Question about Indesit WA 115 Front Load Washer
Wi 101 INDEST
Hello, My washing machine is constantly filling with water and the water is draining away. The programmer is constantly clicking round... Have you any suggestions as I cannot find my manual. Thank you, Julie
  • 67 Answers
You might have a pressure switch problem due to a blockage in the sump , but more likely the fault is down to tracking on your control board. You might be lucky and find that if you take the board out and clean it around the the botttom of the printed side it might just work, failing that I suggest you call an engineer
Posted on Aug 02, 2007
  • haartz Nov 11, 2010
    REMOVE PLUG FIRST!!!
    Thanks so much for this advice. Checked out the edge connectors on the module (remove REAR panel to locate- - L hand lower corner) and found a patch of corrosion between two connectors. Cleaned it away (carefully) and re-assembled and hay presto all is sound again. :)
    Saving £200approx for new machine
Switch the machine off, turn the dial to stop (end of cycle). Turn the machine on again. This should reset it hopefully. i am no expert but it will take seconds to try. Stu
Posted on Sep 08, 2007
  • 38 Answers
Your module is blown and im afraid this problem is terminal due to the price indest want 4 a new board it is not worth repairing sorry but scrap it
Posted on Aug 06, 2007
Hotpoint aquarius washing machine
Try unplug from electrical outlet wait 15 minutes and plug it in. If you are lucky it will reset. If you are not lucky it sounds like the circuit board may be damaged.
Apr 24, 2014 | Washing Machines
Washing machine constantly fills
The pressure switch, also called the water level switch, is what control the amount of water goes in the machine, If your machine is constantly filling to the overflow point, then that is your problem. Now, if water is going in and the level is staying the same then your machine drain line is lower than the pump and your siphoning out the water as it goes in. Pull the drain up a little a that should fix the problem.
May 08, 2012 | Whirlpool Clothes Washer Water Level...
How do i program a replacement pc board controller
For module configuration information on Hotpoint WMA range of machines go to www.selfix-uk.co.uk and click on the ERROR CODE link.
Feb 29, 2012 | Hotpoint WMA40 Front Load Washer
The washing machine fills constant and water drains out straight away.
your drain hose is installed incorrectly. it rise at least 36" or so (preferably higher) before it enters the stand pipe (drain pipe connected to the houses plumbing), and there has to be an air break (i.e., not sealed off where the drain hose enters the stand pipe). hope this helps.
Mar 06, 2011 | Washing Machines
The washer will not drain or spin
more than likely the pump needs replacing, first of all remove the outlet drain hose from the the place it discharges and lower it into a bucket,this should allow it to syphon away,you may need to empyt the bucket a few times once the machine is empty you should be able to put it on its spin cycle once it has spun locate and remove the filter to remove any objects or lint, fill machine with warm water and try to drain and spin via the programme,if this do not work fit a new pump
May 29, 2009 | Kenmore Washing Machines
Problem with a indest wil143s
it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
May 06, 2009 | Washing Machines
Bosch classixx 1200 express
Not a programme error but carbon brushes on motor.Fixed by local engineer.
Aug 30, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Machine filling and then immediately draining
Hi You need to higher your outlet pipe on the back of the machine there is usually a clip to hold the pipe in place 3/4 of the way up the machine so it looks like a u upside down its should stop the machine from emptying straight away
Apr 29, 2008 | Zanussi ZWF1430W Front Load Washer
Running water
Sounds like your stand-pipe has fell over,located behind machine that the drain hose goes into.This pipe must be vertical,and secure.The top of the washers drain hose loop that goes into the stand-pipe, should be as high as your soap dispenser.If this is not the problem then your water pump must be pumping the water out all the time.Can you hear the pump? If so, some faults can force the washing machine into a constant cycle of filling with cold water and pumping the water away if it thinks the washing machine is overheating (possible faulty thermistor).Hopefully its only your stand-pipe causing the loss of water.Lets know how you get on.Good luck.
Sep 05, 2007 | LG WFT1071TP Top Load Washer
Indesit WA 115 Front Load Washer Logo
213 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
