Question about Sony Xplod XM-1652Z Car Audio Amplifier
One speaker is working more than the other
I had was mounting 2 10'' subs to the rear of my truck, when i reconnected the speakers one was working more than the other, i replaced the fusses and i am still having the problem, whats up?
  • pucknutchris Feb 02, 2009
    i have it bridged with everything wired right and the one not pushing as hard isn't burnt out, could one channel on the amp have weakend or something along those lines? or should i see if the dual voices coils are wired right?
  • 486 Answers
HAVE YOU THE LEADS ON THE RIGHT TERMINALS POS AND NEG?OR ONE SPEAKER WILL BE GOING BACK THE WRONG WAY, OR GENTLY PUSH CONES BACK SEE IF THEY MOVE THE SAMECOULD BE ONE IS SIEZED OR BURNT OUT
Posted on Feb 02, 2009
  • cock cock
    cock cock Feb 03, 2009
    SWITCH SPEAKERS TO SEE IF ITS THAT OR THE AMP, AND RECHECK FEED IN, THAT INPUT IS SUPPLYING SAME POWER FROM HEAD UNIT, AGAIN SWITCH FEEDS IN AND CABLES ARE NOT SHORTING THE FEED IN OR OUT, SO ELIMINATE EACH PART BUY SWAPING EACH COMPONANT,
    IF AMP CHECK THE EARTH PLAIN NOT BROKEN OR SHORTED ON CIRCUIT BOARD. THEN YUP IT IS THE AMP,
Why are my satellite speakers not working?
set sound to defoult on main receiver power of and then power on
Sep 02, 2014 | Vizio S4251w-B4 5.1 Soundbar System 5.1...
Esw-c10 subwoofer hums and dont work
if you short a sub it will hum try connecting it to a working speaker (no amplifier) if you have access to rear of sub check for wire only needs to be the size of a hair arcing out the speaker, i have a sub that does that on only one output (left rear) its actually the stereo causing it to hum..
Jun 20, 2012 | Energy ESWC10 Subwoofer Speaker
I been having a problem with my JBL TLX CSS-SUB1, I don't have the manual. Connecting speaker wires from the JBL TLX CSS-SUB1 to the a Digital Audio/Video Control Center ( it's a reciever) I confused,...
The connection on the receiver would be the sub woofer out. Not a sub woofer out LFE, a sub woofer out with speaker wire connection. From there you plug it in to the top section of the available terminals on the sub you are referring to (speaker level input). One in positive and the other in negative matching what you did on the receiver with correct ends. The speaker connections underneath the top connections is for additional speakers like surrounds to be able to be connected directly to the sub woofer speaker level out for sound. This of course would be for an older receiver connection. I do not think it is possible to convert this connection to an LFE and have it work properly. If the receiver does not have sub woofer speaker connection and only a RCA out then you can try to connect both rear speaker connections from the receiver to the speaker level inputs on the sub and then connect your rear speakers to the speaker level output on the sub to power them. This is an active sub woofer but for some reason they made it connect as if it was passive. I am not sure if this sub is designed for really low frequencies required for movie or if it is better for music.
Nov 01, 2010 | Audio Players & Recorders
No sound from front speakers
Check if a or b or what is reflected for speaker.
Oct 27, 2017 | Technics SA-DX950 Receiver
Wiring Speaker to amp
remove all speaker connections to your amp. MAke sure the inputs are driving all 4 channels, and that the built in crossovers on the amp are all set to full range. Conect your full range speaker to each output channel one at a time and verify there is oputput on all 4 channels. If all is ok, then connect your rear speakers to the front(a) outputs of your 4 channel amp, and then use the second 2 channels (rear or B) bridged to drive the sub. Re-configure the crossovers for highpass for front (to drive your rear speakers) and lowpass for sub. This is the proper way to connect a 4 channel amp with a sup whle driving 2 full range speakers.
Jun 10, 2009 | Car Audio & Video
Rear door speakers don't work w/ aftermarket radio in 94 suburban
You need to attach the blue wire on the stereo harness to the blue and white wire on the car adapter harness. they installed a small amplifier to power the rear door speakers and unless you connect those two wires then the speakers will not work.
Jan 05, 2009 | 1994 Chevrolet Suburban
Onkyo 875 - No sound
YOU ARE PROBABLY USING 5 SPEAKERS WITH OR WITHOUT A SUB, AND YOU CONNECTED THE REAR SPEAKERS TO THE REAR SPEAKER OUTPUTS. THEY WON'T WORK THIS WAY. RECONNECT THE REARS TO THE SURROUND SOUND SIDE SPEAKERS, AND RERUN THE AUDISY SETUP. THIS SHOULD TAKE CARE OF THE PROBLEM. YOU HAVE TO FOLLOW THE DIRECTIONS AND SET UP THE DVD INPUT, IT WON'T WORK RIGHT OUT OF THE BOX, TOO MANY VARIABLES.
JACK
I CAN'T GET MY 875 TO RECOGNIZE COMPONENT VIDEO SIGNALS, I GUESS I'M STUCK USING HDMI, AND COMPOSIT INPUTS.
Feb 25, 2008 | Audio Players & Recorders
Sony Xplod XM-1652Z Car Audio Amplifier Logo
44 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
