More often than not when BBC Iplayer is selected it starts saying "Loading" then Hangs. Also have a 32 inch model of this TV and never have the same problem on that. Am fed up with this problem and believe the TV is faulty, been reporting it almsot every other week to my supplier since purchasing TVs a couple of months ago!
SOURCE: Problems with Loading into project
Install update 1.504 should fix the problem, i had to load it twice...
SOURCE: trying to reinstall vista; it goes about 75% then hangs
if you are reinstalling from a dvd...its just probably having trouble in reading the files from the disc...try another disc...and also ..try to format the C partition before loading files...it might recognize some old files...and misguide itself..
SOURCE: wmi error comes and vista hangs
Event filter with query "SELECT * FROM __InstanceModificationEvent
WITHIN 60 WHERE TargetInstance ISA "Win32_Processor" AND
TargetInstance.LoadPercentage > 99" could not be reactivated in
namespace "//./root/CIMV2" because of error 0x80041003. Events cannot
be delivered through this filter until the problem is corrected.
Boot into safe mode. First, open services and stop the Windows Management Instrumentation Service.
Take ownership of the folder or the contents of the folder
"C:\Windows\System32\wbem\Repository." I've done this three times now
on different installs and didn't have any issues after doing this, but
I suggest you back up the folder to be certain. Delete the contents of
the folder. Reboot. When you boot into Vista, you might notice a half dozen or so application errors...it's OK.
Reboot again, and Event ID 10 will be gone, along with the afore mentioned application errors.
Good luck, I'm not responsible for you hosing your system, & all that.
SOURCE: My n5 hangs while loading
I've come across this before when the card has been too full or there has been a corrupt game on the card
SOURCE: KDL 32S5500 TV When left on standby overnight locks-up, hangs.
There is a Post on the Sony Support site which I hadn't previously found. Basically there is a software bug which has come about apparently due to Freeview transmission changes. In order to stop the the machine locking up disable the 'Automatic System Update' option. A Sony centre will apparently apply a software fix to properly resolve the issue, fine if with warranty period, maybe pricey if not. I will get the fix but haven't yet done so as the workaround of disabling the System Update option works.
