Question about Dell Inspiron 8200 Notebook
Touchpad on my 8200 insprion stop working
My touchpad on my 8200 insprion stop working. my mouse work fine when i pluge it up. please help me
  • 3 Answers
I would first check f2 at startup and mak sure it is turned one
Posted on Apr 08, 2009
    Scholar:
  • 116 Answers
Try to test it using 32 bit diagnostic
tap F12 (just after Dell Splash Screen)
select Diagnostic partition
wait for test to finish
select Custom test (may need to use TAB and ENTER)
select pointing device
if it work here, it is likely a driver issues - got to support.dell.com and download latest pointer drivers (Alps under Input Devices?) You may as well do this first since it is easier than testing see http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=22&l=en&s=dfh&os=WW1&osl=en&catid=&impid=&SystemID=INS_PNT_P4_8200
If it does not work her, you'll need to pop it open and see if cables are tight, if they are the touchpad is broken and you'll need a replacement palmrest (included the palmrest)
see the manual at support.dell.com for info on disassembling your model if required.
Posted on Feb 03, 2009
HP 2530p EliteBook - touchpad stopped working. Scrolling works except touch scrolling on right side of pad) and right button, but that's all. Wireless mouse works fine.
To access Mouse Properties, select Start - Control Panel - Hardware and Sound -Mouse.
Use Mouse Properties in Windows to customize settings for pointing devices, such as button configuration, click speed, and pointer options.
Jan 18, 2013 | HP EliteBook 2530p Notebook
My touchpad stopped working on my acer 5532. I
> you just have to reinstall driver for your touchpad but if after doing that and still not working then touchpad might be busted
> sometimes a certain software might be causing the touchpad to not work and restoring computer to factory default might resolve the issue but this will cause your files so do a back-up first
> to get the driver for your touchpad please refer to your manufacturer or to the website of acer
Jun 05, 2010 | Computers & Internet
Touchpad stopped working on acer aspire 5517 Laptop
make sure the mouse pad switch is not turned off.
Mar 31, 2010 | Acer Aspire 5500 5570-2609 Laptop
Virtical mouse pad on my pavilion dv7 won't work.
Reinstall the touchpad drivers (from www.hp.com) Most of these will not work without the driver, my dv9000 is the same way.
Apr 29, 2009 | HP Pavilion dv4000 Notebook
Mouse pad
you would be better off using an optical mouse that has a usb or ps2 connector ( depending on what your laptop supports ) usb would be better though less chance of pins bending as there are none on a usb connection ( at least not like a ps2 connector )
Also download the latest drivers for the touchpad and make sure that the scrolling options for or on the touchpad are not configured too thickly which will be in the touch pad settings.
Apr 15, 2009 | Dell Inspiron 8200 Notebook
How do i operate the mouse on a toshiba 8200
hi, you probably have to disable the touchpad, for the microsoft mouse to work properly, i had same problem on my notebook. i conflict of software for touchpad made my microsoft cordless mouse not work, until i removed the touchpad software. i hope this is helpful,good luck!
Feb 13, 2009 | Microsoft Wireless Optical Mouse
Mouse touch pad problem Lenovo Y410 model notebook
Just above my keyboard there is a little black strip with little lights.
they are control buttons and if you tap one of them it turns the touchpad off and on (so it's very easy to do accidentally).
 If you look really closely at the strip in good light (or restart the laptop to see them flash on and off) you'll see that one looks like a touchpad crossed out. Just press this to get your touchpad back.
If it doesnt solve the problem, I have noticed that the touchpad can be knocked out by a Window Update of something called ideacom. If you believe this could be the problem please clarify.
Jan 28, 2009 | Lenovo 3000 Y410 Laptop
Mouse or touchpad not working
add an external mouse/keyboard to fix the onboard fault.
check the device manager for any yellow exclamation marks. as there may be a faulty or corrupt. keyboard/mouse touchpad driver.
other option, is to add remove touchpad drivers, and re-install.
finally, you could check if the settings are correct in the bios.
Thankyou For Using Fixya.
Mike @ compurepair.
Jan 05, 2009 | Toshiba Satellite A105 Notebook
Mouse does connect but keyboard does not, vice versa
reinstall the logitech cd which came with keyboard and mouse, with the mouse pluged in. once reinstalled restart and while restart plug the keyboard in..... this should resolve the issue.
May 29, 2008 | Logitech Cordless Desktop MX 5000 Laser
Dell Inspiron 8200 Notebook Logo
174 people viewed this question
Alun Cox
