Question about Whirlpool LER5636P Electric Dryer
Dryer starts when u first
Turn on the know before u hit the start button...also stays running when you open the door, wont shut off till you turn button to off
  • rabidwolf42 Feb 03, 2009
    thats knob not know
  • rabidwolf42 Feb 04, 2009
    would that cause the dryer to come on when turning the knob to a setting? one thing i did do is unplug the door switch and took out totally.....still ran.... and i thank you very much for the help
  • 979 Answers
You have a bad door switch or a wire has come off it. Should be cheap and easy to fix.
Posted on Feb 03, 2009
  • Bill Dickerson
    Bill Dickerson Feb 04, 2009
    Yes it could, but it should not. Your door switch is kind of like a 3 way switch. I guess if it runs O.K. without the use of the door switch, then you are O.K. I am assuming that the only way to get the dryer to stop is by turning it off at the control knob.
    However, if you want this to be running correctly and moreover, safely, you may want to replace that control switch. It sounds like it could have melted inside or fused together the components.
Dryer light stays on when door is shut nd wont run
check the door switch,i don't work on lg but on any other dryer if the wsitch is broke the dryer won't start and if the light is on the switch shuts off the light and dryer will start.if you send the model number i can look up the switch for you.open the door and look around the frame where the door closes into,there should be a push button switch or a little paddle that the door hits,when you push in on the switch it should make a clicking sound or i've seen the paddle broke off.hope this helps or if you removed any wires to the door switch you might of wired it wrong
Mar 30, 2013 | LG Dryers
Drum wont turn.pust start and hear a buzz but drun wont turn
I have found that the switch activated by the door close or turns on the interior light when open on is likely the problem. You may notice that if the door is open and you push the start button, it will buzz. So if the door is closed and you get this buzz when pushing the start button, there is a problem with the door switch. The start button "thinks" the door is open, and therefore not start. The defective door switch needs to be replaced. At least highly likely.
Oct 01, 2011 | Maytag Centennial 7.0 Cu. Ft. Super...
My dryer light will not shut off even when door closed and it will not start up when in push start button it does a rapid beep
is the door switch broke?first what kind of dryer and send the model number,when the door closes it hits the door switch and shuts the light off,the dryer will not run if the switch is broke,it's like trying to start the dryer with the door open if the switch broke.
Apr 25, 2011 | Dryers
Push the start button. The dryer will run. Release start button and the dryer stops. The end of cycle chime sounds. The timer ticks. Placed all controles in every position and the results are the same.If...
probably has a broken belt,there is what is called a "Broken Belt" switch by the motor inside on the idler pulley tensioner for the belt,if the belt breaks this switch opens so the dryer wont run without the drum turning so as not to overheat and burn your clothes,replace the drum belt and you should be good to go
Jan 21, 2011 | Whirlpool GEW9878LW Electric Dryer
I have model #110.76712645 The dryer does not
open the door and push on the door switch paddle,if it doesn't click the door switch is broken.when you open the dryer door while it's running the dryer should shut off,if the switch breaks the dryer will either not run or will stay running,if the switch is clicking and is good then you have a broken push to start switch.this is the button you push on to start the dryer,this could break in the on position.let me know what you find
Jul 14, 2010 | Kenmore Dryers
Kenmore heavy Duty Series Dryer (Elec) Model 96576200 has power to on switch dryer starts to run but wont stay on when you release the start switch it shuts off????
The switch is probably bad or the door switch isn't being made by the door pin some machines will start with the button pushed and the door switch open.
Mar 05, 2010 | Dryers
Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Mar 25, 2009 | Dryers
Dryer wont start
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%208522243.pdf
if possible, with the door open, push the limit switch the door normally hits to let the drier know the door is shut. That switch may be bad.
Dec 27, 2008 | Whirlpool LEQ9858P Electric Dryer
Dryer won't stop running
the dryer wont stop running only when open door will it start a fire?
Sep 14, 2007 | Kenmore 62802 Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
