Question about Philips Magnavox 51MP392H Rear Projection Television
Everything works except picture
I have a rear projection philips. everything works volume, on/off, channels, AV, remote, etc. except the picture wont show. This happened allof a sudden. i know it generally means that the picture tube might be bad but it feels like something else. the TV is approx 2 yrs old.
  • Anonymous Feb 17, 2009
    have the same problem no pic but sound and everything else works fine
  • Philips Master
  • 8,617 Answers
Most probable cause is the vertical output IC. You can get a replacenment at the following link.
http://servicemanuals.vstore.ca/
Posted on Feb 02, 2009
Touched a button on remote now no picture or sound Help
find the input or av button on the remote and press it till you get a picture. i thing this tv remote has av button at bottum of channel numbers.
Mar 26, 2010 | Philips 50P8341 50" Rear Projection...
Volume lock of philips vardan tv
I hv philips 21RF vardaan TV ,there is sound on AV channel. and the picture is blinking. even some menu setting have changed.. i tried using the service menu but cudnt understand anything. 2 new av channels have come.. av2 and front which were not present before. sound is not coming even on the other channels but picture is fine on them. only on the av1 channel it is blinking., the philips technision had solved this prob once by pressing some code by remote and i don't know the system code
Sep 10, 2009 | Philips 20DV6942 20 in. TV/DVD Combo
60" philips projection - no picture
check to see if your collor wheel is rotating and the buld didnt blow.
Sep 03, 2009 | Philips 43P8341 43" Rear Projection...
How do I replace the Vertical Output IC
Replace the Small Signal Board Part #313912725871
This is a common problem withis TV.
Jul 30, 2009 | Philips 50P8341 50" Rear Projection...
Hitachi volume bar always on, remote doesn't work
you can start by opening the front panel and check if the control board (with channel ,volume ) is correctly fixed or need to be solded.
the service manual is here in 6 parts and for free...:
http://www.eserviceinfo.com/downloadsm/31328/Hitachi_43FDX10B.html
cheers
Dec 21, 2008 | Hitachi FDX Series 43FDX10B 43" Rear...
No av-input picture with sound
Goto the site www.TvRepairKits.com and get their "chirping" TV repair kit. It will fix the problem of the dead set with high pitch sound or chirping sound.
Sep 25, 2008 | Philips 60PP9363 60" Rear Projection...
Phillips projection no picture
It sounds like you hit the AV button. Try hitting it again until you see a picture.
Dec 24, 2007 | Philips Magnavox 51MP392H Rear Projection...
Sound but no picture
You say AV4, is this the HD part? And if so, then have you checked the video board area?
Sep 12, 2007 | Philips 60PP9202 60" Rear Projection...
Menu will not display
If the channel and volume visual display was not set up on the menu to display on screen , neither will show up even if either the remote or set front button are used. Make sure that the tv button is selected on the remote to access the menu .If that does not work ,then either the batteries are dead or the remote is dead.If it is you will need a new remote,sadly. Then you can press the m button , select sound and then select "display volume" and check "during adjustment". The channel display settings are found on "features" from the main menu. Hope this helps.
May 30, 2007 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 51MP392H Rear Projection Television Logo
64 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
