Question about Maytag MER6772 Gemini Electric Kitchen Range
MER6770AAC getting F1L
Can you tell me if this is someting terrible or maybe something simple. Oven won't heat, and sometimes I get an error code in middle of night when nothing is on.
Thanks.
2 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave Oven Model MMV5207BA/BC
E13 is usually a bad door switch or door switch mount.
The first step is to unplug it from the power outlet for one minute, then plug it back in and try it again.
If it still fails to heat, I would check the door switches and door switch mounts.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
NOTE: There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 22, 2008
Oven won't heat
You might have to unplug it let it set for a hour then plug it back in and it might set it self.
Dec 31, 2012 | KitchenAid Kitchen Ranges
Oven won't heat up, but no error codes
I called the repairman for help. Turns out that one of the suggestions would have worked if I could go to basement turn off breaker then run up and carry out the suggestion and run to the basement again and turn back on breaker, then up again faster. The repairman was able to fix problem by using me as the go between the breaker and the oven. He stayed up and I stayed down thereby eliminating the problem of not being able to run up and down fast enough myself. The two of us were able to make things happen in the time limit. I think I should have gotten a break on the bill since I played helper!! If anyone else has this problem and has closer access to the breakers than I, they would be able to cut the repairman out of the picture and save the service fee. Maybe I should run up and down from oven to breakers for a set amount of time for exercise in preparation for the next oven problem. May be easier to get a new oven without a computer in it if such a thing exist anymore because at 77+ I don't think I am going to get much faster even with exercise.
Dec 19, 2012 | Maytag CWE5800A Electric Double Oven
Mer6772bas ovens won't work, bottom oven won't open
F1-4 is a lower oven runaway clean error F9-3 is a lower oven door latch failure. Must be a bad door latch causing the errors.
GEMINI FAULT CODES
Aug 30, 2012 | Maytag MER6772BAS Gemini Electric Kitchen...
F1L error No heat in either oven.
An F1 code indicates a problem with the touch pad or membrane. Replace the touch pad or membrane. F1 can also indicate an issue with the oven's on-board watchdog system, which requires replacing the touch pad or clock assembly.
Jun 29, 2011 | Ovens
Whirlpool electric oven not heating (has a functional stove top)
Hello Daniellel583! We are terribly sorry to hear of your concern with your Whirlpool Range. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, reviewer name (Daniellel583), phone number, street address, zip code, model & serial number, and date of purchase on the appliance. We would be happy to assist you. We look forward to your reply.
Jun 18, 2017 | Whirlpool RF111PXS Electric Range
F3-error. Kenmore classic oven Heating element will not go pass 100 deg. Heating element recently replaced. Broiler is also malfunctioning
Hello there:
Whenever you get the dreaded f-3 code this is the code that tells you that the temperature sensor is going bad or already has gone bad and needs to be replaced immediatly. It should look something like this and cost about 50 dollars
Jun 20, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Recently the light flickers and gets dimmer, then back to normal, several times while heating something in the oven Just wondered if this is some simple thing to take care of, or should we consider...
Sounds like an arcing switch or connection, or maybe the light itself is not making a good connection. Check the plug in the outlet socket to see if it gets hot after heating something. Wiggle the cord to see if the light flickers. The door switch is a microswitch type and should make a positive 'click' when operated.
Feb 05, 2010 | Microwave Ovens
Samsung SMH 8165 ST E13 Error message. Oven
I own the same Microwave and it just gave me the same error code E-13. I was heating a large plastic coffee mug of cold water using the "beverage" control. The only thing out of the ordinary was I used very cold water from the Fridge. Maybe this had something to do with the Max time error. Hopefully this was a one off error.
Jun 24, 2009 | Samsung Microwave Ovens
My thermador oven tells me error code 14
Sometimes you can unplug the unit for at least 30 minutes and reset the unit and it wont do it again.Try that first. An error code on a thermador of 14 means latch switch problems.
May 12, 2009 | Thermador SMW272 Electric Double Oven
F2 and F3 code appearing along with annoying beeping
i think f3 error code has something to do with the temp probe maybe it is the problem. the temp probe is located if you open the door directly in the back wall. it looks like a prong. should read 1100ohms the f2 error code though usually has something to do with the keypad i would check all the connections maybe they are loose.
Jan 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Maytag MER6772 Gemini Electric Kitchen Range Logo
35 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
