Question about Car Audio & Video
What das the ws button stand for on the interior pannel
This regarding mercedes 230 slk?
  • 179 Answers
SOURCE: what is the correct spark plug gap
.35 to .40 should be fine also the parts store or a dealer can help
Posted on Jun 02, 2009
  • 99 Answers
SOURCE: '03 SLK 230 top wont close - stuck half way open
first thing I would try, disconnect the battery to the car for a minute, then reconnect it. that may correct your problem.
Posted on Aug 30, 2009
Testimonial: "Thank you so much! That was the fix no one (else) could give me on a Sunday. Now I need the code to unlock the stereo... I will check with Mercedes."
  • 140 Answers
SOURCE: 98 mercedes SLK 230 ASR dash light on although
Check one of the fuses in the bonnet. There is most likely an electrical contact problem. You will need a fuse wire replacement
Posted on Oct 14, 2009
  • 2702 Answers
SOURCE: mercedes slk 230 1998 locks all doors with remote
this sounds like a door switch not switching if you shut the door and left your kyes inside the car the door locks would pop up so you cant look yourself out,,,(but you can?) my money is on a door switch,, give them all a good swilling with WD40 to free them off if this dont fix it then its the car alarm it needs to be reprogramed to the kye fob and also fit a new battery to the kye fob at the same time people often forget how much work the kye fob needs to do and only when it stops working do they change the battery in it,
Posted on Feb 23, 2010
  • 4793 Answers
SOURCE: mercedes slk 230 kompressor supercharger doesn't
only a turbo "kicks in".a supercharger is a compressor that uses the speed of the engine, so the faster the engine the more pressure....use the gearbox for rapid acceleration....
Posted on Jun 07, 2010
I need orings for top of pump on slk230
SLK 230 320 Hydraulic Top Cylinder Rebuild Kit O-ring Seals - Page ... > ... > R170 SLK Class
May 6, 2010 - 10 posts - ‎6 authors
If the screw that is on top of the pump is lost what are my options? ... Ebay search: Mercedes SLK 230 320 Convertible Top Hydraulic Cylinder. ... just surprised that the last two orings are almost useless.other than, its worth it.
Oct 30, 2015 | Cars & Trucks
1998 slk 230 can the boots central locking alignment interfere with the operation of the roof closing
your windows move first , check fuses and clean your window may be sticking due to dirt.
Jan 20, 2015 | 1998-2004 MERCEDES SLK230 SLK 230 CARBON...
What to check when a SLK 230 1999 Convertible top will not open?
dont know much about convertible mercs but there should be a relay which would send power to the motors if this has blown the lid would not lower or fuse or the terminals in the switch its self are still wet
Sep 08, 2014 | Mercedes slk 230 kompressor fuse. lock. ....
Mercedes slk 230 hardtop does not open
I owned an SL 500 with the same issue. The auxiliary battery went out ( during warranty )
Mar 11, 2014 | 1998-2004 MERCEDES SLK230 SLK 230 CARBON...
Merc 230 slk 1998 stalls when put into gear unless you are very quick
check the gear box fluid levels this is usually the cause of most merc faults on the box
Mar 18, 2013 | Mercedes-Benz Cars & Trucks
How to do I open the hood on a mercedes 2003 slk 230
the release is under the dash for the main lock the safety is by the rt oor left headlight
Mar 04, 2010 | 2004 Mercedes-Benz Mercedes Benz Slk Class
Aug 30, 2009 | 2003 Mercedes-Benz SLK-Class
Car Audio & Video Logo
111 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
