Question about Brother IntelliFax-2820 Laser Fax
Brother 2820 fax machine
Msg keeps coming up to change drum...I have no idea where this is on the fax...please help
  • jhessy Feb 24, 2009
    i already replaced the cartridge with a new one..and still showing emply toner..pls help
  • 726726 Feb 28, 2009
    my fax machine is saying to clean drum, remove drum and clean the corona wire.
    Champion:
  • 320 Answers
THE DRUM AND THE TONER CARTRIDGE IS IN SIDE OF THE MACHINE.OPEN THE COVER AND YOU WILL SEE THE DRUM CARTRIDGE,TTAKE OUT THE DRUM UNIT. ITTELLS YOU ON THE DRUM UNIT THE NUMBER DR    IT IS SOLD IN OFFICE DEPOT OR OFFICE MAX OR STAPLES, MAKE SURE THAT YOU ONLY USE BROTHER PRODUCTS. GOOD LUCK BROTHER SR TECH
Posted on Feb 03, 2009
KUWIT OIL COMPANY IAM FACING PROBLEM IN FAX MACHINE BROTHER 2820 MESSAGE SHOWS 'TONER LIFE END' AFTER CHANGING TONER MESSAGE REMAIN SAME PLEASE GIVE ME SOLUTION. I HAVE AROUND 24 FAX MACHINES BROTHER...
you must have remove the white mylar sheet from the catridge when loading it...if yes! you got to find back the white mylar (plastic sheet) that slot in between the drum and charger roller placed it back ( the position must be accurate) then slot in back the catridge.The white mylar sheet is to reset the drum life counter
Jan 26, 2011 | Brother Office Equipment & Supplies
Hi. We have about 6 of the Brother 2820 fax
CAN U PLEASE CONTACT ANY SERVICE CENTRE NEARBY U,
May 25, 2010 | Brother IntelliFax-2820 Laser Fax
HOW DO YOU TURN OFF DRUM LIGHT ON BROTHER 2820
Open front cover....press 'options', and select 'new drum'
Nov 11, 2009 | Brother IntelliFax-2820 Laser Fax
How do I clean the drum of a brother fax machine?
Move the blue slider on top of the cartridge side to side 10 times.
Mar 03, 2009 | Brother IntelliFax-2820 Laser Fax
Brother printers 2820 paper coming out fouled
Pull toner and drum cartridge out by folding front door down and seperate the toner from the drum by pressing the blue lever. re-insert the toner into the new drum. After installing the cartridge back into the printer, leave door open and press the clear button and on the LCD screen you will see for new drum press 1 for yes and 2 for no. Press the 1 button and close front door. Finished. Please rate my help if this fixed your issue. Thanks!
Feb 15, 2009 | Brother IntelliFax-2820 Laser Fax
Change toner error brother 2820 mach has new brother toner ctg
with machine on, open front cover, press the "options" button, you should see "replace drum?" press the "start" key then 1 then 0. display should show accepted for a couple of secs. then show cover open. close front cover and message should be gone. if not, you will have to contact Brother.
hth,
razors
Jan 23, 2009 | Brother IntelliFax-2820 Laser Fax
Intellifax 2820 plain paper fax
Take it out with the drum unit and make sure the toner is in the drum unit right. If it was ok before you changed the toner then you did something wrong. reinstall the drum and toner after you check it. Lawrence
May 01, 2008 | Brother IntelliFax-2820 Laser Fax
Brother 2820
The toner cartridge is in the drum unit. push the blue lever and the toner pops out, make sure you have a toner cartridge in the drum unit. Lawrence
Apr 23, 2008 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
565 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
