normal
if you dont like feature then go to windows control panel
click power, ICON and turn off all monitor sleep /hibernate modes.
that assumes windows, no OS stated.
if the lamps are dead,
use flash light pointed to sceen, see data. ? bingo for bad CCFT tubes.
as seen here
http://www.pcdied.com/monitors.html#flashlighttest
Jan 12, 2018 | HP Vs17 17" LCD Flat Panel Monitor
I've got a HP w1907v monitor and latly it has been going into sleep mode without warning while i'm using it. All my power saver settings are set to off.
If this monitor is going into sleep mode the normally blue power led will change to yellow. This indicates loss of video signal or possible out of range resolution. If the picture goes dark and the power lite stays blue, you have a backlight malfunction. It can be an inverter power fault but this model mostly has worn out backlights causing a shutdown condition.
Monitor Mike
Aug 18, 2010 | HP w1907 LCD Monitor
Computer powers up but monitor goes right to sleep?
when i power start my computer,,the light come on and seems to operate but the monitor doesn't come on,,,when switichin the monitor off and on , the blue light comes on and it reads monitor goin to sleep and the screen gets dark,,but the monitor orange light is on,,,pls help
Sep 21, 2009 | HP Pavilion MX70 17" CRT Monitor
Screen comes on briefly then blanks out.
check inverter, memory, and powersupply.
May 31, 2009 | HP w1907 LCD Monitor
HP vs17e My screen went black for a few moments and when it
Switch off and on your PC and hold down the F5 key and this should bring up your PC in Safe Mode. If this fails, then find a PC repair shop to replace the power supply.
Mar 22, 2009 | Computers & Internet
check the board postings for the HP f1903 monitor.I recall seeing a problem of the same there and a solution or fix. As it is only a newer version of the same model, it may be the same fix. Appears HP has a big problem with QA and this particular model. Lots of people have same or similar problems, and all appear to have a similar fix or solution. Tricky part... figuring out how to "Open" the monitor to check it inside!
Good Luck.
PS - if you figure out the opening part, let us all know!
Feb 02, 2009 | HP Pavilion F1703 17" LCD Monitor
Monitor in sleep mode
I think it maybe time to buy a new monitor
Aug 09, 2017 | X2Gen MG15VT 15" LCD Monitor
my computer is on but screen is black and has power. How can I fix it?
Aug 27, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Goes to sleep
Hi
Pls check the power option settings in control panel.
Also pls check if the power management options for keyboard and mouse in device manager are enabled or not.
Pls try to create a new profile and check if the sleep mode is working in the new profile.
Pls try a System restore if the above steps don't work.
Dec 24, 2007 | HP Vs17 17" LCD Flat Panel Monitor
Going to Sleep
got the same issue
hp pavilion 1723
Nov 01, 2007 | HP Pavilion F1903 19" Flat Panel LCD...
HP Vs17 17" LCD Flat Panel Monitor Logo
1,644 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
