Question about HP Color LaserJet 4550n Printer
Network Printer takes for ever to process job
I just installed a Netgear Gigabit router with wireless and now when we send a printjob to the printer it says processing for 5-20 minutes.
Prior to the netgear, we were on a dial up connection with 10\100 hub.
When i start my pc the system is not run in first time
Posted on Feb 02, 2009
How to connect brother hl5470 using wireless
Brother hl5470dw only requires a Wireless connection, SSID and password to connect up to a computer, not AOSS.
Read the network set up manual here
http://download.brother.com/welcome/doc002930/cv_hl5450dn_eng_net.pdf
Apr 09, 2014 | NetGear N750 Wireless Dual Band Gigabit...
Netgear d6300 won't find a wireless canon ip7250
If the printer is connected via wireless it may not be set up correctly, as a network printer.
Connect it up via a USB cable to make sure it works, then change it to Wireless configuration and re-install it as a network not a USB printer.
Nov 26, 2013 | NetGear Computers & Internet
HP 6400 wireless printer will not work with netgear wndr3400v3 router
see manual
http://www.hp.com/ctg/Manual/c01325559.pdf
Sep 13, 2013 | NetGear WNDR3400 N600 Wireless Dual Band...
Wireless connection with a wireless router (Netgear WNDR 4000) a pc and a laptop.
I assume you connect your printer to the desktop with the USB cable.
I assume the laptop is connected to the Wifi network.
First you need to setup the printer to connect to the wireless network. Follow the printer installation instructions to do that.
Next insert the install Disc into the laptop and follow the installation instructions. Use the network installation section.
The printer has a built-in server for printing.
If UPNP is enabled on the router then you should be able to browse the printer on the network.
Sep 30, 2017 | NetGear WGPS606 (WGPS606NAR) Print Server
I am installing a new printer and it is asking me for the wgp passphrase....will it be wgps606? I have a netgear super G wireless Router WGT624
The network passphrase/encryption key is in the Netgear wireless settings.
These settings eg. SSID and encryption key is used to configure the wireless card in the printer or computer so it can connect to the wireless router.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Nov 17, 2010 | NetGear WGT624 Wireless Router
How do I know what my SSID is for my NetGear router Can I hard wire a printer and also send jobs by wireless to same printer? Do I have to download the software in order to print wireless from a different...
Go into the router configure to view the wireless settings, it contains the SSID and encryption etc.
Open IE browser and enter the Netgear URL configuration IP address (http://192.168.0.1)
A network printer must have a built-in print server or be attached to a print server device on the network then all the computers on the network can access this printer.
For a run of the mill printer to work as a network printer it needs to be attached to a computer which is on your network and the printer needs to be setup as a shared printer. This printer and computer must always be switched on for the other computers on the network to access and print to this printer. This method does not require any additional software.
Nov 18, 2009 | NetGear WGR614 Wireless Router
My wireless laptop won't connect to network printer using netgear router . When hard wired over LAN, printer works. Cannot ping when laptop is wireless. Other computers work fine. HELP~
  • laptop has to be connected first to SSID
  • then ping is possible
  • or else reset the wireless settings: change SSID name, channel 6, and no password first
Jul 31, 2009 | NetGear RangeMax WPN824 Wireless Router...
Wireless printer
Call the tech people at the router company they will walk you through getting it set up properly. If it worked before the change over, then part of their job is making sure you are set up again with the new system.
Oct 03, 2017 | Belkin Wireless-G Plus MIMO Router with...
Print jobs no longer arrive on printer
try this: make sure you do not have any pending printjobs (cancel all documents if there's one) then delete all printer icons. Reboot the computer then launch the printer server software to locate it. add that network printer & make it your default.
probability is that some of your applications are sending printjobs to the wrong queue (like the one for the USB connection).
Aug 18, 2008 | Lexmark N4000e Print Server
Wireless Printer Setup
For installing a wireless printer on Windows XP, wireless router is an essential device.
Follow the recommended steps mentioned on the installation CD of the router, and set-up a wireless network.
Since several computers or laptops will access the printer, it0 1is recommended to connect the wireless printer to the main computer through the USB port.
To begin the installation process on Windows XP, access the network setting in the Control Panel, and activate the file and printer sharing option in the LAN setting.
This will allow the operating system to recognize the availability of a wireless printer.
Now, click the Start button, go to Devices and Printers, select Add a Printer option.
Click the second option- Add a network, wireless or Bluetooth printer.
The computer will search for available printer and reflect it on the screen.
Click Finish; and the printer is ready to begin the printing process.
Feb 15, 2008 | Canon PIXMA MP810 All-In-One InkJet...
HP Color LaserJet 4550n Printer Logo
55 people viewed this question
Seeker5211
Seeker5211
