Question about GE HSM25GFTSA Side by Side Refrigerator
Our refrigeraters water dispenser is not working.
The water button lights up, but the water is not coming out when you push the lever back. Can you give me any ideas for whats causing this problem?
  • 360 Answers
If the filter has not been replaced in a while, replace it. if this does not correct the problem then the problem will most likely be the switch or relay.
Posted on Feb 03, 2009
The water dispenser on my GE fridge, model bss25jsrss, doesn't work. There is water in the lines, and the lights in the front work, but when I try to get water or ice nothing comes out.
There is a simple switch behind the push lever which activates the water/ice dispenser circuit. Sometimes these switches are poorly engineered to the lever with an adhesive or plastic rod which will break away. This is the first place I would look for a culprit.
Sep 25, 2011 | GE Refrigerators
No water is coming out of the water depenseron the refrigerater
does your ice maker work OK ? if yes , do you have a inline water filter in the upper right hand section of your refrigerator at the rear ? if yes , replace the filter and follow the directions on the new filter to properly prime the water dispenser line. if the unit will not prime with the new filter installed, you'll probably have to replace the water dispenser control valve located at the bottom rear of the refrigerator where the main supply water line goes into the refrigerator.
Mar 17, 2010 | Refrigerators
The water dispenser does not work properly. The light does not come off of the cubed ice button. To get water, I push the water button and without pushing the lever, water starts coming out. To stop it, I...
You have a bad main control board . The new pt # WR55X10656 . The dispensor board is not communicating with the control board . However , check this site to see if it can be replaced under warranty .
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter .
Nov 15, 2009 | GE GSH25JFR Side by Side Refrigerator
Ice & Water Dispenser Suddenly Dysfunctional; LED lights, too!
Cory, you sound like you have a bad water valve as well as a bad control board for your dispensor. If you've had any storms in your area in the past 4 - 6 weeks, it's very possible that the storm took both parts out.
We have parts for GE as well as mots other major brands, so please give us a call with your complete model number and we will get your parts out to you right away!
We hope this solves your problem and we look forward to being able to assist you with future issues.
Have a great evening.
Nov 05, 2009 | GE GSS22JF Side by Side Refrigerator
Kenmore Elite refrigerator ice and water dispensers not working
check for a child lockout button it will look like a tiny padlock ,press and hold for 3 sec.(could be the freezer door light switch)
Jul 24, 2009 | Refrigerators
Water dispenses without pushing lever
There is a solinoid valve that opens when you push the switch in. It has apparently failed and is leaking. Sometimes taking it apart and cleaning it will fix the problem.
Jan 28, 2008 | Kenmore 53542 / 53544 Side by Side...
Water Dispensing System
Check that the dispenser is not locked. Some models have a lock feature that deactivates the dispenser levers and control buttons. The lock button is on the dispenser front cover. This feature controls unintentional dispensing during cleaning. Press the "Unlock" or "Locked" button to reactivate the dispenser levers and allow dispenser function. You may need to hold the button for 2 to 3 seconds.
http://whirlpool.custhelp.com/cgi-bin/whirlpool.cfg/php/enduser/std_adp.php?p_faqid=110&p_created=1147725595&p_sid=lTIkCMOi&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MzEmcF9wcm9kcz0xOTkmcF9jYXRzPSZwX3B2PTEuMTk5JnBfY3Y9JnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9d2F0ZXIgZGlzcGVuc29y&p_li=&p_topview=1
Oct 20, 2007 | Whirlpool GC5SHEXN Side by Side...
GE GSH22JFRE WW not dispensing ice
Deb, sounds like your dispenser control board has given up the ghost. The boards come in 2 models, 4 button and 5 button. The 4 button part # is WR55X10443 (~$87.00)... the 5 button part # is WR55X10437 (~$97.00). Not too difficult to replace. UNPLUG YOUR FRIDGE!!! Remove the drip tray from the dispenser, and any screws hiding in there. Then, using a flat screwdriver and starting at the bottom of the fascia, pry the fascia away from the door and remove. Then remove the screws holding the control in place and disconnect any wiring. (Don't forget to pay close attention to WHERE the wires connect and HOW the wires are routed!) Then install the new board and rebuild. Approx. repair time for your first one is ~1 hour. Good luck!
Sep 24, 2007 | Refrigerators
Icemaker and water dispenser
Mine did the same thing.  Other web sites said it was the motherboard.  I replaced it and now it works great.  The part number is: Hotpoint Refrigerator Main Control Board Assembly WR55X10552best deal was at http://midwestapplianceparts.com
Sep 10, 2007 | Hotpoint HSS25GFP Side by Side...
GE HSM25GFTSA Side by Side Refrigerator Logo
255 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
