Question about IBM ThinkPad R50e Notebook
Just received a used IBM laptop - it will not see 3 different HD i tried putting an OS on??
  • 1 more comment
  • CyborgCop May 11, 2010
    How are they connected to the computer?
  • Randy Hough
    Randy Hough May 11, 2010
    You can't put an OS on the hard drive if it couldn't see it.
    If you used another computer to install the OS,It's not going to work either.
  • Kim Tyler May 11, 2010
    what model laptop, how old??
    What size are the Hard drives?
    Does it see/recognise them in the Bios??
  • 404 Answers
You need to disable RAID from bios
then try it, check if the hard drives work elsewhere
Posted on Mar 02, 2009
Adding a hdd
You can only install one hard drive for this system, if you want to upgrade the capacity or storage you can purchased hihger specs of hard drive and use OEM version or liecense verison of OS to he system and the respecting drivers for your computer from IBM websites.
Jul 18, 2010 | IBM ThinkPad R40 2723 Notebook
Adding A HD TO R40e
You will not really get a GUI for selecting the OS, but if you bring up the boot menu dialog while the computer is booting (before the OS starts loading) then you should be able to select the secondary internal drive (be sure this HD bay is enabled in the BIOS).
You WILL NOT be able to boot from this drive correctly if it was installed on a different computer - the drivers needed will be different from the drivers already installed with your OS on this drive.
You may be able to boot Windows 7 with your IBM, however it will be extremely slow with only 768Mb of RAM. The minimum requirement as given by Microsoft is 1.00GB, and I wouldn't personally make the upgrade without 2.00GB of RAM. If you really want to run Windows 7, I would upgrade your RAM before adding in the additional HD.
I hope this helps, please rate my solution!
Jul 17, 2010 | IBM ThinkPad R40 Notebook
Replaced HD and CD Rom drive, PC will not boot to disk, Do I need to format HD 1st. before loading OS?
Hi Get to the bios screen using F8 or F9, change the first boot device to CD ROM/DVD, then insert a bootable disk into the CD drive and try installing the OS first by completely formatting the HD during installation Win XP and higher OS editions give you the option to partition the HDD Hope this resolves
Nov 05, 2009 | IBM ThinkCentre S50 8183 - P4 3 GHz...
IBM Think Pad TDD
reinstall the OS, but first back up you files. you can remove the HDD located at the bottom of the Laptop. buy a cheap 2.5 inch usb to ide/sata enclosure and place your hdd on it. use a PC to transfer your files. then format the HDD. reinstall the HDD to your laptop and install the OS.
Jul 06, 2009 | IBM ThinkPad T22 2647 Notebook
BIOS self-set Password after upgrade/HD Install
try this if you can do  but i am not sure.  i am good on electronic things but its hard to do that. its only way.
May 28, 2009 | IBM ThinkPad T43 Notebook
Ntldr error on ibm intellistation z pro w/ xp pro
During the XP install, you will be given the chance to set up partitions on the drive. Blow them all out. Completely. Then recreate the partition and let XP install. I expect this will solve the nt loader issue. If, however, it does not, then use the recovery approach below to get the required loader files onto your boot partition.
  1. Insert the Windows XP bootable CD into the computer.
  2. When prompted to press any key to boot from the CD, press any key.
  3. Once in the Windows XP setup menu press the "R" key to repair Windows.
  4. Log into your Windows installation by pressing the "1" key and pressing enter.
  5. You will then be prompted for your administrator password, enter that password.
  6. Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "d." This letter may be different on your computer.
    copy d:\i386\ntldr c:\
    copy d:\i386\ c:\
  7. Once both of these files have been successfully copied, remove the CD from the computer and reboot.
Mar 04, 2009 | IBM IntelliStation Z Pro 6221 PC Desktop
Could you be more specific as to the "problem" as there are many reasons that could cause problems. Any error messages or anything and also what os are you trying to install
May 16, 2008 | IBM NetVista PC Desktop
If your old copy of win xp is not being used by any other computer then reformat the entire drive with xp. Also make sure that your drive is not divided into 2 or 3 sections. All updated will be available on the windows update site. The reason that I prefer tostart from scratch is Everything is new with no lingering Junk programs in the background. Need help email me at
Apr 13, 2008 | IBM Netvista Intel Pentium 4 2.4GHz /...
IBM starting problem.
Hi , if your dont have any data, try to get the IBM Netfinity CD for 4000r which supporting the OS 2003. Usually IBM provide a cd on each NEtfinity server. Check on the IBM website for more details about your Server Compatibility on 2003 server. then proceed to re-intalled the OS.
Aug 10, 2007 | IBM Netfinity 4000R 8652 Server
IBM ThinkPad R50e Notebook Logo
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
