Question about Canon PIXMA MP150 All-In-One InkJet Printer
Problem on a canon 3100
E000020-01a9 error code on a canon 3100
  • 565 Answers
The Power Light Flashes Orange - Error Codes When an error occurs, the power light flashes orange. The number of orange flashes followed by a long green flash indicates the cause of the problem.
Two orange flashes: Out of paper, paper jam, or paper feed error
If no paper is loaded in the auto sheet feeder, or if the paper is not loaded correctly, set the paper correctly and press the Resume button on the printer to continue printing.
Three orange flashes: Paper jam
If paper has jammed in the printer, carefully remove the jam and press the Resume button to continue printing.
Four orange flashes: A tank inside the BJ cartridge (print head) is out of ink
Replace the empty BJ tank and press the Resume button to continue printing.
Five orange flashes: BJ cartridge is not installed properly
Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely.
Six orange flashes: BJ cartridge (printhead) is not installed
Seven orange flashes: BJ cartridge (printhead) is defective
Remove the BJ cartridge and check that the contacts on the cartridge and cartridge holder are clean. Make sure the orange protective cap and tape have been removed and reinstall the cartridge. If the error occurs again after you resume operation, you may need to replace the BJ cartridge.
Eight orange flashes: Waste ink absorber almost full
The printer has a built-in waste ink absorber to hold the ink that is consumed during print head cleaning. This error indicates that the waste ink absorber is nearly full. Press the Resume button to skip the error so you can continue printing.
The POWER light flashes orange and green alternately: Service error
A service error means the printer requires the attention of a qualified technician. Count the number of flashes. (You may be asked this information.)
Posted on Feb 02, 2009
Error problem
http://forum.testcopy.net/threads/how-to-fix-errors-based-on-error-code-table-of-canon-lbp-3100-3108-3010-3150.693/
Sep 29, 2014 | Canon I-Sensys Mf4410 All-In-One Laser...
Canon ir 3100 error code e000070-0001
the error code appears when a tension arm (front or rear) of the ITB tension roller is broken.check the tension arms (front and rear) for breakage. If either of the arms is broken, replace it with a new one.
May 03, 2011 | Canon iRC3100 Printer
the error code appeared because a tension arm (front or rear) of the ITB tension roller was broken. check the tension arms (front and rear) for breakage. If either of the arms is broken, replace it with a new one.
Canon iR 3100 Problem Error Code E 20081
HELOW SIR UR PROBLAM E 20081 IT IS A RONG CODE?SO U WILL WRITE THE CURRECT CODE SUPPOSE EXAMPLE E021-0001
Nov 12, 2010 | Canon iRC3100 Printer
Ir3100 : E00070-003 error code
canon ir 3100 error code E00070-003
Oct 23, 2009 | Canon imageRUNNER C3200 Copier
I have an e 000012-0002 error on my ir 3100 - can you help please?
Hi error code refers to a drum drive motor error code,
more than likely you have a tight Drum. remove drum and see if you can turn it by hand if not replace the drum unit
Oct 02, 2009 | Canon imageRUNNER C3200 Copier
Canon copier ir 3100 cn error code E000602 - 0202
the hard drive containing the software that drives the machine has an error. Corrective steps would be to contact to a Canon technician, who can first try to re-install the software, and if this doesn't work the hard drive has probably crashed, meaning that the drive will need to be replaced and the software re-installed
Jan 23, 2009 | Office Equipment & Supplies
Canon ir 3100 cn error code e000020-0081
HP Photosmart C 310series-driver Vindows Vista
Aug 09, 2008 | Canon imageRUNNER C3200 Copier
Canon IR 3100 error code (E000020-0081)
error code E00020-0081 my canon printer IRC3170i.what is the problem?Anybody can help?
Feb 19, 2008 | Office Equipment & Supplies
Canon PIXMA MP150 All-In-One InkJet Printer Logo
650 people viewed this question
old marine
old marine
