Question about Intel Pentium 3 933 (38l4460)
I have intel pentium 3 with 128 ram. how can i increase ram memor
How to increase ram memory
    President:
  • 1,179 Answers
To upgrade your RAM you would need to know what type of RAM your motherboard supports. Once you have this info you can then check online who sells the RAM modules. Once you make your purchase you then can remove the old modules, replace with the new modules & reboot. Hope this helps & please remember to rate my answer. Thanks.
Posted on Feb 02, 2009
Required Intel SL9CB Pentium, 3 GHz compatible motherboard
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#Prescott_.2890.C2.A0nm.29
Pentium 4 HT, Model 531. sSpec number SL9CB.
OK. So far I know you need a motherboard that has an LGA 775 processor socket; needs to support Intel processors that are Single-Core, and with an 800MegaHertz Front Side Bus.
(800MHz FSB)
Ram Memory? Dunno. K
Do know the rule of thumb is, that the Ram Memory typically operates at Half of the processor's FSB.
Therefore can only assume the ram memory is DDR Sdram, and operates at 400MHz. (PC-3200)
You haven't stated the motherboard chipset that was used, OR what computer manufacturer, and model number; this mobo came out of.
(MOtherBOard)
Also didn't state if you are using a graphics card, and what kind it is.
(PCI, AGP, or PCI Express)
This isn't a 'guess-ti-mate'. Exact specifications are required in order to replace the motherboard.
Otherwise you may not be able to reuse the Ram Memory, or graphics card. (IF used)
Awaiting needed information. Post back in a Comment.
Regards,
joecoolvette
Oct 30, 2012 | Intel SL9CB Pentium, 3 GHz
Intel(R) Pentium(R) 4 CPU 2.40GHz 512 MB of RAM. can i increase the memory to 1gb?
Yes pentium 4 supports 4gb of ram..
older system supports 2gb of ram..
So you can increase your memory to your suitable choice.
While for agp graphics cards xfx radeon hd launched 4650 agp graphics card with gddr2 memory so you can purchase it for graphics card needing 1gb memory..
Please rate me on fixya if i am helpful..
Jan 08, 2011 | Vga GeForce4 Ti4200 64MB DVIout AGP Card...
I have a DELL with XP-Home Edition - version 2002 service pack 3, Intel(R) - Pentium(R) 4cpu 2.66ghz, 2.66ghz, 512 MB of RAM My daughter plays games and has 24 of them in the computer - she tells me I...
Hello, Jim.
Dell's official position is that the maximum memory for this PC is 1 GB. But, it may be able to support 2 GB, per Intel's specs.
But, to answer your question - yes - you can increase your memory amount to 1 GB. Since the system has 2 memory slots, you could conceivably have (2) 512KB modules (total 1 GB). If your system already has 1 module of 512 KB, you could add another. Just be certain it's the same type and speed.
Or, you could have a 1 GB module.
I don't think that your computer's life is in jeopardy, but additional memory always helps the speed of your computer.
Hope this helps.
Sep 19, 2010 | Dell Dimension 2400 PC Desktop
What i can do 4 more perfomes?
Increase RAM size & turn off 'eye candy'.
The fancy effects can take a lot of grunt, and the memory is barely enough for windows and one program. If maximum memory is exceeded then the hard drive is used to cover the shortfall, which is very slow in comparison.
May 04, 2010 | Intel D101GGC Motherboard
I have intel pentium celeron 1.70ghz 256mb ddr ram, i wana upgrade it to P4, i got 8284g motherboard
8284G tells me nothing unless I want to hazard a guess, and I don't.
I like to post factual information.
8284G could be a pre-built computer manufacturer number on a label, that is stuck upon the motherboard manufacturer's printed model number, on the motherboard.
All pre-built computers have their motherboards made by a motherboard manufacturer, they do not make their own.
Or it could be a printed model number on the motherboard, but refers to the pre-built computer manufacturer model number, that they wanted printed on. Printed on for them by the motherboard manufacturer.
It could be a reference to a part number on a chip of the motherboard. An Intel 8284g which is a graphics controller chip. (Chip and chipset are slang terms for Integrated Circuit, or IC)
http://www.intel.com/support/graphics/intel845g/sb/cs-009072.htm
However though, the Intel 8284G graphics controller chipset is usually used in conjunction with the Intel i845 chipset family.
