Question about HP Photosmart C7280 Printer
HP Photosmart 7280 fax
My 7280 will fax locally, but not long distance.
    Scholar:
  • 169 Answers
Plug the phone line into a telephone handset and then try calling someone long distance....this will help you to isolate if its an issue with the printer or your phone line....i think you can contact your telephone service povider for the same they will help you out in an efficient manner
Posted on Jun 25, 2009
Hp photosmart will only fax locally
first can you make long distance phone calls. have they been bared from your service ??
Apr 23, 2014 | HP Photosmart Premium C309A All-In-One...
Photosmart c 7280--light cayan-- how do you clean heads-?
There is an option within your printers software " Head Cleaner "
Run that and it should fix your problem
May 20, 2010 | HP Photosmart C7280 Printer
HP 7280 can't find the fax log
On the printer itself hit the setup button (the one with the little wrench)
Then go to print reports and press ok
Then to fax log and press ok.
Jan 15, 2010 | HP Photosmart C6180 All-In-One InkJet...
I can fax to local numbers but not to long distance numbers. Phone company has no clue.
Your problem is how you have set up your long distance carrier. You may not be able to use your fax if you must first go through a phone card system. However, sometimes you can use enough pauses in your fax dialing to get through it. If your long distance carrier is your local phone company, they SHOULD be able to tell you how to dial.
Oct 12, 2009 | HP OfficeJet 7310 All-In-One InkJet...
My HP 7280 printer has suddenly stoped printing on both sides
ONCE YOU HAVE THE DRIVERS INSTALLED DO THE FOLLOWING:
Go to START >> SETTINGS >> PRINTERS AND FAXES. Right click the printer in the PRINTERS AND FAXES window and go to PROPERTIES. Click the DEVICE SETTINGS tab Change the DUPLEX UNIT (FOR 2-SIDED PRINTING) to INSTALLED
Aug 06, 2009 | Office Equipment & Supplies
My printer copy fax scan and photo card light
Unplug and replug the printer power cable if the issue still persists call in to hp at 1800 474 6836 and ask the representative for an upgrade and go in for either
the photosmart 7280,photosmart
6380 or the photosmart 8180.
You will get it at a 50%
discounted rate.Its called a
refurbished printer but the
actual scenario is that if
wallmart purchases 100
printers and realises they
needed 99 they send one back
to hp and then our factory
test it before sending it out
to the customer but it has
never been used before.
trust me this is the best
option.I work for HP.
call in and hope you get me on
the call.If the printer is in
warranty then hp will try a
couple of troubleshooting
steps and if they dont work
then they will replace the
printer free of cost. Cauz this could be a hardware problem
Jun 15, 2009 | HP PSC 2210 All-In-One InkJet Printer
Fax answers on phone calls.
Hello There. Most household all in one units cannot operate on the ring characteristcs that you are describing.
They simply operate on the number of rings before automatic pickup to the fax machine. Therefore, you will need to just change the number of rings before the fax machine picks up. In this case however, you will not be able to use voicemail, since one or the other will will pickup.
http://h10032.www1.hp.com/ctg/Manual/c01102249.pdf
Page 63 and 64 (in PDF) or page 62 and 63 (hardcopy manual) explain the process.
Ignore the information about setting higher then voicemail. That information is typically only valid if you have the old voicemail devices in your home. Most people now adays get a voicemail service added to your telephone service, in which case you cannot control the voicemail as easily.
So again, in other words you will be sacrificing your voicemail for your fax machine. Only other way around it is to get a dedicated fax line to seperate the two numbers.
Feb 26, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP 7280 fax interrupts phone calls
Set the fax to MANUAL MODE, you will then have tp press START to receive a fax.
Dec 21, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C7280 Printer Logo
94 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
