Question about Game Factory Build-A-Bear Workshop for DS
Locking up after rubbing the hearts
When creating a new bear, once my daughter has rubbed the hearts and whispered into the mic, the hearts all come together to create one big pink heart. But that's it. The DS locks up and nothing else happens. Any idea what the problem might be?
  • 1 more comment
  • Anonymous Feb 18, 2009
    locks up while it says make a wish
  • Anonymous Mar 26, 2009
    same exact problem
  • Anonymous Apr 20, 2009
    Same here, someone help
    Problem Solver:
  • 6 Answers
I think that the DS has just frozen. It happens sometimes, the heart should go onto the top screen and then fly into the bear.
Posted on Dec 25, 2009
Rubbing noise
This will probably be the front C-V shaft or hub bearing. When in 2 wheel drive the C-V shaft will not have a load on it. But as soon as you change to 4 wheel drive the part has stress on it. It can also behave this way when the Hub bearing is asked to bear Torque from the turning C-V shaft. Instead of having slack from the weight of the truck pressing the Hub bearings straight up, the bearings are rotating under Torque and any play is magnified.
The rubbing can be the rotor, running on bad bearings and hitting the brake pads. As the rotor is bolted onto the Hub bearing, the rotor will tilt in harmony to the bad bearings in the Hub. This creates a misalignment as one side of the rotor is tilted creating a high side.
Feb 28, 2014 | Ford F-250 Cars & Trucks
Weird vibration, unable to figure out
I would have the front wheel bearing adjustment checked first as if they are loose the rotor will be rubbing on the pads and the vibration will be wheel wobbling on the loose bearings Unless you replaced the bearings with new ones then they will fail especially if the adjustment was too tight and too much grease was used.
Jul 15, 2013 | 1999 Oldsmobile Alero
Washer maytag front loading 4000 series assembled and runs but iwith two problems.1) residue on inner surface of door window..lint like oily paste ..gasket rubbing on inner drum?? meaning main rubber
The fault seems to be that the main seal is rubbing against and is thus producing the oily residue on the window. Now the fault seems that the drum is rubbing due to POOR ALIGNMENT or poor BEARING settings.
You need to check the PLAY on the drum and if this shakes a bit then the assembly must be reset with correct aligment and the drum must move without rubbing the rubber seals.
Check this link; replacing bearings
Jan 14, 2013 | Maytag Washing Machines
My daughter got poptart in the mic and charging area. This morning I was told that you could barely hear me but after I got what I thought was all of it out no one can hear me. I have taken the phone...
The best bet to clean gunk out of a phone is to use a high concentration rubbing alcohol, something of a 98% concentration or more. You can pick that up at any drug store.
Using the rubbing alcohol on a q-tip can to get any residue out of the phone will likely increase the usability of the microphone.
May 04, 2011 | Cell Phones
I have a 750, shaft drive, water cooled. Last summer the drive shaft began to rub the support arm. I put the bike in the shop & the mechanic tore it down to find the problem. He reported back that the...
It sounds like you have a broken or worn swing arm bearing. There are two bearings , on on each side of the swing arm. If the one on the shaft side has gone bad it would cause the shaft to twist or move the result being the rubber dirt boot getting rubbed. To check, unbolt the lower shock bolts , remove the rear wheel , grab the swing arm , and move it from side to side to see which side has the worn/broken bearing.
Dec 03, 2010 | 1994 kawasaki VN 750 Vulcan
My neptune washer is makintg a bearing or a rubbing noise, I took the back off and the pulley is rubbing the inspection cover
THERE IS A RETROFIT KIT FOR THIS PROBLEM..YOU CAN FIND IT THRU REPAIR CLINIC.COM..USE YOUR MODLE NUMBER..THE KIT CONSIST OF A LARGER WAHER AND REPLACEMENT LOCKING BOLT..GET A NEW BELT WHILE YOUR THERE,A PIN TO PUT ON BUT YOU'LL THANK ME LATER..RDS
Apr 23, 2010 | Maytag Neptune MAH5500B Front Load Washer
Brush roller does not turn on bissell upright
Pull the brush out and pull the bearings off the ends. Clean everything up with rubbing alcohol. Put it back together. DO NOT OIL the bearings. Oil will make dust stick and jam the bearings again.
Mar 10, 2009 | Vacuums
Lock light doesn't go on, won't fill, metal rubbing sound
thins sounds like a bad control board and wax motor issue, comon for this machine prbably about $300 for you to repair ,closer to $500 for aservice co. however, you say oyou hear a metal on metal rubbing thisi a sign of a more serious problem of rear bearing NOt worth cost of repair.. one way to tell the rear bearing is to open the washer door and grab the inner basket, try to lift it up you should have no movement iff correct. ifyour able to lift teh inner tuban inch or so, independently of the machine, i would venture to say oyou need a rear bearing// i mean new machine!!!!
Feb 27, 2009 | Maytag Neptune MAH5500B Front Load Washer
Repaire scratches on a lcd flat screen
The eraser method is even better than I first thought.
I acquired my first scratch some weeks back, tried the eraser method, and was quite pleased with the results, as my scratch was approx. 80% less visible, a faint grey line visible only on very light or dark coloured backgrounds, instead of the glaring black line it was at first.
Today my monitor toppled again (I really must tether the damn thing to something next time) creating - gulp - a new and even larger scratch. Oh, no... But whodathunk I'd end up happy I got the 2nd scratch? Oddly, I am happy, 'cause I took the opportunity to lay the monitor flat, take my white eraser again , and really go to town rubbing both new & old scratches. Lo & behold, both scratches appear to be now virtually 100% invisible or gone. My 2-scratch monitor is better now than it was as a one scratch one! I'm now convinced it's partly, largely, or completely due to the heat from friction of rubbing the eraser across the scratch, plus pressure applied, that does the trick. The heat must soften the plastic surface making it malleable, and the pressure of rubbing smooths out the jagged scratch edges, making the scratches disappear.
-So, if at first your eraser doesn't completely eliminate your scratch, try, try again! Keep working on it - harder!faster! And with luck, you'll get results like mine: complete elimination of two ugly scratches!
Apr 25, 2008 | Computers & Internet
Game Factory Build-A-Bear Workshop for DS Logo
216 people viewed this question
Top Game Factory Video Game Consoles & Games Experts
James Wishart
Josh Whitehead
Josh Whitehead
Are you a Game Factory Video Game Console and Game Expert? Answer questions, earn points and help others
