Question about EA - Electronic Arts NHL 08 for Xbox 360
Can't change period time. when i put 5 min it comes up 20:00 MIN.
IS THERE SOMETHING I AM MISSING . I SET THE GAME UP SKILL LEVEL PERIOD TIME AND I PUT 5 MIN AND WHEN THE GAME STARTS IT IS ALWAYS 20:00 MIN. THE SCREEN SHOWS I PICK 5 BUT WHEN THE GAME STARTS IT IS 20:00.. PLEASE HELP..
  • 67 Answers
If your playing the campaign mode you can't change the time only with multi player
Posted on Jun 03, 2009
TV powers on & off every 5-10 min. After about 3 times it powers off and has to be turned back on. Why?
Someone may have turned on the sleep setting meaning after a set period of time the TV will automatically turn off.
Jun 01, 2015 | Televison & Video
Cub Cadet LT1050 Runs fine..20 min...dies...wait 20 min....runs fine 20 min.
Check the breather in the fuel cap, run it with the cap loose and see if it is any better.
May 30, 2013 | Cub Cadet Riding Lawn Garden Tractor 25hp...
I bought a house with a Hunter # 44100A programmable thermostat but have no manual to program it from. How can I program it?
To change the time, press Hour once. Then press and hold Hour to until it reaches the correct one (pay attention to the AM/PM notation). Do the same with the Min and Day buttons. Press Return when done. (The thermostat will leave return to the normal mode after 10 seconds without a button press.)
Now to set the program, set the switch to heat or cool depending on which you want to program first. Press Prog (this will program M-F settings) then press and hold Hour until the time you want Prog 1 to start. Press the Up or Down arrows to get to the temperature you want to reach and stay for this period. Press Prog again and use the Hour/Min/Up/Down keys to set the time and temperature for next period. Repeat for program 3 and 4 for weekdays. Press Prog again to do the same thing for the 4 possible weekend program segments. Any time left at 0:00 results in a program being skipped.
Press Prog to set the Program. These settings will not take effect until the next time change in the program. You can review the settings by pressing Prog and scrolling through the settings.
Change the switch to the other setting and repeat the programming if your system has both AC and heat.
If you want to press the AutoProg button the thermostat will use preset times and temperatures. For Heating that is 5 am 68, 7 am 60, 3 pm 68, 10 pm 62. For cooling it is 5 am 78, 7 am 85, 3 pm 78, 10 pm 82.
For more information, you can get the manual from Hunter: http://www.hunterfan.com/Support/Manuals-and-Parts-Guides/ , just enter the model number in the Search line.
I hope this helps.
Aug 17, 2010 | Hunter Heating & Cooling
Htc battery is not up to dat level.. Is it so..
What do you mean by HTC battery is not up to "dat" (that) level?
Is it always running out of battery so easily? Or it's not charging correctly.
HTC phones has a battery life basis. Please refer to the info below:
Standby time: Up to 490 h (2G) / Up to 390 h (3G)
Talk time : Up to 6 h 20 min (2G) / Up to 5 h 40 min (3G)
Music play: Up to 12 h
If your HTC phone's battery is not not reaching the said hours, there could be a possibility that your battery is defective. You may send your phone to the dealer and have them repair it, or replace it if it's still under the warranty period.
Thank you for using fixya!
Jul 16, 2010 | HTC Touch HD Smartphone
Where can I download instructions for utilitech timer
UTILITECH - Grounded in Quality
Digital 2-Outlet Timer (TE06WHBL)
Instruction Manual & Warranty
Before using your timer please read the following instructions carefully.
FEATURES
- Up to 8 ON/OFF events per day/56 ON/OFF events per week
- Option to program individual days or 8 different weekday groups
- Minimum switching period one minute
- Summertime/wintertime change over
- Easy to read LCD display
- Random automatic ON/OFF security feature
- Countdown feature
- Manual override button
- Rechargeable battery back-up (if there is no LCD display, plug
timer into a wall receptacle, this will recharge the battery)
SETTING TIME
Press and hold CLOCK key, then press DAY key to select correct day,
HOUR key to select correct hour, and MIN key to select minutes. When
MIN key is released, time will be set with seconds starting from 0.
Either holding down or repeatedly pressing appropriate button can
advance days, hours and minutes.
Do not set ON and OFF for same time.
PROGRAMMING EVENTS
The timer has the capacity for 8 ON/OFF events per day.
Save program capacity by using available blocks of days.
