Question about Amana AMV5164 Microwave Oven
Moved oven. Keypad can not set time. Amana RRL 9TC
I unplugged and moved our countertop Amana RRL 9TC to another counter and plugged it back in but now I can't set the time with the keypad. Reset just flashes the dashes. One key flashes when pushed but rarely do others. The RandarRange level button in the center near the bottom makes all of the icons and digits illuminate on the display contstant until pushed again. Light button works.
  • Amana Master
  • 9,098 Answers
After so many years, the electrolytic filter capacitors dry out and these become more susceptible to disruptions and glitches.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, I would say your control unit (called the "net module") needs to be repaired or replaced.
If this item is available anywhere, it may take several weeks to get and will likely run well over $150.00.
If you decide to look for parts, the proper model number format is RRL-9TC and it also has one of four manufacturer numbers on its tag: P7553302M, P7553303M, P7553304M, or P7553306M.
Be sure to have both numbers handy.
The original part numbers for the net module seem to have been R0163049 and then R163079A.
Good luck.
Posted on Feb 02, 2009
My Advantium 120 microwave shows the time, but none of the buttons respond to being pressed.
Try turning it off at the power switch,leave off for several seconds then switch it back on, it may reset the control unit, if not take it to a repair outlet,
May 27, 2015 | In Microwave Ovens
Why won't the turntable turn?
this model DOES use a probe,look inside for a port,like a headphone plug,unplug your microwave and use a couple toothpicks and gently push thenm into hole and move around to make sure no food is in there,then plug back in and try,or reset,do not touch accu temp,if still nothing then there is a bad plug,here is your manual,,
http://www.manualslib.com/manual/733847/Amana-Mvh330.html?page=2#manual
Mar 21, 2015 | Amana MVH230 Microwave Oven
How do you stop, reset or change the remaining time on the Timer on the GE JES1142 microwave? Pressing Clear/Off does nothing. Do you just have to wait for the timer to run out? Manuel is wrong even on how...
If that doesn't work, leave it unplugged for about 5 minutes.
Oct 27, 2013 | GE JES1142SPSS 1.1 cu. ft. Countertop...
After a power surge, the display comes on. Yet, the buttons do not work. Is there a button to reset?
Is this a one time event? Try unplugging the unit from the wall for at least one hour and plugging it back in. Open the door and close it. I'm not familiar with this particular model but I have to guess that you push the stop/reset button to set the clock after plugging it in. It may be a bad touch pad or a bad door sensing switch.
Sep 19, 2013 | Danby Designer Series DMW077BLSDD 0.7 cu....
My amana model number amv1150vas is not working after a power outage
Unplug for 60 seconds to see if it will reset, if no! the fuse in the microwave has opened/ or if the model is the new type, it is the keypad control board or smart board.
Apr 05, 2012 | Amana Microwave Ovens
Microwave model number: 721.80593402. There seems to be a problem with the control pad. It will start but the stop/clear button isn't working....
If that doesn't work, leave it unplugged for about 5 minutes and try again.
If it still doesn't work, then your membrane keypad has failed.
If the keypad is available separately and
you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
If this model's keypad is not available separately, you would need to order the control panel frame, which comes with a new keypad.
In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors on the relays may have a lock:
Feb 16, 2011 | Kenmore 80809 Microwave Oven
My amana microwave reads se and fan runs on its own. the keypad will not repsond at all. When unplugged for day then plugged back in works for few times then backl to same thing. Cant afford to replace it....
"SE" error means you have a shorted membrane keypad.
You have a shorting membrane keypad. If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and of course one should never leave a microwave unattended while cooking.
In most cases, it's economical to repair this problem, and many DIYers can do it.
But we would need your full model number form the tag in or on the unit to steer you further.
Please make a new post or contact me directly with your full model number.
Jan 27, 2011 | Microwave Ovens
Model-MH3184xpb-0 Lock symbol on keypad, continuos beeping. I unplugged power for now
If it still fails, you have a failed membrane keypad.
On this model, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
That is a simple do-it-yourself job, and the part is very affordable.
It is part number 8205376 and you can get it from the Pros here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven (as MH3184XPB0 with no dashes) here.
If photo does not appear, it is located here.
Jan 16, 2011 | Whirlpool Microwave Ovens
I'm trying to find a replacement glass tray for my Amana microwave oven. The model number is RRL-10TD. The date on the back of the oven is 1982.
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy
Appliance Parts Online
heatman101
Jan 11, 2011 | Amana Microwave Ovens
Amana radarange built in...read out asks for PM or AM but keypad will not work
Otherwise, you may have a bad keypad.
Note your full model from the tag on the unit and check here for more information.
Aug 22, 2010 | Amana Microwave Ovens
Amana AMV5164 Microwave Oven Logo
137 people viewed this question
Top Amana Microwave Ovens Experts
William Miller
William Miller
Steven Clarke
Steven Clarke
foster_mommy
Level 1 Expert
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
