Question about Brother MFC-7820N Laser Printer
Scanner locked Makes ratcheting sound but goes back to "scanner locked" error message
  • rsullivan601 Feb 03, 2009
    Tech said may need to lubricate shaft or new motor. Would like to try to lubricate shaft but cannot remove the scanner bed. Need just a little hint how to get it apart.
  • 63 Answers
Look for a switch, or lever to unlock the scanner (behind it, maybe under the lid)
Posted on Feb 02, 2009
  • Kim Tyler Feb 02, 2009
    if that is not it,
    then you will need parts
Why do I get an error message: Internal error occurred. Scan driver will be closed. Code:5,202,52?
Look at the bottom of the scanner and there should be a lock/unlock slider. Unlock it and see what happens.
If it is already unlocked then the drive/stepper motor or belt is bad.
Mar 27, 2015 | Canon CanoScan LiDE 25 Flatbed Scanner
Epson 610 Workforce Printer Error; Light Bar won't reset
Sound like the scanner is the issue, is it under warranty? OR the Scanner may be locked, check for the scanner release device unlock it,.
Dec 17, 2012 | Epson Workforce 610 All-In-One InkJet...
My drz 110 makes a ratcheting sound and wont turn over
the main shaft has broken and possibly the first gear and right engine case. Common problem.
Jan 06, 2010 | 2005 kawasaki KLX 110
Unit makes a clicking sound at end of the power-up sequence
Sounds like the scanning mirror might be locked - during shipping, the mirror is locked to prevent damage. Look around the back or the underside of the unit and look for a slider with a lock/unlock picture on it. Slide it to unlock and the mirror should be free to move.
Nov 20, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Scanner makes a horrible noise until it goes into error state
Sounds like the scanner portion of your all-in-one is bad, best thing to do if its still under warranty is to call HP Tech Support and have them verify the issue: 800-474-6836
If its not under warranty then the machine is done.
Aug 08, 2009 | HP Office Equipment & Supplies
Error message says: Scanner is locked, Computer cannot communicate with scanner.
Have you checked the obvious? The scanner lock switch is located on the bottom of the scanner back right corner. --Ted
Jun 29, 2009 | Canon CanoScan 4200F Flatbed Scanner
Scanner bulb stuck on left after mirror cleaning, machine frozen
The scanner is locked. You need to see the user manual and look for the scanner lock. It just needs to be switched to unlock.
Feb 12, 2009 | HP LaserJet 3330 All-In-One Printer
Trouble shooting
The "car sound" could be an indication that the scanner is locked. Check the lock switch on the bottom of the scanner. Move the switch back and forth a few times and then leave it in the locked position. Another possibility is that you are scanning heavy items such as books. If too much weight is placed on the scanner glass, then pressure could be enough to prevent the scanning element from moving as it should.
The code 201 sometimes can indicate a power issue...meaning the scanner is not getting enough power. Try connecting the usb cable to a different port on the computer (preferrably directly to the computer and not through a USB hub).
May 20, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Unlock
Most scanners shipped have a lock on them to prevent the top from opening up and damaging the glass. This is a screw type mabey other but a penny fits in mine. This may not be the case for you but look in your manual to find the unlock device.
This will also in some scanners prevent the stepper motor from moving in transit . The stepper motor is the device thats makes the bar slide up and down to scan the page.
Hope this helped some.
Kevin
Dec 30, 2007 | Visioneer OneTouch 5800 Flatbed Scanner
Laser Jet 3300
Hi, when you lift the cover where the flatbed glass is can you see the scanner trying to move back and forth? Also you might want to check and make sure the scanner lock didn't get moved to where the scanner just goes back in forth ? Are you getting any error codes?
Nov 29, 2007 | HP LaserJet 3300 All-In-One Printer
Brother MFC-7820N Laser Printer Logo
1,075 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
