Question about Garden
Homelite saw runs wide open(homelite ut10520)
Saw started running wide open..filter was a little dirty,now clean..same problem,got owner manuel out keep backing off idle screw..no difference. checked gas cable in handle. has a lot of play.dont know if lose from carb also dont know how to put the gas cable back to the trigger. I think I know where it goes but how it stays
  • papawgeorge Feb 12, 2009
    will not let me into link...expired
  • njl16374 Mar 04, 2009
    I had the same problem returned it to Home depot where it was bought 3 times it still happened so then gave me a new chainsaw it is in the deals
There is a recall on the UT models, all you have to do is call the costumer service center for homelite. they will give you a number for the closest warrenty center that will adjust you throttle cable free of charge. I went through two UT 10520's before i started researching the problem.
Posted on Mar 17, 2009
I had the same problem 2 weeks ago. I figured out that the way the cable is engineered, it is holding the throttle open. I actually found that if I pushed down with my knee on the hande and wiggled it, While spraying WD-40 in the cable. Eventually it freed up, and started working right. This saw was assembled in China, and is a prime example of why we should not allow stuff to be made there. The quality is very bad. I have an old 16" XL that still starts better than my new UT10520. I bought the new one because I liked the old one so much. That will teach me. Now I am having a problem with starting it at all, and the manual says "Contact an authorized service center for carburetor adjustment." I should have paid more money and bought a Sthil.
Posted on Mar 04, 2009
I had the same problem. I had to shorten the cable sleeve and it works great. Now all I have to do is find the stock adjustments for the high and low on the carberator. Had to cut slots into the adjusment screws.
Posted on Sep 09, 2013
    Problem Solver:
  • 6 Answers
Homelite UT10520 Chainsaw runs wide open. It is not in the throttle. The carburetor is clean as a pin and there are no leaks. It must be in the electronic timing module. I just do not know how it is timed.
Posted on Apr 05, 2011
Same problem-fixed by opening handle and engine cover, getting access to both ends of throttle cable and spraying motorcycle cable-lube into cable body. After some new adjustments to throttle speed screw, it runs like it should from Homelite. Never buy Homelite again.
Posted on Oct 01, 2009
  • 211 Answers
  • Savu Mihai Feb 13, 2009
    Hi
    Start on google with "husqvarna chainsaws parts and diagrams"
    best regards savumihai71
Need owner or service or both manuals for Homelite model #UT10516
Robert:
As far as the manuals... you might be able to download them at http://www.homelite.com. (you can click on the link) under customer service, you'll find "owner's manuals). To adjust the fuel/air mixture, start the saw and turn the adjustment screws in or out a little at a time until you get the saw running properly. There is no "set" adjustment... as the saw motor ages, those settings will change. If you make adjustments to the fuel/air screws and the saw stops running and starting, turn the adjustment screws all the way in (clockwise) GENTLY... If you force those screws you will damage the needle valve seats! Turn both screws out one and a quarter turns out, and the saw will start. continue adjusting until the saw runs properly. Have patience... it may take a while to get the saw running to your satisfaction.
Jan 18, 2013 | Homelite Garden
Need gas/oil mix for Homelite 330 10604A, HJ
To the best of my recollection the 330 is an older model saw and should be running about a 16:1 ratio. 8oz. of oil to 1 gallon of fuel. Hope this helps.
Note: You're always better being a bit richer (lower ratio) than you are leaner (higher ratio).
Feb 20, 2011 | Homelite Gas, 20 In. Bar, 46 CC, Chain...
My homelite chainsaw model# ut10520 has aoil leak from the flexible line at the base of the oil tank.
I input your model number and found 3 possible matches, "42cc/46cc Chain Saw UT-10520; SUPER 2 Chain Saw UT-10520 or SUPER 2 Chain Saw UT-10520-A".
I opened the first "Ref # 3" on "Figure A" I suspect is what you say is leaking. It is very inexpensive and available. I would order one and inspect it once recieved to determine an installation method. It does not appear overly difficult without the part in hand. Good Luck.
Homelite/Ryobi.com (authorized parts supplier)
https://www.gardnerinc.com/recons/disclaimer-lg.php - Agree; Choose “Product Line”; “Select OEM” & “Select Catalog” both to “Homelite Consumer Products”. A drop down list appears; self explanatory from here.
The numbers Homelite & Ryobi use do not match the numbers everyone posts. A careful inspection of your saw should find something that matches.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 07, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
GETTING MY HOMELITE 150 STARTED.
Hello Vic;
Start with “L” & “H” needle valves 1.5 CCW from lightly seated, then adjust for performance as follows.
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
  • CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
  • Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
  • Clean the spark arrestor and muffler; if the saw cannot exhale it cannot inhale.
  • There are 2 wav (sound - idle & full - may not be highlighted) files that I find most helpful, I think you will too.
I am going to inject a little philosophy here. Undetected air leaks and defective fuel delivery systems account for most chainsaw failures. Constant adjustment of needle valves can easily camouflage more serious problems that result in burning up your saw. A sudden need for an adjustment may be indicative of a larger problem.
I searched for an OM with no good luck. Please contact them here:
Homelite.com (Contact Us)
https://register.homelite.com/contact_us/new
Ask they create an on line location where OMs can be found and down loaded please.
Lou
Apr 29, 2010 | Homelite ZR10926 16 Chain Saw
How to adjust high and low settings on carb for a homelite chains
Me know how! Want know who?
I would start with both the "H" and "L" needle valves at 1.5 turns CCW from lightly seated then adjust for performance as follows:
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 17, 2010 | Homelite ZR10926 16" Chain Saw
Homelite timberman only runs wide open
im no pro but id start with the throttle stop adjustment and the low speed jet.
screw low jet in, till its fully seated, do not force it. then back it out 1 and 1 / 8 turns. this should get it running and ideling.
Feb 28, 2010 | Garden
Does anyone know the carb. setting for a Homelite 45cc chainsaw. Or set up procedure??
Start 1.5 CCW from lighty seated then do as the link suggests.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too.
Dec 28, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Where is the air filter on a homelite super2?
If you remove the top plastic cover on top of the saw, you will find the air filter under that cover.
Jul 05, 2009 | Homelite ZR10926 16 Chain Saw
I have a homelite chain saw that the bar oil is not dispenseing
May be oil port on saw clogged. Remove side cover, remove bar and chain. Remove giude plate if equipped. Check to see if small oil hole on saw is open and clean. You can start the saw with side cover removed to see if oil is coming from oil hole or not. If it is coming from oil hole when running the problem is most likely dirty bar .If bar is dirty check to see that groove is clean and the oil hole along the edge of bar is clean also. The hole is at same end of bar that attaches to saw.
May 08, 2009 | Homelite Garden
Garden Logo
1,413 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