(845, 845E, 845GL, 845G, 845GE, 845PE, and 845GV)
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Pentium_4_Chipsets
The Intel i845 chipset family supports Intel processors that have up to a 400MegaHertz Front Side Bus. (400MHz FSB), and some of the Intel i845 chipsets will support processors with up to a 533MHz FSB.
So now let's look at the Intel Celeron 1.7GHz processor,
http://en.wikipedia.org/wiki/List_of_Intel_Celeron_microprocessors#.22Willamette-128.22_.28180_nm.29
1) Based on the Willamette-128 Core
2) Based upon the 180Nanometer architecture. (180nm)
3) Uses a 400MHz FSB
4) Uses 1.7 Volts (DC)
5) Uses the Socket 478 processor socket. (Processor has 478 pins, processor socket has 478 socket holes)
Based upon the processor information, and processor information only, you could use an Intel Pentium 4 that has a maximum frequency rate of 2.0GHz, and uses a Socket 478 processor socket.
I also believe it should be based upon the Willamette Core. Reasoning is that the Willamette Core Intel Pentium 4 processors, use 1.75 volts.
The next generation of Intel Pentium 4's are based upon the Northwood Core, and the 130nm architecture.
They use 1.475 to 1.525 Volts.
I don't know if you would install one of these Intel Pentium 4 processors, and your BIOS would automatically recognize it, and set the voltage to match. If not, the processor would burn up due to too much voltage.
What would you gain if you installed a Pentium 4 2.0GHz processor?
Intel Pentium 4's have twice the cache that a comparable Celeron does.
Cache. Crude explanation:
You are writing a thesis, and you need more information. The information is located in books, which are in the basement in a box, and there is no light in the basement.
Down you go with a flashlight in hand, locate the box, and look through the books until you find the book you need.
Back upstairs you open the book, and find the page/s you need for your information.
You find that not all the information you need is located in that book, and back downstairs in the basement you go, flashlight in hand.
OR, you press a few keys on your keyboard, of the computer in front of you, and have your information is seconds.
Low cache is the basement scenario.
Large cache is the computer scenario.
The processor cache is a small memory area for the processor. It operates at the same frequency rate as the processor, therefore it is the fastest memory area available for the processor. It is also the first memory area the processor 'sees'.
Ram memory is next, followed by the harddrive. The harddrive is slower due to it being a mechanical device. (SSD or Solid State harddrives are faster than the mechanical IDE and SATA harddrives. Still not as fast as Ram Memory though)
The .3GHz increase, and the cache increase will be a slightly noticeable difference.
Enough to "Write home to mom about?"
Nope. Not IMHO.
You probably won't notice any increase when on the internet, or doing school/business work.
You differently won't notice any real increase when gaming.
To summarize:
The amount spent, and the time looking, for an Intel Pentium 4 processor that is 2.0GHz, and based upon the Willamette Core, just won't be worth your trouble.
Unless someone just gives you one.
Mar 22, 2010 | Intel Celeron -D 2.26Ghz Computer System...
Computer problems
You have to increase the RAM in your computer and then also increase the virtual memory in your computer. This will solve your issue.
Nov 19, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Ram upgradation for Intel(R) Pentium(R) D CPU 2.80GHz
You defiantly need to install the maximum ram the PC will hold and be able to use. Simply go here: http://www.crucial.com/ On that page click the "Scan My Computer" tab and allow the download of the scanner. It will safely scan your computer and tell you exactly what you can install and the price.
Nov 14, 2009 | Cars & Trucks
Whether INTEL 810 motherboard supports ddr2 ram of
The intel 810 motherboard will not support DDR2 memory.
Intel Pentium 3 Socket 370 SDRam PC100 Ultra DMA100 Motherboard With Onboard Video / Sound & LAN! For Intel Pentium 3 Processors (CPU.
This board will only support SDRAM PC100
Oct 01, 2009 | Intel Motherboard
Graphics
1) enter bios
2)make changes in shared graphics to 128 mb
3) increase the size of page sys file allocate more ram to page.sys file by going into rt click my computer/properties/ performance/
4 u can change your windows system to 64 bit.
Sep 19, 2009 | Intel D945GCCR Motherboard
Problem with running GTA4
you can use GTA4 in your system.If their is any problems in playing increse tha virtual memmareof tour system
Jun 16, 2009 | Intel Pentium D 915, 2.8 GHz (BX80553915)...
Intel Pentium 3 933 (38l4460) Logo
85 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
