Question about HP LaserJet 4050 Printer
I have an old HP laserjet 4050 which is on my home lan and connected to an old PC using Windows 2000. I bought a new laptop using Vista home premium and tried unsuccessfully to link the pc with the printer. After looking on every site imaginable, someone suggested updating the printer drivers on the old pc, which I did through windows update. Now, the printer doesn't work at all!! How do I uninstall that windows driver update so I can at least print from my other computers?
  • 1 more comment
  • porschewife Feb 03, 2009
    Thank you so much for trying to help. There seems to be no way to uninstall the HP drivers. I have tried every conceivable way both from the add/delete programs to trying to delete the printer from the printers folder. And, if I try to add the printer as a new printer, it still won't print. I am so sorry I ever attempted this. Now I will have to hire someone to fix it. I hate being computer stupid!
    Thank you both. FRCS68, I spent 8-9 hours yesterday and have totally screwed up the printing on my entire network. I tried deleting and also went to the link that was sent and downloaded 2 drivers, added the printer again, turned it off, turned it on, turned it off, blah blah blah. Computers were not made for the faint of heart. I am willing to invest another hour or two, but then.....I am up for finding a geek that will come to the house and fix it!
  • porschewife Feb 04, 2009
    frcs68 - Thank you! The printer is now working as it did in the past. The laptop keeps giving me an error message that the right driver is not installed. I have downloaded the drivers you suggested as well as the Vista 64 bit, but non work. I am going out of town for a few days and will try again when I get back. But, you are a life-saver. I am so grateful to be able to print again!
    Genius:
  • 1,605 Answers
Unistall the printer driver (software) from the windows 2000 PC. install the old version of printer software on the windows 2000.
install the newer printer software from HP website. install it on the laptop.
you may have to disable the windows 2000 PC first.
make sure you have the same type of driver on both machine, other wise the printer will not work.
Posted on Feb 02, 2009
  • 1 more comment
  • Frank
    Frank Feb 03, 2009
    don't give up yet!
    if you still willing to try one one more thing, let me know and leave a message on this thread.
    thanks
  • Frank
    Frank Feb 04, 2009
    can you tell me how were all if the machine are connected?
    besides PC and printer, do you have any other network devices?
    lets do one step at a time.
    please post back after you completed the following steps.
    1). if the printer is connected to teh old PC runing Windows 2000. as you have indicated before.
    this is what you do.
    turn off the printer adn disconnected the printer from the PC.
    deleted the printer from start>>printer and Faxes control panel.
    install the driver from the follwoing link or from the original printer CD.
    Windows 2000
    HP LaserJet 4050 PCL 5e driver
    http://h20000.www2.hp.com/bizsupport/Tec...
    reconnected the printer and turn it on.
    test it out via test page, from MS word, Excel. make sure the PC with Windows 2000 back to normal.
    2). go to start>>control panel>>add & remove porgarm, click on the add /remove windows components, check the network and file sharing.
    3). right click on my network on the desktop. select porperties, right click on local area connection. check fiel and printer sharing for microsoft network.
    4). open my computer and share the c: drive. (windows 2000 need share folder in order to share print).
    deleted the printer form the laptop.
    go to the following link and download the driver.
    windows Vista
    HP LaserJet 4050 Universial Print Driver for Windows PCL-5
    install it and restart the laptop.
    install the printer, and check all the item same as in windows 2000.
  • Frank
    Frank Feb 05, 2009
    OK
    go to WIn2k machine.
    start>>control panel>>system>> computer name, copy the machine name.
    go to start>> printer and faxes and copy the printer name.
    you are going to need both name later.
    1). on Vista machine.
    click on advance system settings.
    click on computer name tab, make sure both Win2k and the Vista are inthe same group i.e; workgroup.
    if not, click on the change tab and change the group.
    restart the computer.
    2). double click on the network icon on your desktop
    rigth click to enable the "network discovery and file sharing" under the main tool bar.
