Question about ViewSonic VX2235WM Monitor
I just bought a viewsonic vx2240w. When I change the resolution to 1680x1050 the page becomes too wide for the screen. I have to scroll left and write just to see it.
  • 4 Answers
This sounds like an issue with the windows driver for your video card. I have to load the viewsonic driver for my monitor first and make sure the device monitor is showing the vx2235 and not default monitor. Then make sure your video board will support the 10 x 16 format and check for any settings about horizontal scrolling. If you are running an ATI card, get the latest version of the Catalyst drivers from their web site. Hope this helps.
Posted on Mar 15, 2009
Not able to change the display mode to aspect at 1920x1080 resolution... but able to change the display mode to aspect @ 1680x1050 pls help... right now my screen is totally messed up.. i mean the display...
I'm not sure I totally understand the problem, but in general if you can't change to a higher resolution that indicates an issue with your video/graphics drivers rather than your monitor.
I'd try updating your graphics drivers (download the free program Speccy if you need help determining what video card you have) and then seeing if you can set your desired resolution after a reboot.
Mar 01, 2011 | BenQ G2220HD Monitor
I cannot install the driver for Viewsonic VX2235wm (XP pro) Cannot select 1680x1050 res for this monitor
Well your LCD supports 1680x1050 resolution.
You have to check the video/ graphics card of your PC, if it supports the same resolution or not. Let me know the model no. and your motherboard details for a better assistance.
Looking forward for your response
CreativeTECH
Nov 13, 2010 | ViewSonic VX2235WM Monitor
I connected my ps3 to my viewsonic vx2235wm and it says out of range or wont have a picture
The PS3 video output setting is too high for the monitor to handle, native resolution for this Viewsonic is 1680x1050. Try running the PS3 at 640x480 first and start changing the resolution to higher level.
Mar 25, 2010 | Computers & Internet
1920x1080 resolution-entire screen not viewable
This also happens to my vga connection to my TV.
I used my tv remote "auto" button to re-size it to fit correctly.
If your monitor/TV does not have the adjustment, you may need to
supply your vga compatible device with your monitor's driver software.
This tells your computer what monitor specifications you have.
Mar 16, 2010 | ViewSonic X Series VX2260wm 21.5"...
Have a VG2230wm wide screen and the image trembles and bounces slightly, and the color is going from white background to pink. What would be causing this? The monitor is about two years old, it is set at...
This is due to a bad pin or bent pin or a bad connection isde the monitor or can even be a bad signal cable. Check all of these when in doubt check the solder points inside the unit.
Thanks hope this info helps please rate...
Aug 21, 2009 | ViewSonic VG2230WM LCD Monitor
How do you change the resolution on a Viewsonic VE510S
Click Start, then Control Panel, now Display and then Screen Resolution. There should be a slide bar there that goes left or right.
Keep in mind, it depends what kind of video card you have. If you can only go up to 1280x800, but your monitor supports 1680x1050 it's because of the video card.
Hope that helped.
Jul 17, 2009 | ViewSonic VE510s (Black, Silver) 15" LCD...
1440x900 Monitor seems to think it is a 1680x1050 screen @ >19"?
Try reinstalling the video driver (Control Panel - System - Device Drivers - Video ... ) Good luck
Jun 13, 2009 | ViewSonic VA1930WM LCD Monitor
Scrolling lines on monitor
Weird... if there's still warranty on the monitor see if you can get it fixed or replaced with a new one.
Mar 06, 2009 | LG W2252TQ Monitor
Viewsonic vx2245wm
You need to chk graphics settings in NVidia control center and change resolution until it looks right
Mar 06, 2017 | ViewSonic VX2235wm LCD Monitor
Problem with the P5VDC-MX to display 1680x1050 resolution
If you go to the FAQ section for your board you will see that the screen resolution can only go to 1600x1200 UXGA, UXGA+ res name pixal depth 8/16/32
http://support.asus.com/faq/faq.aspx?SLanguage=en-us&model=P5VDC-MX
FAQ page 4
Dec 30, 2007 | ASUS P5VDC-MX Motherboard
ViewSonic VX2235WM Monitor Logo
204 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
