Question about Toshiba Satellite A105 Notebook
How do you install ram in a toshiba a105-s4344 laptop
I have new ram and need` help in right direction
  • 596 Answers
I take it that you already have the correct RAM you need. Wiith that, power off your notebook, unplug it, turn it over and your will see the larg cover closer to the right of the notebook. Unscrew the screw to release the memory cover and place it to the side. Be carefull with static when handling your memory card, install the card into any open slot in your notebook. (The memory card will go in the slot at a 40 degree angle and then 'snap' down into place. Replace the memory cover (the large piece you took off at the begininig.) power up you notebook and the new memory should be registered and ready for use. Good Luck.
Posted on Feb 02, 2009
I dont have a restore cd
You can download all the drivers you need here>
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp#
Jul 07, 2009 | Toshiba Satellite A105-S4344 Notebook
My toshiba a105-s4344 has a line threw the screen where the top is darker than the bottom by alil bit and when the screen moves around the screen flashes and goes nuts what do u think the problem is the...
The problem with Lcd screen is that if you see line through them there are three possibiltys 1Your cable connection from the laptop to the screen is loose 2 the inverter is failing which mostlikly you will see backlite flashs and then blank screen or pixcels seem to get lost and return 3 bad screen pixcel lost in hole sections or line or lines than a total lost of screen chech all the connections first .connect a monitor to the laptop and see if you have the same problem if so it may be the video card on the board
Mar 25, 2009 | Toshiba Satellite A105-S4344 Notebook
Toshiba satellite laptop A105-S4344 graphic card
you should be able to change your graphic
( maybe just not showing )
but first I would check my device manager and see if your
expansion pack shows in there if so update driver
and when you installed the graphic did you do it using control panel add new hardware
Jan 21, 2009 | Computers & Internet
DVD broken - How to replace it
I found this on the toshiba website http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=ex&bbid=bb35&url=&dialogID=45113241&stateId=0%200%2045111928
Basically it says 'If the internal CD or DVD drive is removable, it's usually secured in place by a locking switch and a separate eject switch / lever on the bottom or side of the computer.'
I couldn't find a decent manual with pictures, hopefully this helps
Lee
Jun 25, 2008 | Toshiba Satellite A105 Notebook
Toshiba Satellite A105 Notebook Logo
51 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