    3). you should be able to see the Win2K machine. you may need a login and password setup on the Win2k machine.
    4).if you have the printer share enable on the Win2k machine, you should able to see it, under the Win2k icon. as subgroup.
    5).go to start>>devices and printer. click on add a printer.
    select local printer, click on creat a new port , click on the drop dwon and select "standard TCP/IP port"
    click on next, type the Win2k machine name in the following format \\Win2k\machine name
    type in the port name as "com1"
    note: if the above format don't work, you can just type in the Win2k name.
    the rest of screen should be all default.
    restart the computer and check the pirnter is still present and try to print a test page.
    if the test page comes out, then you are all set.
    s
  • 63 Answers
You need to download 2 drivers
one for the Old PC, and 1 to the New PC
this link has what you need,
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=18318&taskId=135&prodTypeId=18972&prodSeriesId=25475&lang=en&cc=us&submit=Go%20â»
make sure to choose the right Operating System for each machine (for the new machine you would click/download/install Microsoft Windows Vista)
Compaq Presario F700 Windows Vista Home Premium My Network Card has stopped detecting wireless connections and tells me there is no network adapter installed. It was working then stopped several days...
If you can use the cable connection
you can search for a new driver for the lan card for vista here:
http://h10025.www1.hp.com/ewfrf/wc/pfinder?lc=en&dlc=en&cc=us&lang=en&tool=&query=F700+#N284
Try using the auto detect function it will tell what model
you have.To get the right driver.
Also try use the microsoft update function
in your start button.
Hope this was helpfull.
Mar 10, 2011 | Compaq Presario 700 470024-192 Notebook
LJ 3050 printer is printing very slow.
TRY HP Print Diagnostic Utility was created to help users troubleshoot and correct many common problems on Windows-based computers that can prevent printing.Follow the on-screen instructions to run the utility. Details and specifications File name: s.gif HPPDU.exe [1/1, 1.54M] System requirements: s.gif No additional prerequisites Released: s.gif 2010-08-13 Version: s.gif 3.0.0.013 Compatibility: s.gif Microsoft Windows Vista, Microsoft Windows Vista Home Premium (32-bit), Microsoft Windows Vista Home Basic (32-bit), Microsoft Windows Vista Business (32-bit), Microsoft Windows Vista Ultimate (32-bit), Microsoft Windows 7 (32-bit), Microsoft Windows 7 Home Basic (32-bit), Microsoft Windows 7 Home Premium (32-bit), Microsoft Windows 7 Professional (32-bit), Microsoft Windows 7 Enterprise (32-bit), Microsoft Windows 7 Ultimate (32-bit), Microsoft Windows 7 Home Basic (64-bit), Microsoft Windows 7 Home Premium (64-bit), Microsoft Windows 7 Professional (64-bit), Microsoft Windows 7 Enterprise (64-bit), Microsoft Windows 7 Ultimate (64-bit), Microsoft Windows 7 (64-bit), Microsoft Windows Vista (64-bit), Microsoft Windows Vista Home Basic (64-bit), Microsoft Windows Vista Home Premium (64-bit), Microsoft Windows Vista Business (64-bit), Microsoft Windows Vista Enterprise (64-bit), Microsoft Windows Vista Enterprise (32-bit), Microsoft Windows XP Fix/Enhancement: s.gif This version of the HP Print Diagnostic Utility provides an improved user interface in multiple languages, improved diagnostic and problem resolution capability, and support for usb and network connected devices.