Blocks of days are:
1. M,T,W,Th,F,S,Su
2. Individual days of the week
3. M,T,W,Th,F
4. S,Su
5. M,T,W,Th,F,S
6. M,W,F
7. T,Th,S
8. M,T,W
9. Th,F,S
For each ON time and each OFF time--DAY, HOURS and MIN must
be set. Press PROG key onceto set first ON time--"ON" and number
"1" appear to left of LCD display indicating to enter first ON time.
Press DAY button to choose required day or blocks of days, then set
hour and minutes using HOURS and MIN buttons. After setting required
ON time, press PROG button to validate entry and move onto first
OFF time--"OFF" and number "1" appear to left of LCD display
indicating to enter first OFF time by using DAY, HOURS and MIN
buttons as above. Press PROG button to validate this entry. Repeat
remaining 7 ON/OFF settings as required. After setting required
ON/OFF settings, press CLOCK button to return display to clock. Timer
is now ready to operate. Check programmed settings by pressing
PROG button repeatedly--each setting will appear on screen.
MANUAL OVERRIDE
To choose permanent Manual ON, permanent Manual OFF,
Auto ON or Auto OFF, press Manual button. Each mode will be
displayed on screen. When choosing Auto ON, timer turns ON until
next programmed OFF time. The programmed settings will only work
on Auto mode. When Auto mode OFF is chosen, timer is OFF until
next programmed activity. (Inverted black triangle on LCD points
to either AUTO or MANUAL indicating which is selected)
COUNT DOWN FEATURE
To enter count down feature, press CLOCK and PROG buttons
simultaneously. Using HOURS and MIN buttons, set count down time.
(Maximum selection is 9 hours 59 minutes, minimum is 1 minute.)
Press MANUAL button to start countdown. Output will turn ON until
end of count down. Count down may be paused at any time during
period by pressing MANUAL button. To re-start, press MANUAL button
again. To review time during count down period, press and hold
CLOCK button. Release CLOCK button to return to count down display.
Note: To return to timer mode, press CLOCK and PROG buttons
simultaneously.
RANDOM AUTOMATIC ON/OFF SECURITY FEATURE
With this option selected, timer will switch ON and OFF in a random
pattern at least once in every 8 hours. (This may mean timer will
switch OFF within a set ON period, or vice versa.) Ideal for use with
a light--switching it ON and OFF automatically gives appearance of an
occupied home, but not at exactly the same time every day. To enter
Random mode, press DAY and HOURS buttons simultaneously.
An "R" will appear on display and unit will start random switching.
If no programmed times are set, timer will switch ON or OFF
approximately 1 minute after entering Random mode, then continue
randomly. To turn Random mode OFF, press DAY and HOURS buttons
together again.
SWITCH OVER SUMMERTIME/WINTERTIME ZONE CHANGE
To change from wintertime to summertime, press HOURS and MIN
buttons simultaneously. Clock will be set forward one hour and
"S" will appear on display. Repeat same procedure to return to
wintertime.
Note: if unit is purchased during summer, set clock time for one hour
less than correct time, select Auto mode and press HOUR and MIN
keys simultaneously. The unit will then adjust to correct summertime
and "S" will appear on LCD.
RESET
To reset unit for time and programmed ON/OFF settings,
press RESET button.
IMPORTANT SAFETY PRECAUTIONS and
RATINGS
[Contact the manufacturer; I've already wasted too much time typing
this in:
AmerTac
Saddle River Executive Centre,
One Route 17 South, Saddle River, NJ 07458
800-777-0802
www.amertac.com
Made in China
May 05, 2010 | Kitchen Appliances - Others
For knowing warranty period
its time to replace the battery.
Apr 09, 2008 | HP Pavilion dv6000z Notebook
Auto Power Off function?
To conserve battery power, the camera will shut down if an operation is not made within 3 minutes (default setting). The auto-power-off period can be changed in the setup mode to 1 min., 10 min. or 30 min. at user's option. When using the AC adapter, the auto-power-off period is set at 30 minutes.
Sep 19, 2005 | Konica Minolta DiMAGE E201 Digital Camera
EA - Electronic Arts NHL 08 for Xbox 360 Logo
113 people viewed this question
Top EA - Electronic Arts Video Game Consoles & Games Experts
James Wishart
Adam Jasar
Level 1 Expert
Nikki  Mclean
Nikki Mclean
Are you an EA - Electronic Arts Video Game Console and Game Expert? Answer questions, earn points and help others
