Interactive services problem
Every now and then i have a window open up saying the MSI.exe must be launched through set up.
what does this mean?
  • 51 Answers
Go to search in the start menu and search MSI.exe and then right mouse and click run as administrator and it will stop that message.
Posted on Feb 06, 2009
  • Aaron Whitehurst Feb 06, 2009
    go to search in the start menu and search MSI.exe and then right mouse and click run as administrator and it will stop that message.
How to download Take 2 Interactive Update ?
goto my documents and sanandreas userfiles delete th gta_sa.set
Aug 13, 2012 | Rockstar Grand Theft Auto: San Andreas
I have Wildlife Zoo (not interactive). I installed the disc, but can not open it to play. I have Windows 7 and says not compatable with program name WLP2.exe Can you help me? Thanks
1.
Go to the location of the file WLP2.exe in the root directory of the game, which is normally located on Computer>drive C>program files> and then under the company name, dreamcatcher.
2.
Then right click the file and choose "Properties" and then select Compatibility Tab and make it to run under Windows XP, and checkmark the box that says "Run as Administrator".
3.
Push ok, then restart the computer.
4.
Double click that .exe file: WLP2 where I directed you before and see if it worked.
Hope this helps!
May 29, 2011 | DreamCatcher Interactive Wildlife Zoo...
Hasbro MasterMind does not install on Windows XP or Windows 7 ! Do they have a newer version available ? I loved the game but it only played on Windows 98 ..... Anyone have any ideas ? Thanks...
Have you tried running the installer in compatibility mode? Right click on the installer (usually setup.exe or install.exe, and if you have it on a CD, you need to open the CD in My Computer as a folder by right clicking and choosing open), go to Properties -> Compatibility -> Check the 'Run this program in compatibility mode for:' check box, and select 'Windows 98/Windows' ME from the drop-down menu. Apply the changes or click 'OK', and try to run the .exe -file. If the game successfully installs, and you can't still launch it, do the same to the game's launch .exe -file.
Mar 22, 2011 | Hasbro Interactive MasterMind for Windows
Problem running Civilization IV with Windows Vista
Okay, i play Civ IV on my system and i run Vista as well. Your best bet is the tweak with the compatibility. Find the install folder and look for the .exe that launches the game (civ.exe i think, don't hold me to that though). Right click on it and click on properties, then the compatibility tab. Try dropping the compatibility to win xp and see if that helps. If it doesn't, post your system specs and we'll work from there
Jul 25, 2010 | Take 2 Interactive Sid Meier's...
Give me unit setup in nero 9
Here is something I was workining hard to solve: how to install any nero 9 app for example "Nero Burning rom" or "Nero Stsrtsmart" from one of the seperate .msi installers without setupx.exe. These installers are found when you extract the full downloaded packege of nero 9. In the folder you find folders named "unit_app_4", "unit_app_5" and so on.
Inside the unit_app folders you find cab files and an .msi installer. If you try to execute the .msi you recieve an error stating this program can only be started from "setupx.exe".
This is most distubing since what would seem to be the only option is to go through nero's set up process which is time consuming and annoying.
However I have discovered a way to choose the applications I like for example Nero burning rom which is the files in "unit_app_4" and install any one of these apps directly from the .msi installer.
To do this you will need an .msi windows installer editor. The one I use is "ORCA" which is available from microsoft and comes with the windows installer sdk.
The first thing to do is edit the .msi. The .msi in the folder to burning rom is labled "unit.msi" as are all the .msi installers for each app. Open orca. Drag and drop "unit.msi" onto orca.
On the left hand tables select "custom action'. On the right hand window under "action" select "CA_BeforeDeferredFinalizexxInstall". Right click on this and then delete it.
gif.gif Capture.JPG (54.59K)
Now find in the left hand "table" "launch condition". Right click on it and select "drop table".
gif.gif Cape.JPG (47.21K)
Save the changes and exit orca.
You should now be able to install the application with the modified installer be clicking on it.
After running the install you should find folders and files in "program files" and "program files\common files" but there will be no shortcuts.
We are not finished.
If you go to the folder that contains "nero.exe" don't even try it becouse it won't work.
Nero applications will only work with a serial key and a crucial file which must be registerd.
You need this file: "AdvrCntr4.dll". In ordern to get this file you will have to run the full packege installer or setupx.exe. When you get to the first welcome to nero page go to your temp folder and you will find a folder named "nro.tmp". Open this folder select "AdvrCntr4.dll" and move it to "program files\common files".
Open a commaned prompt. Change the directory to "program files\common files"(CD %systemdrive%\program files\common files)
Type "regsvr32 AdvrCntr4.dll"
It will confirm that the file is registered.
Now you need your serial.
Open a command. Type REG ADD HKLM\SOFTWARE\Nero\Shared\NL9 /v Serial9_1223131541 /d 1111-2222-3333-4444-5555-6666-7777-8888
Substitute these intergers with your key.
You may need the product id which is under the same key. The easiest way to enter it along with the serial is to install nero with the normal installer or setupx.exe go through the process and then export the key containing the product id and serial from registry editor.
(Be carful not to use the nero product id from vista on xp becouse they are different.)
--This edit is for people who modified their .msi but still can not launch it directly. This behavior only occurs if the .msi you edited has bean used previously.--
The reason for this is the .msi was executed before it was modified and the data base located in c:\windows\installer
is still refering to the previosly executed unmodified .msi.
To create a new data base find the .msi in the c:\windows\installer folder and delete it but thats hard to find so just move the installer folder somewhere outside of c:\windows, create a new folder in c:\windows named installer and execute the modified .msi which will create a new data base then move the installer folder you moved out of c:\windows back to c:\windows. The .msi should now execute directly.
Jul 19, 2010 | Ahead Software Nero 6.6 (600901) for PC
The installation wont launch
try going to the run program and typing Setup.exe
Aug 12, 2009 | LEGO interactive LEGO Loco for Windows
Can't install Business Plan Pro V 11
http://support.paloalto.com/index_Left.htm#StartTopic=content%2Fbusiness_plan_pro%2Finstall_or_update%2Fwindows_xpsp3.htm|SkinName=default
Jan 10, 2009 | Compaq Modular Smart Array 500 G2...
Debugger detected
Not sure if your problem is solved yet. I have read about this issue being casued by the nero burning software. An uninstall should fix it
Dec 12, 2008 | Whiptail Interactive R.C. Cars for Windows
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