Oct 27, 2010 | HP LaserJet 3050 Printer
Is there any hope for a Vista 64 bit HP Laptop with the HP LJ 2840 Printer? I have tried it all, had Invisus Support work on it for two hours today, 10-25-10, and still no printer functionality. I am...
s.gif upd-5_1_1_8232-pcl5_winxp-vista-x64.exe [1/1, 15.21M] System requirements: s.gif Client and server operated systems supported for the most current release of the UPD:
Client operating systems supported:
  • Microsoft Windows 7 Starter, Home Premium, Professional, Enterprise, and Ultimate; x86 and x64
  • Microsoft Windows Vista Business, Enterprise, Home Basic, Home Premium, and Ultimate; x86 and x64
  • Microsoft Windows XP (SP2 and later) Home Edition, and Professional; x86 and x64
    *Note: Microsoft retired mainstream support for Windows XP in April 2009. HP will continue to provide best effort support for the current UPD and tools for the discontinued Windows XP operating system until 2011
Oct 26, 2010 | HP LaserJet 2840 Printer
I have have downloaded the HP Laserjet 3015 Print driver on my Lenovo U330 Laptop with Windows 7 Ultimate. Unfortunatley, I've tried 2-3 times to with no success. Am I having a compatiblity issue with...
File name: s.gif upd-5_1_1_8232-pcl5_winxp-vista-x64.exe [1/1, 15.21M] System requirements: s.gif Client and server operated systems supported for the most current release of the UPD:
Oct 25, 2010 | HP LaserJet 3015 All-In-One Printer
Can vista home premium connect to a LAN
You should check the possibility to connect to homegroup network. I have Vista home OS and I can use router to connect to internet but I can not connect to other PC runned windows 7, I can see them but without connection. I had found on a forum that Vista home version can not interconnect in homegropu network.
Good luck with your search
Mar 19, 2010 | Computers & Internet
HP Laserjet 4050. Can I connect from my TCP/IP to JetDirect?
To use a printer DIRECTLY into your PC or laptop (without plugging both into a network hib, or switch), you need to use a CROSSOVER patch cable.
Feb 19, 2010 | HP LaserJet 4050 Printer
Problem connecting LaserJet 5L to new HP Pavillion laptop
I have an HP 5L and Vista Premium also. If you would tell me where you did find the driver, I will install it on my computer and possibly solve both of our problems.
Thanks
Mar 17, 2009 | HP LaserJet 5L Printer
Hp dv7-1132nr Quickplay touch button doesn't launch quickplay.
Hallow Dear,
Please use this link to download Drivers for your PC (20M)
XP/Vista - ftp://ftp.hp.com/pub/softpaq/sp38501-39000/sp38688.exe
Operating Systems
Microsoft Windows 2000
Microsoft Windows XP Home Edition
Microsoft Windows XP Media Center Edition
Microsoft Windows XP Professional
Microsoft Windows XP Tablet PC Edition
Microsoft Windows Vista Enterprise 32 Edition
Microsoft Windows Vista Home Basic 32 Edition
Microsoft Windows Vista Home Premium 32 Edition
Microsoft Windows Vista Business 32 Edition
Microsoft Windows Vista Starter 32 Edition
Microsoft Windows Vista Ultimate 32 Edition
Microsoft Windows Vista Enterprise 64 Edition
Microsoft Windows Vista Home Basic 64 Edition
Microsoft Windows Vista Home Premium 64 Edition
Microsoft Windows Vista Business 64 Edition
Microsoft Windows Vista Ultimate 64 Edition
This Will Completely Solve your Prob; if there is no any internal Hardware Problems with Quick Lunch Buttons
(I feel there is no any coz u mention about Ding Sound. That mean your system is recognizing your key input & all you need is Just program those keys – above setup will do that)
** If you didn’t solve your prob; my advice is take your lap to a good technician with component level Repair skills.
Thank you & Best Regards
Dinu….
Dec 20, 2008 | HP Pavilion dv4000 Notebook
Problem in closing window of any internet explorer screen with Windows Vista Home Premium
I would recommend you to back all your work up, then with the use of the restore cds, re-build your laptop. Then see if you get the same problem. If you do, then you need to send the laptop back
May 09, 2008 | HP Compaq Presario V2000 Notebook
HP LaserJet 4050 Printer Logo
199 people viewed this question
Seeker5211
Seeker5211
