Question about Dell E152FP 15" Flat Panel LCD Monitor
Brightness/contrast menu popup
On my computer the Brightness/Contrast block comes up and the hilighter goes from exit to brightness to contrast it does that over and over again. I press the plus to reach the exit it disappears for a second and than returns no matter in which program I am.
Do you have any ideas to stop it.
    Scholar:
  • 116 Answers
Sound like either the button is stuck or the display is in error.
press and wiggle the buttons carefully, and disconnect the power to the display.
Posted on Feb 02, 2009
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
Feb 07, 2013 | Computers & Internet
Unable to reduce brightness windows7 ultimate hp1670
laptop ot desktop monitor ?
Adjust your monitor's brightness and contrast
Brightness and contrast symbols
Laptop display. Laptop displays don't have brightness or contrast buttons on the front.
For a majority of laptops, there isn't a control for setting the contrast.
However, you can set the brightness of many laptops by pressing and holding the Fn key, and then pressing a function key to decrease brightness ( ) or increase brightness ( ).
http://windows.microsoft.com/en-US/windows7/Calibrate-your-display#
When using Display Color Calibration on a laptop, set the display to the maximum brightness setting.
Adjusting brightness automatically using adaptive brightness
Adaptive brightness is a feature in Windows that uses a light sensor to automatically adjust the display brightness to match the lighting conditions in your computer's surroundings.
To use adaptive brightness, you must have light sensors installed and enabled on your computer.
To determine if your laptop or computer monitor supports adaptive brightness, look for the Enable adaptive brightness setting in Power Options (mentioned in the following procedure) or check the information that came with your computer.
To turn adaptive brightness on or off
Open Power Options by clicking the Start button , clicking Control Panel, clicking System and Security, and then clicking Power Options.
Under any plan, click Change plan settings.
Click Change advanced power settings.
In the list, expand Display, and then expand Enable adaptive brightness.
To turn adaptive brightness on or off when your computer is running on battery power, click On battery, and then, in the list, click On or Off.
To turn adaptive brightness on or off when your computer is plugged into an outlet, click Plugged in, and then, in the list, click On or Off.
Click Apply. Click OK.
hope this helps
Jul 26, 2012 | HP...
HOW DO I BRIGHTEN UP MY MONITOR SCREEN?
hi,
you can adjust the contrast and brightness of the screen accordingly using the following instructions. Please select the right combination of brightness and contrast according to your desire.
  • Please check out controls in the bottom of your monitor, below the scree. I have provided the image below for your reference.
  • In this the fourth option is OSD menu. Please click on it and you will scoll down to options .
  • you can see options called "brightness and contrast". I have added picture for this too!
9b04c60.jpgOnce you go that page,use the menu to enter! then use the 2nd and 3rd button to adjust the brightness. Now your job is done.Please click on 1st button to exit. If you need more assistance in this, please write back to us. Please rate my solution as helpful!
Apr 02, 2010 | Acer AL1715 17" LCD Monitor
Viewsonic VG2021m contrast/brightness menu won't go away
I had same problem. The solution I got was to unplug power cord, and hold down each switch on monitor for 30 secs and switch on. IT WORKED! Hope it helps you too.,
Fred
Apr 12, 2009 | ViewSonic Graphic VG2021m LCD Monitor
Brightness/contrast
Mos likely the menu (or one of the buttons) has malfunctioned and is shorting. You can try to shake or wiggle the button to try to loosen it.
Or there is a malfunction with the circuit board and there's not much you can do. You can send it in for repairs but that often costs a lot of money and the problem could come back. If it didn't cost a lot of money to buy or is older than 4 years, I recommend you buy a new monitor.
Oct 08, 2008 | Dell E152FP 15" Flat Panel LCD Monitor
Dell 15 inch monitor, brightness/contrast window
The front panel switches are known to become leaky.You need to replace these switches.
Samir.
Please rate the solution and provide feedback.
Sep 28, 2008 | Computers & Internet
The Contrast screen pops on all the time
It looks like your UP button contact is demaged.
SOLUTION is to insert a piece from your business card mostly above the button to adjust it down or up. It works fine.
Dec 09, 2007 | ViewSonic VX910 19" LCD Monitor
Dell E152FP 15" Flat Panel LCD Monitor Logo
445 people viewed this question
Alun Cox
