Question about HP LaserJet 2840 All-In-One Printer
Connecting problems When trying to send or receive faxes, it will call or receive from a # but thats it, it will not connect
  • john slater Feb 11, 2009
    As far as I am aware, it receives ok. But when trying to send a fax, it comes back with no answer, even though the fax machine is okay at the other end. Go to another fax machine after trying many times on mine and it works first time. AAARRGH!!!! It is very close to going through a window!!!
  • HP Master
  • 1,113 Answers
Is it set to auto receive, is the tel line plug into socket marked line not tel. Is it used on a dedicated line, no extensions, if using ADSL you must have filter on line. If plugging standard phone in place of fax is dial tone heard and line is noise free, can you ring and speak fine on line using a phone. Is machine set to correct dial format for your country ie pulse or tone. When did it stop, have you had storms, phone work done, has it worked on this line before? I take it it copys ok is that correct.
My bet is A noisy phone line or B set to manual answer. More info equels better help, but I am short of free time now..
Posted on Feb 03, 2009
No dial tone on handset. can't send or recieve fax.
? Other equipment, which uses the same phone line as the HP All-in-One,
might be causing the test to fail. To find out if other equipment is causing a
problem, disconnect everything from the phone line, and then run the test
again. If the Dial Tone Detection Test passes without the other equipment,
then one or more pieces of the equipment is causing problems; try adding
them back one at a time and rerunning the test each time, until you identify
which piece of equipment is causing the problem.
? Try connecting a working phone and phone cord to the telephone wall jack
that you are using for the HP All-in-One and check for a dial tone. If you do
not hear a dial tone, contact your telephone company and have them check
the line.
? Make sure you have correctly connected the HP All-in-One to the telephone
wall jack. Using the phone cord supplied in the box with the HP All-in-One,
connect one end to your telephone wall jack, then connect the other end to
the port labeled 1-LINE on the back of the HP All-in-One.
If the supplied phone cord is not long enough, you can extend it. For
information, see The phone cord that came with my HP All-in-One is not long
enough.
Check the connection between the telephone wall jack and the HP All-in-One
to make sure the phone cord is secure.
Make sure you use the phone cord that came with the HP All-in-One. If you
do not use the supplied phone cord to connect from the telephone wall jack
to the HP All-in-One, you might not be able to send or receive faxes. After
you plug in the phone cord that came with the HP All-in-One, run the fax test
again.
If you are using a phone splitter, this can cause faxing problems. (A splitter is
a two-cord connector that plugs into a telephone wall jack.) Try removing the
splitter and connecting the HP All-in-One directly to the telephone wall jack.
If your telephone system is not using a standard dial tone, such as some
PBX systems, this might cause the test to fail. This will not cause a problem
sending or receiving faxes. Try sending or receiving a test fax.
Check to make sure the country/region setting is set appropriately for your
country/region. If the country/region setting is not set or is set incorrectly, the
test might fail and you might have problems sending and receiving faxes.
Make sure you connect the HP All-in-One to an analog phone line or you will
not be able to send or receive faxes. To check if your phone line is digital,
connect a regular analog phone to the line and listen for a dial tone. If you do
not hear a normal sounding dial tone, it might be a phone line set up for
digital phones. Connect the HP All-in-One to an analog phone line and try
sending or receiving a fax.
again.
After you resolve any problems found, run the fax test again to make sure it
passes and the HP All-in-One is ready for faxing. If the Dial Tone Detection test
continues to fail, contact your telephone company and have them check the
phone line.
Dec 03, 2010 | HP Laserjet M1319F Laser Multifunction...
HOW TO EMAIL SCANNED DOCUMENTS FROM HP J4580 DIRECTLY?
It is not possible to email the scanned file directly through the printer. However, you may send fax over the Internet
You may subscribe to a low cost phone service that allows you to send and receive faxes with your device by using the Internet. This method is called Fax over Internet Protocol (FoIP). You probably use a FoIP service (provided by your telephone company) if you:
• Dial a special access code along with the fax number, or
• Have an IP converter box that connects to the Internet and provides analog phone ports for the fax connection.
NOTE: You can only send and receive faxes by connecting a phone cord to the port labeled "1-LINE" on the device. This means that your connection to the Internet must be done either through a converter box (which supplies regular analog phone jacks for fax connections) or your telephone company.
