Question about Schumacher & Fast Charge Starter Charger
I have a schumacher se-82-6,i dont use it much and have misplaced the instruction manual.how do i read the guage,when do i know battery is fully chargrd or battery wont charge? thanks erik
    Problem Solver:
  • 4 Answers
If you look at the meter, the charge meter of 100% is slightly above the 2 amp mark so it is confusing. because it says the charge represents the amont charged and the amp meter shows when there is no draw on the charger. so if the battery shows 2.5 amp on the amp meter, it's showing 100% charged. but yet they say it should go to zero on the amp meter, which would mean about 150% charged. i think everyone is scared of blowing up or damaging their batteries because the instructions manual is quite contradictory and confusing. well apparantly, they have several versions of this model to make it more confusing, but here's a pic of what i have.
http://www.northerntool.com/images/product/zoom_images/1677820.jpg
ok, as i was looking for manual online, it is more detailed than the one in box. it now explains this in picture detail. thank you schumacher.
here's the updated manual:
http://www.batterysales.com/downloads/SE-82-6.pdf
hope this helps.
Posted on Jan 23, 2012
  • STEVE L. Jan 23, 2012
    http://www.northerntool.com/images/produ...
    http://www.batterysales.com/downloads/SE...
    hope this helps.
  • 565 Answers
Here are the manuals for your charger:
http://www.schumacherproducts.com/manuals
Posted on Feb 03, 2009
Do you have a wiring diagram for a Schumacher se-1010-2 battery charger?
What did you find on Google and forum sites are also a great sourse of information.
Sep 16, 2014 | Schumacher SE-1010-2 12-Volt 10-Amp Dual...
Schumacher charger parts
Probably not worth repairing. Meaning, the cost to repair will most likely exceed the value of the charger.
Sep 04, 2014 | Schumacher SCUSE826 SE-82-6 6 Amp 12V...
Wiring diagram se-4020 battery charger
try this web site
http://www.manualslib.com/manual/523935/Schumacher-Se-2254.html Schumacher SE 2254 Owner Manual
Feb 08, 2014 | 10/40/200 Amp 6/12-Volt Manual Battery...
Missing battery leads
use meter it will give u a negative reading if your leads are backwards
Jan 07, 2014 | Schumacher SCUSE826 SE-82-6 6 Amp 12V...
HAVE NO IDEA HOW TO READ THE METER ON SE-82-6...RED AND GREEN TRIANGLES...DON'T KNOW WHICH DIRECTION THE NMEEDLE'S SUPPOSED TO BE GOING.
The meter is telling you approximately how much current (amps) it is sending to the battery. When the meter moves all of the way to the right it is charging as hard as it can (that would be 6 Amps) which indicates that the battery needs a lot of charging. As the battery becomes saturated with charge, the meter will move toward the left. As the battery become charged, the unit automatically tapers off the current. The meter can indicate as little as little as zero Amps, meaning it is not charging the battery at all - which is the case when the battery is powered up, but isn't even connected to the battery. If it reads zero when it's connected to the battery, the battery is broken and can't be charged.
Since this charger is rated at 6 amps, it will indicate about 3 amps when the battery is about done. It won't normally go to zero because those 3 amps are getting wasted just heating up the battery.
Aug 16, 2010 | Schumacher & Fast Charge Starter Charger
Schumacher & Fast Charge Starter Charger  Logo
5,705 people viewed this question
Top Schumacher Electrical Supplies Experts
D. E. Hev
Are you a Schumacher Electrical Supply Expert? Answer questions, earn points and help others
