Question about Nikon Coolpix S550 10 Megapixel Digital Camera (Cool Blue) with 5x Optical Zoom + Card Reader + Niko
Nikon Coolpix 995 gets a CF.Er and does not shoot any pix anymore
"This card cannot be used" is a message that I get everytime I turn my camera on and I have tried 3 different memory cards, even an empty one, did not make a difference one way or the other, the problem started gradually so it still would shoot sometimes for a while and then now it does not want to shoot at all. The CF.Er message is in the top right hand corner of Control Panel and the other message "This CF card cannot be read" or "This card cannot be used" shows up on the monitor. Sometimes I can still view pictures in the view mode but cannot shoot any new pix in the A or M mode. I do not think its the battery it can still be fully charged and I tried the AC adapter. It does give it more power so it will temporarily load and then suddenly get the 'This card cannot be read' message again with an Err code in the right hand bottow corner of the Control Panel blinking.
Nick Spirov
  • 35 Answers
SOURCE: Err CF
Observe the connector inside camera, using a flashlight. If there is a bent pin take the camera to service immediately. Don't turn it on any more as we did in one similar case - creating a short circuit that damaged the camera electronics and voided the warranty.
If no visible problems, remove battery and leave it out overnight.
Posted on Jan 16, 2008
informatica
  • 1114 Answers
SOURCE: CF Card for Coolpix 995
Hi - You can download the manual by clicking the link underlined in blue below:
Coolpix 995
See page 162:
So it seems that only 128 Mb is officially supported, however elarger cards may be OK but you would need to try, don't forget to format the new card in the camera. You may find a friendly high street shop that will let you try various card to see.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Posted on Sep 03, 2008
karan4aaki
  • 68 Answers
SOURCE: "CF CARD CANNOT BE USED"
If you are not able to find your connecting cable. Well what you can do is you can take out the memory card and fix it into the card reader (you will get a card reader vey cheap anywhere.). and connect it to your comp. Now your card will work as a flash drive and format the card once.
May be you got a corrupted card. Hope this helps you out.. :))
Posted on Mar 10, 2009
19messiah65
  • 230 Answers
SOURCE: COOLPIX L100 Digital Camera: I am using a L 100 Nikon Cool pix. I have videos s...
Hello there, for transferring media from the memory card to your computer it is much better to remove the memory card from the camera slot and use a card reader as the operating system of your computer will detect it as new media found and you can easily drag and drop the files you want to utilize and will save battery on your camera as well.
Posted on Jun 24, 2010
marked
  • 6487 Answers
SOURCE: need a manual for a
You can download the user manual for this camera from this link, just click HERE.
Posted on Sep 29, 2010
Nikon Coolpix 995 gets a CF.Er card is not formated
bens pins inside on the camera , need to fix the card holder unit
easy to fix
Oct 09, 2017 | Nikon Coolpix 995 Digital Camera
Hi i've a problem.. when i put my cf 4GB in my coolpix 995, on my screen i see "out of memory" why?
Same thing happened to me. I was told the cf 2GB is compatible while the cf 4GB is not. I found the cf 2GB at walmart.com.
Mar 08, 2011 | Nikon Coolpix 990 Digital Camera
I got message "system error
Having a "System Error" message display on the camera's LCD display generally indicates a problem where the camera will need to come to Nikon for repair. A System Error is a general error which can be caused by many things: lens problem, CF Card problem, general camera failure, etc. Before sending the camera in, check these:
  1. Use the memory card that originally came with the camera (or a Nikon approved card) [/*]
  2. Remove and replace the battery [/*]
Mar 05, 2011 | Nikon Coolpix 8800 Digital Camera
Need a manual for a Nikon cool pix 995
You can download and print the instruction manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Click here to download the latest version of Adobe Reader.
Hope this helps. Thanks for using FixYa.
Sep 29, 2010 | Nikon Coolpix 995 Digital Camera
New 4GB CF card for E5400, camera gives 'out of memory' message
So far as I am aware, the 5400 will support only up to 2GB cards. As to the firmware upgrade you mention, I don't recall that that has any bearing on the max. card capacity; but it's worth doing for the RAW format support (for me, at least). Cheers and good shooting. Davo, Tas.
Oct 06, 2009 | Nikon Coolpix 5400 Digital Camera
Coolpix 995 CF Card error
My Nikon 995 began having trouble communicating with the CF card. At first it was intermittent then later there was nothing. After a couple of years of non-use, I decided to open it up to see if there was anything obvious. If I destroyed the camera in the process, no big loss. All the card slot pins were there and non were bent or coroded. Removing the drive, I could see under a microscope about half the pins on one side solder connections had broken. I assume from the repeated insertion and extraction of the card. (I use a card r/w drive in my pc instead of an interface cable to the camera). After I reflowed the pin solder connections and re-assembled the camera, all is good again.
You should know the disassembly/assembly of the camera is complex, and tedious. The connector pins are very small. I repaired the pin solder connections using a small high quality soldering iron while looking through a microscope. Witthout the scope, I couldn't even tell the connections were bad much less be able to repair them.
Jun 28, 2009 | Nikon Coolpix 990 Digital Camera
Mar 10, 2009 | Nikon Coolpix 990 Digital Camera
Blurred picture with nikon coolpix 995 macro mode
When shooting in macro to get good depth of field you often have to shoot f/22. This does not let much light in. You have to hold the camera and subject tight. Meaning the use of a firm tripod is not optional. In most cases you need a longer exposure so wiggle is very important.
Jan 20, 2018 | Nikon Coolpix 995 3.3 Megapixel 4x...
Coolpix 995
See page 162:
Informatica
Sep 03, 2008 | Nikon Coolpix 995 Digital Camera
Nikon coolpix 4600.
Hi I found this info on the Nikon Australia website:
"System Error" or "Lens Error" message in LCD monitor trnsp.gif Question My COOLPIX camera displays a "System Error" or "Lens Error" message. What should I do? trnsp.gif Answer Having a "System Error" or "Lens Error" message displayed on the camera's LCD monitor would generally indicate that your camera needs servicing. A System Error is a general error which can be caused by many things: lens problem, CF Card problem, general camera failure, etc. To troubleshoot, please try the following:
  1. Use the memory card that originally came with your camera (or a Nikon approved card).
  2. Remove and replace the battery.
On the other hand, a Lens Error generally means that an error has occured during the lens operation. To troubleshoot, please try the following:
  1. Turn off the camera.
  3. Turn on the camera.
If the above tips do not help, your camera must be sent to our Nikon Authorised Service Centres, there are no user serviceable parts in our Nikon COOLPIX cameras. We apologize for any inconvenience caused and we will do everything to repair your Nikon camera as quickly as possible. Click Here for our Nikon Authorised Service Centres details.
Seems you may just have to remove and replace the battery - sort of like a Windows Restart to fix a computer problem! - this would reset your camera's memory.
Hope this helps.
Apr 29, 2008 | Nikon Coolpix 4600 Digital Camera
Nikon Coolpix S550 10 Megapixel Digital Camera (Cool Blue) with 5x Optical Zoom + Card Reader + Niko Logo
248 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