Some Internet faxing services do not work properly when the device is sending and receiving faxes at high speed (33600bps). If you experience problems sending and receiving faxes while using an Internet fax service, use a slower fax speed. You can do this by changing the Fax Speed setting from High (the default) to Medium. For information on changing this setting, see Set the fax speed. If you have questions about internet faxing, contact your internet faxing services
support department.
(Ref from the manual of the printer.)
Hope this helps.
Jan 23, 2010 | HP OfficeJet J4580 All-In-One Laser...
Can dial out and receive incoming calls but will
Are you connected to a VOIP line for your fax?
A VOIP line can come from a company like Vonage or your local cable co.
If so:
Unfortunatly, faxing over VOIP (Internet) is not always successful. You might want to talk to your VOIP provider if they have a solution.
If not:
Are you trying with the same fax to send and recieve? Some traditional fax machines have probles connecting to fax modems, which is what you have in an Office Jet.
Try having someone else send you a fax and try sending to another number. Otherwise, you might have a defective fax modem.
Nov 07, 2009 | HP Officejet 7210 All-In-One InkJet...
Error 441 seems to take all pages but receiver get aapx. 1 paragraph & the rest is blurred - same incoming
This means that an error occurred during transmission after one or more partial pages were sent. The sending machine was unable to restart the control channel connection(handshake) before sending more data. This error typically occurs when the receiving fax disconnects after receiving part of a page. It can also be caused if the receiving fax is using a fax format incompatible with the HP fax (usually during color faxing) or the line speed drops to an unacceptable level.
Solutions
Check that the phone cord is plugged in correctly and is not cut, creased or damaged.
Make sure that the phone connection terminal box is not damaged and that the cable connecting to it is not damaged.
Try the fax at a different time when telephone line conditions have improved.
Oct 08, 2009 | HP OfficeJet d145 InkJet Printer
Cannot receive faxes
What is the make and model?
Call the fax machine from a regular phone to see if it answers.
I think you have some sort of phone line problem.
Fax machine modems are good or bad, nothing in-between.
Mar 13, 2009 | Office Equipment & Supplies
Our Epson Sylus CX9400Fax Series is not receiving or sending faxes. We have already done the phone call to India thing for 90 minutes. All settings were changed and tested. They are now back to factory...
Ok, here's a check list for you.
SENDING
Check the following:
  • Make sure the phone cable is connected correctly and verify that the phone line works by connecting a phone to it.
  • Make sure that your recipient's fax machine is turned on and working.
  • If you connected the Epson Stylus CX to a DSL phone line, you must install a DSL filter to the line or you won't be able to fax. Contact your DSL provider for the necessary filter.
  • If your phone line has static or other noise problems, turn off the ECM (Error Correction Mode) setting and try faxing again.
    Follow these steps to turn off the ECM setting:
    1. Press Setup.
    2. Select Fax Settings, then press OK. You see this screen:
    4. Select Communication, then press OK.
    5. Press cp_button_44_er.gif and select ECM. Then press cp_button_42_er.gif and set it to Off.
    6. Press OK.
RECEIVING
Try the following if you can't receive a fax:
  • To receive faxes automatically, make sure the Auto Answer light is turned on. To turn it on, press the Auto Answer/Space button.
  • Make sure paper is loaded.
    1. Press Setup.
    4. Select Communication then press OK.
    6. Press OK.
Mar 03, 2009 | Epson Stylus CX9400 Photo Printer
Sending and receiving faxes
Do you have an analog phone line or are you trying to run it through a PBX system? I was just having this discussion with RKS tech support. Their fax software was hanging up as soon as the connection was established and all I had available was a VOIP phone line. It took 4 tries but I found a US Robotics fax/modem that worked fine in class 2.0 mode.
Nov 10, 2007 | OKIFAX 5650 Plain Paper LED Fax
Fax was set for two line use, now is using only one - how do we change the settings?
This is an older discontiued model as I can recall. Simply just plug the phone line into L1 and leave L2 unconnected. The one that can send will also automatically recieve (L1). L2 settings are prohibit TX and send/ recieve.
Aug 08, 2007 | Canon LaserClass 9000L Plain Paper Fax
HP LaserJet 2840 All-In-One Printer Logo
74 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
