Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Screen shrinks When i first turn on my tv the screen shrinks in and out until the tv warms up. What would be going out on it? Thanks
  • Philips Master
  • 8,617 Answers
Opto isolators are bad on the LSB, they are no longer available, But you can get the replacement LSB at the following link
http://servicemanuals.vstore.ca/
Posted on Feb 02, 2009
When I turn the T.V. on The screen shrinks and becomes distorted. After it warms up It becomes more clear and works fine.
If your TV is shrinking and expanding you can get a repair kit from www.TvRepairKits.com for less than 50.00
Comments: May 19, 2009- If your TV is shrinking and expanding you can get a repair kit from www.TvRepairKits.com for less than 50.00 May 22, 2009- Here are the most common symptoms and example photos of this problem.
  • Video Shrinks and Expands - Over and Over - After warming up it typicaly works.
  • After a few weeks the shrinking stops and you loose all video and audio.
0667c5f.pngSOLUTION
Its a fairly easy DIY job. Check the site www.TvRepairKits.com
Their kits include a photo instruction guide, parts, email/phone support, etc.
Nov 23, 2009 | Philips Magnavox 9P6034C 60" Rear...
Magnavox 52" widescreen tv year of model 2003
Common problem and fairly easy to fix.
Problem
Screen shrinks and expands - may or may not correct itself after the TV warms up. After a few days, weeks, or months of having the shrinking/expanding problem you may loose all audio/video but the power light will remain lit!
Solution:
Check with the site www.TvRepairKits.com. They have built a kit to fix this problem.
Jan 21, 2009 | Philips Magnavox 9P6034C 60" Rear...
Magnavox 52" widescreen 2003... When you turn it on it takes abou
If you have the following symptoms check the site www.TvRepairKits.com . They have a repair kit for this problem.
I have a 10 year old phillips magnovox 55 inch tv
yes you can take off the cover but carefuly and in the back of your tv you will see the flyback and has 2 button one fro focus and other G2 then rotate the focus button till you will see no blurry
that is all if you dont know how bring some frend who can and tell him to do that
Dec 10, 2008 | Philips Magnavox 55P9271 55" Rear...
After a few minutes picture shrinks to single line on screen and then powers off
Since the set works initially, there are likely poor solder connections at the vertical IC. If this is not addressed soon, the IC will fail and need to be replaced. The vertical IC is a small flat IC with about 11 pins or so that may be marked LA7837 or something similar. Try resoldering the pins first. If that fails to resolve the problem, replace teh IC. Feel free to post the marking here so I can verify you have the correct one.
Dan
Jul 30, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Screen blinks - sometimes shrinks & disappears and then re-appears
just do this, resolder the whole circuit board and crt board.
Mar 12, 2008 | Computers & Internet
Phillips 60 inch projection tv
you can ask a good tv Technion man, since if it happens to be like that then in coming day u will have to face problems. So since this very common problem which will arise in old tv. Actually the real problem is that, some parts in the board may have become weak or the molded part in the board may have fallen down ,so changing that particular part or molding again may fix that problem. Since i am not an Technion I don't the right terms to help u.I have see this problem in many places and don't worry your picture tube is well and good.
Aug 10, 2007 | Philips 9P5544C 55" Rear Projection...
60 inch philips magnavox
When you first turn on the tv, It goes from small picture to full screen and several corors around screen for a few minutes,I guess until it warms up? Could you please help? Thanks!
Mar 25, 2007 | Philips Magnavox 9P6034C 60" Rear...
Poor and incomplete image until warm up
Does it shrink vertically as it warms up? could be a bad capacitor in the vertical circuit.
Nov 21, 2006 | RCA P46924 46" Rear Projection Television
Picture Shrinks
It is in the power supply or I would guess most likly in the horizontal sweep section of the tV set. MOST of the time, if the power supply is going lower in voltage, the set will shrink in width,BUT will also shrink in vertical size. If this is not happening, then I would say it is in the horizontal drive circuit. This is not a circuit a user should be experimenting with, as this is the HIGH VOLTAGE circuit and can pack a mean punch! Please if the sets less the 4 to 5 years old you may want to concider an estimate or replacing the set. Its all up to you. GOOD LUCK
Oct 07, 2006 | Philips 8P6034 TV
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
87 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
