Question about ASUS P4B533-VM Motherboard
During last bootup, your system hung for improper frequency combination. Your system is now working in safe mode. To optimize system performance & reliability, make sure the frequency combination conforms to the specs of your CPU, DIMM, or other connected devices.
  • 36 Answers
This is only a warning of computer bios., this usually happens if you overclock, or a power failure during POST of bios.. Just press the Restore/Default Setttings.. I think its F2 in some boards, itwill just reset the settings, it should be fine
Posted on Feb 03, 2009
I am running in safe mode, I computer will only let me go back one day, this problen started ten days ago.
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your computer and operating system Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart.
if this fails to fix the problem During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer you could select the option start at last known configuration that worked this will tell what file has been corrupted or missing you might be able to work your way through problem if you are unable to find a solution restart back into safe mode you might need to select your operating system to load into safe mode To perform a system restore, follow these steps: 1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue. If you need more help with this post a reply
Hope this helps.
Jan 19, 2013 | Microsoft Windows XP Home Edition
I tried normal but it didn't work so I tried safe mode and it din't work The mouse icon stays there then the computer goes off then I click the mouse and it goes back on but the login screen never pop
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your computer and operating system Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart. Hope this helps. if this fails to fix the problem During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer you could select the option start at last known configuration that worked this will tell what file has been corrupted or missing you might be able to work your way through problem if you are unable to find a solution restart back into safe mode you might need to select your operating system to load into safe mode To perform a system restore, follow these steps: 1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue. Hope this helps.
Jan 15, 2013 | Computers & Internet
How do I reset the laptop with out the disk?
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your computer and operating system Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart. if this fails to fix the problem During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer you could select the option start at last known configuration that worked this will tell what file has been corrupted or missing you might be able to work your way through problem if you are unable to find a solution restart back into safe mode you might need to select your operating system to load into safe mode To perform a system restore, follow these steps: 1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue. Hope this helps.
Jan 02, 2013 | Computers & Internet
I have a Compaq Presario f700 running Windows 7 64bit. It freezes up at bootup, unless at the Compaq screen I press the [DEL] button to view the start-up sequence message. Why? How can I fix it?
click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell you what has occurred and the time it occurred
you might use the system restore to restore your system to an earlier time
click start all programs accessories system tools you should see your system restore option
hope this helps
May 17, 2012 | Compaq Computers & Internet
When the laptop is switched on it goes to the page with start windows normally. when i select it, it goes to the starting page of window xp and then restarts again.
I would suspect damage to the file system and possibly something wrong with your hard drive. Windows loads a number of system files during bootup, and when it cannot find or read these files, it will cause Windows to repeat the process and cause the bootup loop that you are having.
First thing, backup all your data if possible. Second, you can try pressing F8 when booting the computer to access the "safe mode" boot menu. Once in the "safe mode" boot menu, select the option "Last good configuration", and see if the computer boots up.
There are more complicated methods if that does not work, but its the first thing I would try.
Mar 02, 2011 | Compal EL81 Notebook
My acer aspire 3000 turns on then while loading for less than a min and then turns off any ideas? I have the technical information here: *** STOP: 0X0000009C (0X000000004, 0X00000000, 0XB2000000,...
Hi, you can perform a system repair, by inserting your operating CD then booting and selecting this option.
Or you can start up in safe mode, by pressing the ESC key during bootup and selecting start in safe mode, from here you can roll back your system to a time before the problem started.
Hope this helps
Jul 25, 2010 | Acer Aspire 3000 Notebook
How do you do system recovery on acer aspire 3100
Hi, try pressing the ESC or Del key during bootup and select start in safe mode, from here you can reset your operating system to a another time. Or insert your operating CD and perform a system recovery from there.
Hope this helps
Jul 21, 2010 | Acer Aspire 3100-1405 Notebook
Dell 1150 laptop configuration module problem
Hi, you can perform a system restore by accessing safe mode by pressing the ESC button during bootup. Restore system to a time before the problem began. You will need to perform a full virus scan straight after normal bootup is achieved. Hope this helps
Jul 15, 2010 | Dell Inspiron 1150 Notebook
Acer 110 boot problems
This could majorly happen because of sp3 conflict with one of your hardware drivers
log in into safe mode and rollback the last software or hardware driver update
Jan 01, 2010 | Acer Aspire One Netbook 8.9" Notebook
ASUS P4B533-VM Motherboard Logo
365 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
