I have a kenmore elite front load washer that only does 2-3 loads of laundry, then quites doing the spin cycle. How do I fix this??
  • 15,935 Answers
It appears your motor/motor controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
Front-loading washer Kenmore HE2 plus - spinning not ...
www.shopyourway.com > Manage My Life > Questions
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
Front Load Washer Won't Drain or Spin Video: Washing ...
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
www.kenmore.com > Laundry > Washers > Front-load Washers
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
Jan 15, 2016 | Kenmore Washing Machines
Kenmore elite washer leaks water in spin cycle
You need to replace your pump. Make sure you have the washer either on something that will absorb water, or fix it outside/garage. Because these pumps hold extra water and that is why it is not recommended to keep them outside to do laundry in colder climates. The water can freeze in the pump and wreck it. Good luck. They actually are pretty easy to replace.
Apr 26, 2009 | Kenmore Washing Machines
Kenmore Elite HE3 has power but not starting wash.
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN & SPIN if there is excessive water in the washer.
Re-select cycle and press START. If the problem remains, call
for service.
Dec 16, 2008 | Kenmore Elite 45986 Front Load Washer
Makes a very loud noise on spin cycle. Seems to worsen with larger loads.
sounds like a rear bearing gone bad , not exaectly a doit yourselfer. pretty costly as well id call sears, for possible part warr. and how much theyd charge to replace the rear bearing?
Oct 31, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Front Load 3.5 cu ft Washing Machine, NO SPIN CYCLE
is it in a diagnostic mode? unplug from wall for 15 sec or so and try again.
May 15, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4t Washer - "Control Locked"
I had the same problem. If you will hold the "Drain & Spin button" in for approximately 4 to 5 seconds it unlocks the " Control Locked" issue.
Dec 18, 2007 | Kenmore Elite 45986 Front Load Washer
F-H code and beeping noise
error code which is serial communication error with motor contrl.
replaced M.Contl.brd but still have error.
Dec 03, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4T Front Load Washer
These machines have a filter you should clean depending on your usage. It is usually at the front bottom - a small door. This is a filter before the water gets to your outlet pump to be siphoned out; it is there in order not to clog up your pump.
Jun 12, 2007 | Kenmore 44072 Front Load Washer
Kenmore elite front load washer
look for an error code on those washer it will be and f-02 something like that or HF FH it will have an f keep an eye out for that
Mar 19, 2007 | Kenmore Elite 45986 Front Load Washer
My washer doesn't open...
The instruction manual suggests running the "drain & spin" cycle, because there is most likely water left in the machine.
Dec 15, 2006 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
