Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
No Sound on frigidaire black smooth top stove/oven
We use our oven almost daily and went to use it the other day and there is no sound (i.e.: doesn't beep when you adjust the temp., doesn't beep to make you aware the oven is done preheating, etc.) In addition, it is not alarming us when the food we are baking is done. The timer works, there just isn't any sound when the time has expired. Are there settings that need to be reset?
    President:
  • 1,214 Answers
Check in the manual, sometimes the alarms can be disabled.
Please reply the complete model number to see if that ability exists, or what the P/N is of the timer.
Posted on Feb 02, 2009
Frigidaire gas oven Oven control panel went blank. There is electricity to stove and oven.
sounds like the clock assy. is bad part 316557206 heat usually is the cause of this part to fail,people use the self clean the oven gets up to 1000 degrees and damages the clock assy. or a large pot was on top of the stove and the heat damaged it but whatever the cause was you need to change out the clock assy. if the touch pad is black you can reuse it if it's white for some reason it doesn't peel off without damaging the overlay get a putty knife and a hair dryer,heat up the overlay and peel it off with the putty knife,go here to see the parts
https://www.searspartsdirect.com/model-number/FGFLMC55ECA/1428/0124002.html
it looks like this only comes with the black overlay because it doesn't show any other colors so you can order the overlay or peel it off and save some bucks,go to the sight,put your model number in,go to backguard and look at parts 20 and 20a this is what you need,first i would check all the wires going to the clock assy. to make sure there isn't a broken wire.good luck
Dec 24, 2017 | Frigidaire FGB24L2A Gas Single Oven
Frigidaire oven wont heat up but stovetop and digital all works
Hello angeleyez82 - The EOC (electronic oven control/control board) basically sends power to both the broil and bake elements. As long as the power supply to the range (240VAC) and wiring between the elements is correct, then typically only the element(s) or EOC could prevent the unit from heating. I hope this information helps to some degree.
Jun 25, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire oven
Yes, that sounds like a relay on the oven control board. Here is the part to order that has a 365 day, any part, any reason return policy so you may want to order from them.
Jun 25, 2013 | Ovens
I have a 2 yo fridgedare stove that the oven went out..the stove top is working but now oven isn't? The other day while i was cooking a loud noise like a "boom" happened and now oven not working?...
The noise you heard was probably the oven element short circuiting to earth. If the cooktop and grill are working then the fuses, internal/main must not have blown. If this is the case the oven indicator light should come on when you turn the oven on. If it does the oven element is definitely faulty and needs replacing.
Mar 05, 2011 | Frigidaire Ovens
Frigidaire gallery stove, oven not working,
Morison,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
May 04, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Our frigidaire flat-top electric stove stopped working
Sound like you make have a loose neutral on the cord where it attaches to the range or in the electrical receptacle where it plugs in, you can check the cord by pulling the range out, remove the small access cover to the cord connection area, after you have unplugged it and just tightened all the nuts to all connections on the cord. I advise an electrician to check the receptacle. I hope this has helped you. Have a great new year.
Dec 28, 2017 | Frigidaire FEB27S5A Electric Single Oven
Dirt and grease between glass in oven door
i have taken the glass from the inside of the oven,and just cant get grease off, tried everything ,bleach,even lemon juice,
any ideas jimmy
Aug 01, 2008 | Ovens
FEFL78CQA FRIGIDAIR ELECRIC STOVE
Unplug your power cord from the socket outlet.
remove the back cover where the power cord connection is housed. visually check the connection, expose wire harness might touches the cover somehow. or the cover was dent that causes the bare wire to touched the cover. correct the dent if any, or tighen loose wire.assemble back cover. Reset your circuit breaker to your Stove because the pop sound might trip off your breaker. That should solve the problem.
Jun 28, 2008 | Frigidaire FGB24S5A Gas Single Oven
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
158 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
