Question about Sony STR-DE485 Receiver
Fuzzy sound from right front speaker output
Happened suddenly one day - the right speaker output is distorted - swapped speakers and wiring and it is definately the positive output for the right side. No obvious issues noted when looking at the solder points on any of the boards. Anything simple to check and/or replace?
  • Anonymous Mar 16, 2009
    I have the same issue with my left speaker. One day I got nothing but crackling from that channel. I checked the wire and speaker with another channel and everything was fine. Definitely an internal problem.
  • 4,234 Answers
The main issue is to determine where the distortion is coming from. Does it start in the front and and get amplified or does it appear in the output section only? This will require a fixed signal and an oscilloscope to trace. Check for leaky coupling caps or leaky transistors in at the diff-amp section.
Posted on Feb 02, 2009
Bose acoustimass 3 left channel fuzzy
Being Bose, the service department will require the unit back for service.
Jun 14, 2017 | Bose Audio Players & Recorders
No Sound in Right Front Speaker- Denon AVR-1508
hi there,
have you check the system settings for each of the speaker..? should be set and balance all output of the speaker
May 24, 2008 | Audio Players & Recorders
Fuzzy crackling sound from front right speaker only -tried switching speakers and speaker wires with front left and the right still gets fuzzy and crackles
Look to the source. Try switching or reseating any cables between it and the speakers.
Is it on all audio sources or only certain ones? Have you swapped the speakers Left-to-Right to isolate the speaker from the signal chain as a cause?
If it's only an analog source doing it I would suspect a bad audio cable or a switch somewhere in the signal path. Typically, it might be a switch you
rarely use, like a Tape Monitor. It's wise to occasionally (with power OFF) operate all manual controls throughput their ranges a number of times to wipe oxides from their contacts.
Jan 29, 2011 | Audio Players & Recorders
Sony DAV-SC8. I'm suddenly getting distortion
It sounds like the speakers themselves are the problem rather than the amp.
Although, it would be rare to have overdriven/blown the surrounds.
My suggestion would be to isolate which speakers or channels (on Amp) are at fault.
Swap left and right to see if the problem transfers across.
Sep 13, 2009 | Sony DAV-SC8 System
I have distortion coming out of my front right channel of my AVR
Yes, sounds like your DSP chip has an issue. Not an inexpensive repair if that's the culpret. Around 400-500 to replace the chip. It's an awesome receiver and worth 300-400 in repair, however, a 3800 or 1800 can be had for 600-800 depending where you look. If you need more help, post a comment and I can help you some more.
Aug 10, 2009 | Yamaha RX-V2600 Receiver
Left front channel has stopped working
if you are sure you swapped speakers and its still the same, get a refund the unit is bad.
Dec 16, 2008 | Onkyo TX-SR606 Receiver
No Sound Right Front Speaker
Sounds (forgive the pun) like that channel's power chip is gone. Take it to a Tech, I may advise...
Mar 29, 2017 | Audio Players & Recorders
Sound not coming from left side surround sound speaker or my right side front speaker
it is highly likely that you're TV is outputting mono sound, hence the left channel only. check your physical connections to the TV and the balance / channel volume on the television as well.
May 01, 2007 | Onkyo HTR500 Receiver
Stereo speaker suddenly stopped giving sound
You will need to take the speaker apart and with an ohm meter or continuity tester, measure the resistance of the speaker right at the speaker to see if the speaker is open. if it is you have no choice then to replace the speaker. If the speaker measures a low resistance, measure the wires froom the speaker to the output wires or terminals. Some speaker manufacturers install small fuses inside their speakers. Good Luck
Mar 29, 2007 | AAD E-30 Main / Stereo Speaker
Sony STR-DE485 Receiver Logo
573 people viewed this question
Top Sony Audio Players & Recorders Experts
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
