Question about Radio Shack Pro-95 Handheld Scanner
Unit (Pro 95) will not scan trunk tracker stations at all. I have programmed this radio many times previously and it seems that the programming ROMs are misbehaving. The radio works fine in all modes except trunktracking EDACs.
  • 514 Answers
Go to page 23 of the manual (at "http://support.radioshack.com/manuals/ome20-525.pdf" if you don't have it) it has some cures that you can try there. good luck!
Posted on Mar 09, 2009
I Havel a pro-95 scanner and I have frequencies programmed into banks 1 thru 6 and the scanner isn't scanning banks 2 thru 6
Make sure the banks are enabled and the frequencies in the banks aren't locked out. If you are scanning trunked systems make sure the control channels are set up properly.
Keep in mind you cannot scan digital systems with this scanner, only analog systems and frequencies.
Pro 95 The RadioReference Wiki
Mar 07, 2017 | Radio Communications
Need instuctions on how to program hand held scanner
Detailed programming instructions are in the factory manual which you can download and print, at no cost, here:
http://scancat.com/OnLineHelp/OEM_Radio_Owners_Manuals/RadioShack-OlderManuals/Pro-95/pro95.pdf
You may also want to visit www.RadioReference.com for a comprehensive database of frequencies and trunking systems in use in your area, and a lot of other useful scanning information - including programming software that will let you load trunking systems without spending hours punching keys.
Bill B.
Listening in since the 60's
Dec 15, 2010 | Radio Shack Pro-95 Handheld Scanner
How do I program it for triple truncking?
There is no such thing as "dual trunking" or "triple trunking." Such terms are used by manufacturers to indicate the number of trunking systems that a scanner is capable of monitoring. The PRO-95 is designated as a Dual Trunk-Tracking scanner because it is capable of monitoring both Motorola and EDACS systems. Programming a trunking system in to a scanner is a detailed process that requires a bit of research.
For details on active trunking systems in your area, and a lot of other useful scanning information, visit:
Once you have the system information you can follow the programming steps outlined in your scanner's operating instructions. If you don't already have the manual, you can download and print it here:
Bill B
Jul 24, 2010 | Radio Shack Pro-95 Handheld Scanner
HOPKINSVILLE KY. POLICE DEPT. CHANGED TO A
Unfortuantly the pro-82 is not a trunked scanner, it's only a vhf/uhf scanner and cannot pickup trunked systems. You need to replace it with atleast a pro-95 to pick up trunked systems. If you need your manual for the pro-82 follow this link.
http://www.radioshack.com/graphics/uc/rsk/Support/ProductManuals/2000315_PM_EN.pdf
Feb 19, 2009 | Radio Shack Pro-82 Scanner
The scanner doesn't want to scan?
When you first turn on the pro 95 and the dual trunking screen is still on insert (gently) a pin or straightend paper clip in the small hole just above and to the right of the external power plug. That will reset the radio. Once it is reset (wait until it finishes resetting) you may need to initialize it. Turn it off then back on, while it is still displaying the dual trunking screen press "0" and then the "1". Do not turn the radio off until the Initializing is finished.
Now re program your radio if you with to use the "SCAN" button. Other wise you should be able to use the "search" button to select the service you wish to listen to.
Hope this helps.
Nov 08, 2008 | Radio Shack Pro-95 Handheld Scanner
BC245XLT trunk tracker II
Hello majorhart, I have never owned this model scanner, but by looking at the owners manual I see there is a keylock, which locks the keypad.
If you need a copy of the manual, go here and download.
http://www.uniden.com/pdf/BC245XLTom.pdf
I hope this helps out with what you were looking for,,Mechanc.
Oct 17, 2008 | Uniden BC72XLT Handheld Scanner
Completely locked up
Are you pressing the "SCAN" button?
Try pressing the "search" button on the bottom left of the key board. If you want to use the "SCAN" button you need to program frequencies into the banks.
This may be a little overkill but it doesn't hurt.
Hope this helps.
Sep 30, 2008 | Radio Shack Pro-95 Handheld Scanner
Scanning Frqs but not IDs
Hi - You can download the manual from the link underlined in blue below:
Pro-95
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Aug 13, 2008 | Radio Shack Pro-95 Handheld Scanner
Pro-95 dual-trunk scanner
Here is the online programming tutorial:
http://support.radioshack.com/support_tutorials/communications/200-0523/67345.htm
Here is the full manual Should include Quick guide:
Here is FREE programming software for the PC:
Includes hardware info. You can buy programming cable at Radio Shack to connect to your PC.
http://www.starrsoft.com/freeware/win95/default.asp
Aug 01, 2007 | Radio Shack Pro-95 Handheld Scanner
My 95 is way off - Freqs,Mode not working...Grrr!
mORE AND MORE POLICE AGENCIES ARE SWITCHING TO "DIGITAL TRUNKING". I CAN ONLY PICK UP PARTS OF MY LOCAL SHERIFFS STATIONS. RADIO SHACK HAS THE NEW dIGITAL TRUNKING SYSTEMS THEY COST ABOUT $500. I AM UP GRADING NOW. FOR TRUNKING ... WHEN YOU GET A ACTIVE CHANNELL KEEP HITTING THE RED TRUNK BUTTON TILL YOU SEE THE MOTOREOLA 5 NUMBEWR ID.THJEN HIT ENTER. I WANT THE NEW PROGRAMER THAT IS FAST ENOUGH TO FOLLOW DIGITAL HYPER-TRUNKING. ALL POLISE ARE GOING TO IT EVENTUALLY.
Sep 18, 2006 | Radio Shack Pro-95 Handheld Scanner
Radio Shack Pro-95 Handheld Scanner Logo
176 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
