Question about Conair HC100RCS Hair Trimmer
I lost one screw when I was trying to clean con air hair trimmer.
    Problem Solver:
  • 9 Answers
YOU CAN USUALLY CALL OR LOOK UP COMPANY AND THEY WILL SEND YOU OUT A NEW ONE. OR TRY A EYE GLASS REPAIR KIT.
Posted on Jun 06, 2009
Hair trimmer vibrating too much
I also use Philips Norelco Trimmer doesn't vibrate. It's rechargeable so has a "rotary" motor instead of a "vibratory" mechanism. It does a great job on my beard, though I have not tried it for the hair on my head.
you must try it.
Jul 10, 2017 | Braun Health & Beauty
Won't cut anything
we have had this problem many times with our hair clippers
take off the outer blade and make sure it is all clean and there is no hair within the working when rebuilding add a little regular household oil
on the side of the trimmers there is usually a little plastic screw built into the casing this is the motor adjustment turn it until the trimmers become noisy then turn back half a turn so it lowers the noise out put hence the motor speed hopefully this should work
Dec 14, 2011 | Conair HC117 Hair Trimmer
Why my andis outliner not cutting
Try cleaning the head cutter below the main stem. Remove screws and clean old hairs in there, also lubricate.
Thanks
Jun 13, 2011 | Andis 04603 Hair Trimmer
What's the role of the "power screw" ????
To adjust clipper/trimmers to run to their voltage needs. If clipper/trimmer rattles or over vibrates it may need adjustment to the line voltage in your area. Before adjusting, make sure the clipper/trimmer is clean and blade is oiled. Then turn the SMALL power screw clockwise on the side of the clipper until the noise disappears.
Mar 14, 2011 | Andis 01690 Hair Trimmer
I have lost my charger for the Remington BKT2000 hair trimmer do you know where I can get a new one?
Hey I don't know if you still need a power cord but I have lost the hair trimmer and have a spare cord! If you would like it just message me on ebay - queen_of_belgium_dips is my username. I can sell it to you through this if you have an account. £0.50 +P&P (as it is pretty useless to me!)
Aug 16, 2010 | Remington BKT-2000 Hair Trimmer
Hair stuck between blades...repeatedly
They are garbage.....it's a common problem. Call the manufacturer
Aug 01, 2009 | Andis 01690 Hair Trimmer
How to repair my hair trimmers?
I am a retired hairdresser and it sounds like one of three things or a combination. Your blades may be worn (dull) and need replacement , it may need to be oiled,the blades could be "misaligned" and need to be adjusted. You do that by removing the two screws holding the blades on, remove the blades, while you have them off, clean out any built up clippings in there and then put the blades back on. BEFORE you tighten down the screws make sure the "teeth" from the blades are lined up so the bottom blade teeth can be seen BETWEEN each top blade tooth. NOT directly on top of each other. Now tighten the screws. urn the clipper on and add a drop of clipper oil (no substitutes) onto the running blades. That should do the trick.
Jul 20, 2009 | Andis Outliner® II 04603 Hair Trimmer
HOW TO CHANGE BLADES ON CONAIR HCT 426 HAIR TRIMMER
digram on how to replace my blade in my hair trimmer conair hc3180v
Feb 01, 2009 | Conair HCT-426 Hair Trimmer
I tried to clean the blades but now it wont cut and also it sounds tremendously loud
are all the screws tight? Sometimes my screws on my blades come loose and I can't tell until all of a sudden they fall apart in a clients hair
Jul 18, 2008 | Oster 76076-010 Hair Trimmer
Trimmer malfunction
I had same problem, at first I could not find out how to seperate the small silver cover with the on/off switch from the rest. After removing the 3 torx screws, 1 at the power entrance, and 2 under the shaver blade. You can remove the black cover. I also removed 2 more torx screws to separate the battery, from the rest, (don't know if thats really necessary). The silver covers are 'clicked' into eachother. When lifted the part where the battery part was screwed into, the silver parts became partly seperated, then you can pull the part apart.
I cleaned/washed the trimmer part with wd40 contact spray.
Assembled the parts, and made sure that the little plastic nodge was came into the trimmer.
Cleaned it all (removed leaking wd 40) and works fine again.
Hopefully this is helpfull to anyone.
Goodluck,
Adrian
Dec 25, 2006 | Braun Cruzer 3 Electric Shaver
Conair HC100RCS Hair Trimmer Logo
61 people viewed this question
Top Conair Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
 Mikey
Mikey
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
