Back to:
Tags:
Toshiba e-STUDIO 16 Printer
Cannot print to local printer when logged into... (by 2 users)
By Charlie - usenet poster
I have a client who has a real weird problem:
Here are the specs:
2000 AD domain, latest patches and service packs
6 Windows 98SE workstations
1 XP Pro workstation
HP Laserjet 6L printers
Toshiba estudio16 MFP with built in print server
When the XP machine logs on to the network (I do not have this machine
logging on to the domain, just set it up as connecting to a workgroup, the
user doesn't like the restrictions that being a domain user produces), they
can print to the network printer (estudio 16), but not to the 6L attached
locally to the XP station. The print job goes out, nothing in the queue, but
no printing.
If I unplug the network cable and restart, he can print to the 6L. Once I
plug the the cable in and login to the network, local printing is gone
again.
Any thoughts?
Posted via Newsfeeds.Com, Uncensored Usenet News
# - The #1 Newsgroup Service in the World!
Over 80,000 Newsgroups - 16 Different Servers!
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by peter892, posted on Jul 03, 2008
I have the same. Local XP machine with TEC B-572 printer connected to LPT1. It prints when logged into the local machine. It does not print when logged into the Domain even with Administrator rights.
If I change the settings in the port (device manager) to "Use any interrupt assigned to the port", it works correctly..... but only until the machine is turned off. Then it fails again. To make it work again, I have to change the settings in the port back again, reboot and then change back to "Use any interrupt assigned to the port" again. So a clue, but not a workable fix. Looks like an XP problem to me.
Best Solution
posted on Nov 26, 2007
FixYa! (100)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
well I am having the same problem, try copying the local administrator's profile to the default user.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Cannot print to local printer when logged into network:
I don't want to Accept this solution
Can you Help with these Printers problems?
Printers
i have a ph Photosmart c5580 printer I can't print with...
Printers
How do I load an ink cartridge in my Canon printer.
I have been told that the polygon mirror motor in my...
i have a epson stylus cx4200 printer . i got new ink...
Glass copies are perfect. Reversing copies have a...
Loading problems.
Repair Service
Find Printer Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
